Question about Xerox DocuPrint N17 Laser Printer
Dark streak I'm getting a dark streak about 1/2 inch wide all down the length (11" side) of the paper. Any ideas how to get rid of this
  • 53 Answers
Clean the glass lining. It is situated on the left of the glass when you open the document feeder...clean it with a damp cloth
Posted on Nov 20, 2009
Dark streak on paper
you need to clean the rollers. consult the manual about cleaning the copier. if you don't have a manual, then get some methyl alcohol (any alcohol that evaporates completely will do). use a lint free cloth to rub a small amount of alcohol on all roller surfaces (accessible via pull-down compartments on front and back, usually).
Nov 29, 2011 | Canon PC-921 Black and White Copier
MFC8500 VERY DARK STREAK (.25 INCH WIDE) RUNNING DOWN THE ENTIRE WIDTH IOF THE PAGE.
Reference page 22-17 in reguards to cleaning the charge wire on the drum unit and page 22-16 for cleaning the document scanner. This is a link to your Brother MFC 8500. Hope this helps.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_8500_EN_1354.PDF
If the dark streak appears on printed documents, cleaning the charge wire will correct it.
Nov 04, 2009 | Brother MFC 8500 All-In-One Laser Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Printer prints a black streak down the reverse side
You have a build up of ink inside the printer. I had a Canon that did this. I had to take the ink & print head out, and tear a paper towel strip 1 " wide and 13" long or however long the paper towel is. I folded it in half down the length so it was 1/2x13. Then used a plastic strip to shove it under the part the print head sits in. Once I got the towel to the other side, I grabbed it with my hand. I removed the plastic strip used to shove the paper towel under. So now the paper towel sticks out both sides underneath the print head cradle. I gently pull the paper towel back and forth so the paper towel can clean off the ink build up. Hope this helps.
Mar 29, 2009 | Office Equipment & Supplies
Dark streaks on copies from Xerox XC356 copier. Streaks were light at first; changed to a new toner cartridge and streaks are same size/same place on the page -- but now darker. There are three streaks,...
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Mar 04, 2009 | Xerox XC356 Copier
Scanned image on left is cropped by a good quarter of an inch.
To get the image on the right side, Select 11" wide and the length you want. Keep the paper guides at the far ends. Insert the paper at the extreme right side and the image will appear on the right side. The left side would appear dark and You may need software to clean. If you dont have Raster Editing software, best way is to stick your image onto a white paper and scan the whole paper. Ensure that the ends are trim. ( I am assuming it is faceup scanning)
S. Mohan
Feb 08, 2008 | Canon DR-5010C Path-Through Scanner
Scanning document leaves streak down right hand side
Even a single grain of dust or a single strand of hair on the scanning glass will cause the scan head to perceive ink/image where there is none. Deffinetly try cleaning the glass using a good window cleaner, and a cloth that is completely clean, or even a peice of newspaper. If the black line remains, I would suggest taking it into a service center to have the scan head itself cleaned.
Dec 05, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Dark spots on my paper
is there a corona wire sliding cleaner on the drum assy? if so it should be firmly at the correct end of its travel - on some printers if it is inboard it will print aline down the side
Apr 18, 2007 | Kyocera Mita FS 3800 Laser Printer
Xerox DocuPrint N17 Laser Printer Logo
211 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
