HARD DISK CAPACITY PROBLEM
I HAVE RECENTLY BUY AND 320GB IDE HARD DISK OF SEAGATE AND WHEN I ATTACH TO MY PC IT ONLY SHOW 300GB ONLY.IS MY HARD DISK ALRIGHT.AND MY OS IS XP SERVICE PACKAGE 2 .PLEASE HELP ME
  • desire_harya Jan 15, 2009
    Hi !! I got 500GB harddrive..n I format the HDD only one time but now it shows 466GB available space..where is the rest..do I have any issue with the HDD..??
    Scholar:
  • 131 Answers
When your hard disk capacity says 320, that does not mean 320 GB fo free space, Total capacity is 320 GB, from this space required for the partition table, boot sector, etc will be taken, Dont worry only the available free space will be shown.
This is not a problem, so dont worry.
Dont forget to rate me fixya
Posted on Jan 10, 2008
  • M Karthikeyan
    M Karthikeyan Jan 10, 2008
    Sorry melnavz i did not see your post.
    Genius:
  • 1,226 Answers
Yea your hard drive is alright. try to verify the jumper setting that limit the capacity. if ever there is non then hard drive providing only 300 GB instead 320 GB. Don't worry about that.
I have a 4 channel Sunluxy H.264 Network DVR, I have fitted a 300gb HDD but although the system is working and I get the 4 cameras on screen the message I keep getting on boot up is HDD not found
Guys this one stumped me for some time, here is my solution that worked like a dream
1. plug the hard drive you are using into a pc and check the hard drive is recognise and works.
2. Delete all partitions
3. ensure it has a 8 bit cache buffer!! This is the most important one. That means the system only supports older hard drives. I got 2 second hand ones from the local pc store for $50. See the list of hard drives that are know to work below.
MANUFACTURER MODEL CAPACITY ROTATION
ST3320613AS 320GB 7200 rpm
ST33500320AS 500GB 7200 rpm
ST3750330AS 750GB 7200 rpm
Seagate
ST31000340AS 1000GB 7200 rpm
WD3200AAKS 320GB 7200 rpm
WD5000AACS 500GB 7200 rpm
WD6400AAKS 640GB 7200 rpm
WD7500AAKS 750GB 7200 rpm
WD10EADS 1TB 7200 rpm
WD15EADS 1.5TB 7200 rpm
WD
WD20EADS 2TB 7200 rpm
Maxtor STM3500320AS 500GB 7200 rpm
STM3750330AS 750GB 7200 rpm
HITACHI HDT725032VLA360 320GB 7200 rpm
HDS721010KLA330 1000GB 7200 rpm
FYI for some reason the person I bought this off online "Ebay" had no idea how to support and I could not get support from their web site as they email they give just bounces back.
Cheers.
Jan 11, 2013 | Home Security
SEAGATE FREEAGENT GO 320 GB USB HARD DRIVE P/N 9KW2AG-502 320GB SN:2GE7114P THIS HARD DRIVE NOT SHOW IN MY PC SO I REQUEST YOU TO SOLVE MY PROBLEM...... THANKS
Feb 24, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Segate sata 320gb hdd beeping
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Dec 26, 2010 | Seagate Barracuda 7200.9 300 GB SATA Hard...
Hello sir,please help me to solve my problem. i have a seagate barracuda 7200rpm which storage capacity is 320 gb and which have a problem.when i am trying to start my pc it shows boot error,please select...
A bad/faulty lead can lead to a computer not recognizing a hard drive and any other connected devices
One bad lead can cause a computer lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to your hard drive
hope this helps
Nov 14, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
What is the max GB capacity on IDE HD i can use
Hi Good day!! it depends on your IDE CABLE AND IDE CABLE SLOT and of course your PC specs.
1-IDE Cable can connect 2x IDE hard disk so if your board have to slot of IDE Cable it means you can put 4x hard disk. how's that!! ^_^ if your 4x hard disk have capacity of 80gb each that will be 80x4=320gb total capacity of your hard disk installed. by the way what is your Computer specs?
Oct 19, 2010 | ASUS M2N-MX Motherboard
How can i partition my 320gb sea gate ext harddisk
you can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
Jul 22, 2010 | Seagate 320GB FreeAgent Pro FireWire 400,...
What is the maximum size of hard drive for the travelmate 2300
Please keep in mind this unit uses IDE hard drive instead of SATA. The default 2300 uses a 30 GB high-capacity Enhanced-IDE hard disk. With latest BIOS upgrade, this unit will be able to have anything installed. 80GB, 160GB, 250GB, 320GB, 500GB.
However, I believe that IDE hard drives are slowly but surely becoming obsolete and legacy and they seem to be more expensive as well.
May 16, 2010 | Acer TravelMate 2300 Notebook
Usb broke off my seagate 320gb external
it does'nt really matter IDE or SATA both are using same connector. you can change it from second hand or from another board sometimes its not available.
Sep 02, 2009 | Western Digital 320GB MyBook External USB...
Reduced Hard Drive Capacity with Internal to External Kit
Problem can be tricky.. though i offer my two cents.
1. some BIOS have upper limit of hard disk capacity. check that out. try connecting IDE device to IDE connector in same comp and see if it is being detected properly.
2. seagate guys are true .. IDE to usb conversion can be tricky ... a lot depends on card convertor.
my advice would be if you have precious data on it ... first take a backup of it, if possible connecting the disk to nomal ide connector.
Aug 06, 2009 | Sabrent 1 Bay USB 2.0 External Drive Case
Computers & Internet Logo
173 people viewed this question
David Payne
David Payne
