Question about Sony Cyber-shot DSC-W55 Digital Camera
Every time I put the camera on it tells me to turn it off
I was reading input from your website. The black cylinder fell out when I turned camera upside down. I don't know where to put it back in.
Hi Would you tell me more about your camera information? First, the name of camera.. second, lens if DSLR..third, which location of piece you see.---it looks like DSLR... Thanks and best regard! you can skype me at any time after 6pm.
May 23, 2011 | Cameras
Some times my camera won't turn on i charge the batteries but
clean the battary compartment,contacts/battery contact points,if require adjust the contact points.
Mar 24, 2010 | Kodak EasyShare C613 Digital Camera
When I turn my camera on it says "Access" then a message comes up that tells me to "turn the camera off and then on" I have tried this many times and all the camera does is continue to push the lens in and...
This is a firmware problem that is common with many many digital cameras. It will have to be upgraded. The company will do this for $50
Otherwise you may be able to find a kit online and do it which would be hard to located
Jul 20, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Camera window keeps telling me that the camera is not detected
How about try these again
1- Uninstall all of the software related to Canon.
2- Install the drivers for your Canon ONLY.
3- After installing the drivers, plug your camera to a different USB port. (test your USB is working okay by connecting another USB device)
4- TURN YOU CAMERA ON
5- The drivers for your camera will be installed.
6- After it is finished, click start, then computer. Now you should have one Icon starting with canon.....
If you see this icon, double click on it. You will find one or more folders which contain the pictures stored in your camera. You may now download, delete Etc.
You either have not done above steps correctly, or your cable or your USB port is bad.
Good Luck!!!!!!
Jun 12, 2009 | Canon PowerShot A470 Digital Camera
RESETTING CAMCORDER
try getting a new tape or if that doesnt work then i dont know i would get a case big enough for the camera and put the camera and pen in there
Jan 25, 2009 | Panasonic Palmcorder PV-GS9 Mini DV...
Can not finalize the camera to transfer photos
Hi
which make that camera tell me the brand to easy to solve that ok
any way cheek the battery is full charge or try to put new one.
that time not open your disc drive becoz when ever do like this you are lost
old memories images so be careful handle that
south asia camera man association.
Jan 07, 2009 | Sony Mavica MVC-CD300 Digital Camera
Won't turn on
Dear Michibear
Open the battery door , there should be a small button
( right next to SD Memory card on my IXUS 60 )
It tells the camera when door is open & disables power to the camera .Its very weakly made & is responsible for alot of people's problems I have seen so far,including myself !!
The one on my IXUS 60 just magically fell out and landed down the drain whilst I was just changing a battery , and the camera ceased to function. With the button itself gone the copper wire terminals were visible. I used a small pair of scissors and pushed them together and it instantly resumed working, & still does.
I'd recommend using a piece of aluminium foil , or any other conductive material folded up and inserted into the cavity to connect all the copper prongs together.
Im not going to tell you to pull your button out, BUT,
Upon seeing inside it, I'm confident that even when still intact , it'd be really easy for it to malfunction....
May 19, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Wont let me turn on the camera and download my pictures on the computer
yes i have a read time to put my pic on the computer frommy camera help plzzzzdo i have to dnowload anything
May 09, 2008 | Kodak EasyShare C613 Digital Camera
Error problem
hi...i also have this problem showed D:5E02, my suggestion is that turning on camera at the table (camera face on horizontal), don't put camera down/face to the floor when opening.
Nov 12, 2007 | Olympus Stylus Verve / ?-mini Digital...
Sony Cyber-shot  DSC-W55 Digital Camera Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
