Question about RCA TH1602 MP3 Player
MP3 Will not turn on properly. When I turn on the power it will light up but will not load to play music.
Se prende pero luego se apaga
Posted on Nov 17, 2009
The instructions are useless, unit does not work according to their instructions. Have downloaded music, synced the unit, still cannot hear music. Tried everything. Can you help.
All songs must be in MP3 or WMA format in order for the player to load any of the songs to play. If songs are in any other format (MP4, ACC) they must be converted to MP3 in order to work. Instructions are on the Intova website how to convert music to MP3 if needed. If the songs that are loaded onto the player are in MP3 format when you press the play button you should see a yellow indicator light meaning the music is playing. If this light does not come on there may be an issue with the player. If this light does come on but you still cant hear any sound then the headphone wires may be damaged. If there is an issue with the player or headphones manufacturer Intova will be happy to help get you back in the water. Please contact Intova at info@intova.net for further assistance. Thank you.
Sep 27, 2010 | Snap Sights H20 Man MP3 Player
I charged my swimP3 but it won't turn on when disconnected from the computer.
The Swimp3 Player does need to be charged for at least 3 hours for the best experience. Here are some tips that could help solve your problem:
Problem: The player doesn't turn on.
Suggestion: Charge the battery in the player for at least three hours, this will allow it to fully charge. You can charge it by plugging it into the USB port on your computer or by using a USB wall charger (sold separately). If you do choose to use a computer to charge it, be sure your computer is turned on. If there is no power to the computer, then no power is going to the USB port to charge the Swimp3 player.
Additional Tip: The charging answers are in the Green Indicator Light.
If the green light is flashing off and on, then your SwiMP3 player is charging
If the light is solid green, the SwiMP3 player is fully charged
If you have no green light - then it is not receiving a charge - check the connection, make sure its plugged in properly, or check to see that there is power from the computer or USB wall charger.
Problem: I have charged my player, the light is solid green, but no music plays.
Suggestion 1: Have you loaded music onto the player? Try adding a few mp3 or wma files and test it again.
Suggestion 2: If the power is on, you loaded music, clicked the Play button and no music comes out, press and hold the RESET button for 4 seconds. It's kind of like rebooting your computer when it crashes. Many times a simple reset clears up any challenges.
If that doesn't work, then it could be the
* volume
* incompatible files or
* folders
Volume: On some units the factory volume setting is very low.
Solution: Try turning up the volume by pressing and holding the "+" PLUS button. If you click the "+" button it changes the song, pressing and holding the button will actually control the volume. And if its too loud, press and hold the "-" MINUS button to bring the volume back down.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
Michelle
Authorized Finis Dealer
Get Swimp3 Deals at WaterproofMusic.com
May 21, 2010 | Finis Swi MP3 Player
I cant down load music from my laptop to a mps
make sure your usb driver is working properly (plug something else in the drive) if not... reinstall the driver, if it does work, make sure your mp3 player doesnt require software. also ive noticed that some mp3 players are just that... MP3 PLAYERS.. some wont play wma or other file formats.. hope this helps
Mar 07, 2010 | Aspire Acer 53152826 Notebook
It keeps saying file error
Check the format of the music you are playing and if you have music that requires the license it will load the music but not play. It will show up as a file error.
Feb 28, 2009 | Coby MP300 MP3 Player
It will not play my music
my ipod turns on, i can see the video but i cant hear the music
Jan 03, 2009 | JBL On Stage II with Remote Remote Control...
Won't play back and is no longer recognised by my computer
Problem solved with my jensen SMP-1GBD MP3 player. I re-examined the instructions & followed them exactly as they were written, then the unit worked just fine. What I found out was that you first have to plug in the ear phones, then you have to hold down the "on", button for three full seconds before it will turn on. It was just a case of not following the proper procedures as written on page four under the "Power on/off ", section of the directions.
Dec 31, 2008 | Jensen SMP-115 MP3 Player
Have a digital camera/mp3 player 44090/44091/44092/44093 have installed software but when we plug it in to usb slot doesnt register on comp. cannot transfer music etc. running windows vista please help...
I have fixed our problem! Hope this helps you out. I downloaded a manual for the 44090 model.
Make sure that you don't have it plugged into the usb port and the player is switched to mp3 mode. Open the software and then when it says to plug it in now, you need to turn the player into music mode. Press and hold for 3 to 4 seconds the centre power/play/pause button. It will start the red light flashing. Once the light is flashing it is in music mode. Plug in to the usb port and the computer should recognise it bringing up the install now button for the software. Click 'install now' and it should work.
I don't use the software to load songs I just use windows media player and once I had passed this install now bit media player recognised it instantly.
Everytime you want to listen to music you need to put the player into music mode by holding down that button till the red light flashes. Once music is loaded on it starts playing as soon as that red light starts flashing!
Good luck and I really hope this works out for you too.
Dec 15, 2008 | Audio Players & Recorders
Apple iPod Shuffle 2nd Generation Not working
I plug it in to my computer, and I-Tunes does't finds it, I was unable to load music
on it and I get the green light saying it is charged. But when I take
it off the computer, I get lights for two second and it will not turn on or play
music at all. Any suggestions?
Apr 08, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Zen stone mp3player....works but wont let me play music..
Here are a couple suggestions. Did you load music on? Do you have headphones in? Tried turning up the volume?
Feb 18, 2008 | Creative Labs Zen Stone Plus MP3 Player
Coby 256MPAudio player
Try reseting the mp3 by fomating it from the computer. and load the songs on again. it might work
Dec 31, 2007 | Coby MPC-848 MP3 Player
RCA TH1602  MP3 Player Logo
115 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
