Question about Hotpoint RB757 Electric Kitchen Range
Burner Heating element doesn't heat
I've had a repair man out for range model RB757BC2WH. Burner element is not heating. He recommended replacing infinite switch. After installing WB24T10029 switch it still does not work. There is power all the way to the element. The element has also been replaced. The repair man suggested getting a wiring diagram to check the wiring. Do you have one or any other suggestion?
  • whah7 Nov 17, 2009
    The element and infinite switch are good. There is power all the way to the element; it just doesn't heat. The element is good because it works in a different receptacle. Replacing the infinite switch caused the Surface units light to start working correctly. Before replacement, it the surface units light had been on continuously.
  • whah7 Nov 18, 2009
    Turned out there was a pinched wire causing the problem.
  • 11,896 Answers
Check power to element with a voltmeter. If there is power, the element is bad. If not power, than switch or relay is likely faulty. You can also test them with an ohmmeter
Posted on Nov 17, 2009
  • Nate Stansfield
    Nate Stansfield Nov 17, 2009
    How is the receptacle? have you tried to replace it?
  • Nate Stansfield
    Nate Stansfield Nov 18, 2009
    The ribbon cable connections can be corroded or loose. The wires can become loose or pinched and will cause this problem as well. You can test wires to see if there is a pinched, broken, or loose wiring which is a common cause.
How do i fix a heating element on my electric cooktop
Most top elements are just a plug in.. find where the element joins the body of the stove and firmly pull on the element straight back from that point. MAKE SURE THE POWER TO THE STOVE IS TURNED OFF AT THE BREAKER
Mar 02, 2015 | Kitchen Ranges
Why does my whirlpool gold accubake range display turns off?
If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem.
Or Why does it take the oven so long to bake?
When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it.
Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it.
On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat.
Or Oven safety valve needs to be checked with multi meter ohms / voltage
ALSO Test the Burner Heating Element
The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard.
When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps.
First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring.
Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element.
Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity.
Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be.
To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced.
The reason for my free advice is GOD is good!
Jul 06, 2014 | Whirlpool RBS275PD Electric Single Oven
Oven does not stay on
Oven comes on and off intermittently or heats very little:
ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings.
Jun 14, 2014 | Whirlpool 30" Self-Cleaning Freestanding...
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Model 444445410 pven will not stay lit
Aug 15, 2011 | Belling Ovens
Heating elements on stove top stopping heating
To test the heating element, do the following steps:
Jan 19, 2010 | Electrolux Kitchen Ranges
Electric burner does not heat up.
The reason for Maytag electric burner not to heat up is that the heating element had exploded and there was white powder all over the inside of the oven. Replacing the heating element will make it work.
Also would recommend having the following cross verified:
· Element terminals have loose connections? Reposition the element.
· Range element shorted out? Find out by testing; replace if needed.
· Burner switch is bad? Find out by testing; replace if needed.
· Element receptacle bad?
Thank You for using Fixya.com
Jul 28, 2009 | Maytag Gemini® MER6765BA Electric Kitchen...
Range heating problem
if you already eplaced the heating element and its still no doing what its supposed to then its time to call in a repair man instead of 2nd guessing or changing part after part,,,
Jan 06, 2009 | Thermador UCV36A 36" Universal Cook 'n'...
Replacing a radiant element on a maytag glass top range I'm having strange problems with the two right elements of my MER5770 The front larger dual element will only operate at high heat. When turning on...
If the burner is scorched or pitted, go ahead and replace it. New burners can cost anywhere from $10 to $40. Otherwise, check the burner's electrical connections to make sure there is solid contact. Jiggle the burner in its socket. If it is loose, then remove the burner—most just pull out of the electrical socket, although some are mounted with a screw. (Always unplug the range before removing a burner.) Slightly spread the two terminals apart for a tighter connection. If it still doesn't work, then replace the faulty burner with a functioning burner of the same size. If that burner works, then replace the bad burner with a new one. If it doesn't, then inspect the electrical socket for damage. If it's charred, replace the socket. To do so, remove the screws that secure the socket to the range and then unscrew the range wires. Attach the wire connections of the new socket to the range wires and reassemble the burner.
Aug 19, 2008 | Kitchen Ranges
Hotpoint RB757 Electric Kitchen Range Logo
370 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
