Question about Hotpoint WMA74 Front Load Washer
We have a Hotpint WMA74 - water gusting out of powder/liquid compartment at top when spins - have changed drain pump - but still happens - can you help?
  • Hotpoint Master
  • 3,463 Answers
It sounds like you have a partial blockage somewhere..
Remove rear panel.
Remove large black hose onto drum.
Check and clean filter inside hose.
Remove drain hose, and check for restriction here as well.
Please rate my solution.
Thanks.
Posted on Nov 17, 2009
Testimonial: "Spot on!!! you were 100% correct - thank you very much"
    Genius:
  • Hotpoint Master
  • 1,467 Answers
Yes hope so you must also clean the filter it is located in the sump hose @ bottom of drum....
Fabric Softener Does Not Drain
compartment 1: Detergent for pre-wash
(powder)
Before pouring in the detergent, make sure that extra compartment 4 has been removed.
compartment 2: Detergent for the wash cycle
(powder or liquid)
Liquid detergent should only be poured in immediately prior to the wash cycle start.
compartment 3: Additives (fabric softeners, etc.)
The fabric softener should not overflow from the grid.
extra compartment 4: Bleach
! Do not use Hand Wash Detergent because it may form too much foam.
Cleaning the detergent dispenser
Remove the dispenser by raising it and pulling it out (see figure).
Wash it under running water; this operation should be repeated
frequently.
25569074-ineink0kisfnom0atbkujjcx-3-1.jpg 25569074-ineink0kisfnom0atbkujjcx-3-3.jpg 25569074-ineink0kisfnom0atbkujjcx-3-6.jpg
Dado
Mar 14, 2015 | Ariston Technologies AW125NA 13 lbs. Load...
Water not drane setisfewctori Cloth not dry
There are 2 possible reasons for this .The drain for the washer may be kinked at the back preventing the water being pumped out . The pump is virtually a water circulator and not a pressure pump so any obstruction will keep water in the washer.. Next --the spin cycle may be to slow for the water to be spun out of the clothes. Check the load is not above the recommended weight as this makes the spin cycle slow. IT is better to do 2 washes rather than to cram it all into 1 wash. Check the filter at the pump as they tend to block up with lint and other gunk from the clothes and the water may be unable to get to the pump Powdered detergents are 90% clay( fine as talc powder and used to carry the detergent) and this settles out in the lower parts of a machine so if you use powder I would recommend changing to liquid
Mar 11, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Drum will not empty
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 28, 2011 | Hotpoint WMA74 Front Load Washer
Upper tray doesn't clean, lower tray is fine. Also, lot of soap sticks in the soap compartment after the cycle. Thanx.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Jan 31, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
Washing machine not draining the water
the weater pump is bad replace....
Apr 13, 2010 | Neff W5340X0 Washer
Hotpoint WMA74 does not pump out after programmed
No test available other than:
Remove pump - check motor will turn by rotating impellor. There is a slight resistance then moves freely, then slight resistance and freely again. This is correct for this machine. worth checking there is no hair, elastic band or other obstruction around the impellor fins and shaft whilst the pump is out.
There is no spin cycle so you have to use rinse & spin, which means if the pump is shot you need to empty the machine each time :(
Worth checking lower filter as stated and blowing down the drain hose whilst the pump is off to check for obstructions.
The resolution to my problem was a new pump - £20.
All working fine again now !
Jan 24, 2010 | Hotpoint WMA74 Front Load Washer
Top loader washing machine no drianing water
run the machine with a lime scale and detergent remover such as soda crystals on a boil wash no clothes or powder .
what happens is the powder or detergent if u use to much i does not disolve properley and gunks up the pump and filters they have a detergent and limescale remover on espares
Jun 28, 2009 | Washing Machines
HOTPOINT WMA74 WASHER WILL NOT DRAIN WATER
Washing does not drain, instead water comes gushing out of the detergent tray at the top.
Jul 19, 2008 | Washing Machines
Wahing machine kitchenaid won't completely drain water
Check drain pump for any blockage.Pump accessible by removing lower panel,on bottom front of machine.Also try liquid instead of wash powder,and make sure that you are using automatic powder as other will foam in machine.
Apr 01, 2008 | Indesit W 123 Front Load Washer
Water in Fabric Softener Compartment
As for the softener compartment, powder tends to overflow and block the three drain holes. It needs removing and thoroughly cleaning out, i use cotton buds and lots of hot water.
Dec 18, 2006 | Zanussi FS1455W Front Load Washer
Hotpoint WMA74 Front Load Washer Logo
186 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
