Question about Coffee Makers & Espresso Machines
My whirlpool LSR7233B will not spin or adjatate
    Sergeant:
    Champion:
  • 289 Answers
Sound's like the couping between the moter and the transmition is bad.to replace the coupling you first to remove the two screw's on the frount of the control panal.than pull control panal forward and lift up and back.next you nead to remove the clip's on the left and right.next unplug wire harness from door switch line.next lift the door and pull body forward and out.the whole body will come off.the first thing you will see is the water pump.remove the two 1/4# screw's from clamp's holding the pump on. next remove the two clamp's.next pull pump forward and to the left to keep it out of the way.next remove the wire harness from motor.next remove the clip's from motor and pull motor out.next remove what is left of the coupling from the motor and the transmition.install new coupling kit.you my have to use a exstention and a hammer to tap new part's on motor and transmition.next place rubber part on transmition and line open hole at 12 oclok.on the moter make sure you have one of the prong's at 12oclok to match the transmition.take the motor and line it up with the transmition and push it on.next reinstale the two clip's to motor.next reinstale wire harness to motor.next realine warter pump with motor.you my have to manualy turn coupling to get motor to line up with pump.reinstall clip's to water pump along with the two 1/4#screw's.next reinstall body on frame and reinstall the clip's to the left and the right.next hook up the wire harness back on the door switch line.next rotate control panal down and set in place and reinstall the two screw's and you are done.
Posted on Nov 17, 2009
Whirlpool model LSR7233B. Tub won't spin on spin cycle.
Clark Wrye, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Clark Wrye ), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool Washing Machines
Why does my washer make soo much noise when washing sheets??and the sheets wind up in a big ball
If the mod # begins with 110 its whirlpool built. Check to see if the top part of adjatator is moving grab the top of it turn back and forth it should turn the lower section in one direction but not the other.If it is not doing that and just spinning freely then your dogs are defective. cheap part and easy to replace do the test and get back for more info......Thanks for voting
Mar 20, 2011 | Whirlpool Washing Machines
Washer fails to remove water from clothes after rinse and spin cycles are completed. M/N 110.26732500
'f its a top load put something down in lid switch hole.....Start wash cycle let unit go through cycle by itself Don;t touch timer unit should fill then adjatate then drain then you will here a clunk and unit will spin thats the wash////then unit will fill then adjatate then unit will drain(this is the inportant part ) unit should drain completely before it spins if it is spinning with the water in it your gearcase is getting bad//This condition also put stress on the clutch//if unit is not draining and spinning at the same time but just spinning slowly then you will need a clutch.....Hope this helps if i did help you please vote need more help please ask..........
Feb 03, 2011 | Kenmore Washing Machines
Our whirlpool washers agitator doesn't agitate during the spin or wash cycles
I would asume you mean it does not adjatate during the wash or rinse cycles.If it fills and you can here the motor run after it fills/then it drains and does not spin and fills again for the rinse but does not adjatate ? I would guess you have a broken motor coupler ..Most shops will do that repair for under 100.00....If I had more info I could be more sure...anyhow if more info is needed just repost....I hope I help you if I did please give a vote...thank you good luck
P.S mod # helps so much
Feb 02, 2011 | Whirlpool Washing Machines
I have the model LSR7233B with the same problem as
What I would do is unplug the lid switch assembly from the harness and jump out the quick connect to see if that washer will run fine. Then replace the lid switch assembly. To do that you is gonna have to flip up the control panel. I have repair photos HERE
Feb 14, 2010 | Washing Machines
LSR7233B. Midway during regular wash it stops and
sounds like a bad timer.the part# is WPL285938,cost is $148.35.
Dec 11, 2009 | Whirlpool LSR5132PQ Top Load Washer
Have whirlpool LSR7233B top load washer. It fills and agaites but will not drain all the way and spins slowly on slowly on spin cycle
THE BELT THAT DRIVES THE DRUM MIGHT BE WORN, THE BELT IS NOT UNDER A LOT OF STRAIN WHEN WASHING AND MAY WORK FINE BUT WHEN IT GOES INTO THE SPIN CYCLE THE WEIGHT OF THE CLOTHES AND THE WATER WILL CAUSE THE BELT TO SLIP . I WOULD START THERE FIRST
Aug 23, 2009 | Whirlpool Washing Machines
Washer will not empty
sounds like coupler is out but unit should still drain unless motor locked. remove cabinet (2 brass clips under console) and check pump (up front) and coupler (behind motor). set to spin and tub wont move with coupler out but pump will run
Apr 05, 2009 | Whirlpool Inglis IP4400 Washer
GE WJSR2070B won't agitate
There is a drive block under your adjator. You must pull the adjator off. Get your fingers ( Man Friend LOL ) under edge of adjator & pull. You will see a plastic pat with screw in it . if you can spin with hand , replace it .
Mar 01, 2009 | GE WJSR2070B Top Load Washer
Whirlpool Thin Twin Washer
Sounds like the transmission is gone the thing you call the spinning mechanism is call the adjatator it should move left to right I can tell you right now to replace the dog ears if it is a kenmore washer they go bad all the time they cost about 5 dollars they are under the cap on top of the adjatator you will need to pull it off to do the job good luck Ron
Jun 10, 2008 | Whirlpool LTE6234D Top Load Stacked...
Coffee Makers & Espresso Machines Logo
160 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
