Question about SMC Barricade g SMC2804WBR Wireless Router
SMC2804WBR router: The lights are on but nobody's home.
My SMC2804WBR router isn't working. The power, WLAN and WAN lights are on. WLAN and WAN are a bit flickery but I can't remember if they used to do that. I've done a hard reset, lights come back on, but the computers can't load anything with the signal. They see the signal on the list of wireless networks but can't connect to it. It even shows the signal as being strong but they can't load anything. When I plug the computer directly into the modem the internet works fine. Not sure where to go from here
  • minipotatoes Nov 23, 2009
    I don't know a lot about security settings. if they were a problem, wouldn't that be wiped out by the hard reset?
  • 40 Answers
Sounds like the router is about to die. I had the same issue with a wireless router a few years ago. It would broadcast but I would not be able to get onto the wireless no matter what I did but plugging straight into the modem and it worked just fine. If you've done a hard reset and it is still not connecting or staying connected, it is about time to replace the router.
Posted on Nov 17, 2009
Testimonial: "Well, that's not the answer that I wanted, but it does make sense. Thanks :)"
  • 630 Answers
It's worth looking at your security settings.
Posted on Nov 18, 2009
INET light is on not able to connect to internet
Checked the instruction manual online. There's no INET light indicated. There's Power, Status, WAN, WLAN, and LAN LEDs. The WAN LED only indicates that the WAN port is connected to another device, e.g., cable or DSL modem. Check on your cable or DSL modem to see if the Internet light is on. If so, then you'll need to log into your router and go through the configuration/setup per the manual for your type of connection.
Oct 18, 2013 | D-Link 802.11g Wireless Router WBR-1310...
My linksys wrt160n wireless router light is blinking
Welcome to FixYa
Indication of Router Lights:
  • Power light blinks. If LAN or WAN cable is plugged in, their respective lights will flash on activity.
  • Power light turns off for several seconds.
  • All lights, except power light, turn on and then off.
  • Power light blinks slowly, then faster, and WLAN light will turn on.
  • Once Power light and WLAN light are on solid, the router is fully rebooted.
A working router should show solid green power light. upgrade the firmware of the router.
If this Helped you-Rate me..Thanks for Using FixYa
Jun 30, 2010 | Linksys WRT160N Wireless Router
DI-524 version D router problems
you need to open the configuration of the router. Read the manual in order to access on configuration. Once you access .. you can manually configure the router, and set what do you want.
Jul 27, 2009 | D-Link AirPlus DI-524 Wireless Router
Wlan lights off and now wirless access
Does your computer say Network cable unplugged?
If the wlan light is off, it means that your computer is not being detected by your router. You can try unplugging and replugging the ethernet cable at the back of the computer. Make sure that you hear a 'click' when you plug it back in to make sure tha it is properly seated. Check also the light on the wan port (desktops usually have lights..not sure about laptops though).
Do the same process with the ethernet cable but now from the other end--the one connected to the modem/router. if your modem/router have other ports on it, try to connect it to other ports as well. If you're wan light is still off, try using a different ethernet cable.
what's wrong with your wireless access? i can't read it from the title.
May 04, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
WLAN does not work
Can you try and reset the router once. I guess that should help . There should be a reset button behind the router and the reset procedure should be present in the manual
Jan 11, 2009 | SMC Barricade g SMCWBR14T-G Wireless...
Two router home network problem
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Dec 22, 2008 | SMC2804WBR Wireless Cable/DSL Broadband...
Cnet CWR 854 Router
Try this another way of resetting the router, Press and hold teh reset button for 30 seconds while the power is ON then after 0 seconds unplug the power of the router for 10 seconds , then check again if the lights WAN and WLAN lights are still OFF, if its still OFF you can try calling this number for further assistance for this router 1-877-787-8749 so atechnician can walk you through in checking if this router si really bad already or still can be fix....
Oct 16, 2008 | Cnet CWR-854 Router
Smc289wbr wireless could it be a cable problem
re-configure the router properly and get the right details from your isp.(internet service provider)
Oct 13, 2008 | SMC Barricade g SMC2804WBR Wireless Router
DI-624 problem with wireless network
Buy the N router! That is the only solution. My signal weakened and went from the whole home to less than two feet if that at times. I bought the N router and it worked just like the G one did when I first bought it. Ya think somebodies got the limited life span worked out?
Jul 10, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Open Questions:
SMC Barricade g SMC2804WBR Wireless Router Logo
400 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
