Question about Nokia 7610
I have nokia 7610. My mobile remain on only for 2 seconds and then restart. I have so many important contacts details in it.i have been told by some mobile mechanic that softaware of my mobile has damaged and all data would be washed out if new software get loaded in my cell. You are requested to kindly guide me how i can recover my contacts details if software of nokia 7610 has damaged and cell get restarted again and again?
Need 15 digit IMEI for nokia 7610 supernova and my phone is locked
Hi you can use codes to unlock the mobile .to get the unlock codes visit here
mobile-unlocker
Here they ask the following details before rendering the unlock codes they are
1. Mobile model
2. Country from where you brought the mobile
3. Provider to which the mobile is locked
4. Imei number of the mobile
Finally they will send you the unlock codes .once
you entered the code in your mobile as for the instruction
given by them .your mobile get unlocked and it accepts any network sim.
Aug 23, 2011 | Nokia 7610
I HAVE FORGOTTON THE CODE OF WALLET, HOW CAN I RESET IT,PLEASE HELP ME
Hi
Note : Please take the backup in your mobile (Contact, Gallery, and remove the Memory Card0
Easy to format yor wallet Nokia 7610, download the nemesis 1.4 software and Install in your PC, open nemesis software and now connect your mobile and your mobile screen is show 3 option now select PC Suite option,
The Nemesis also detect your mobile. Now click the device info.
Then click the flash, Now select the mode option (Red & Green)
first u select you see down option after flash and click the Reset -Full Factory, and upload, take earth 2 min your mobile will restore and restart automatically now put the date and time in your mobile and enjoy that
May 11, 2011 | Nokia 7610
Nokia 7610 phone memory formatting manualy
You can format your phone by two methods
first method:
1) press *#7370#
2)enter your security code(note:default code is 12345)
3)restart your phone
second method:
1)switch off your phone
2)press power button,press and hold *key,3key,green call button
Dec 07, 2010 | Nokia 7610
7610 i forgot my password
hi there is simple method if you forgot the password switch off your mobile phone and restart it again by continuosly press the key star button,callbutton and button 3 for 3 seconds then the phone will automatically unlock.
Aug 28, 2010 | Nokia 7610
Phone startup failed Contact the retailer.Nokia N91
Problem: Nokia 7610 startup failed contact the retailer
Solve: You Need to format your mobile and this is the way
First of all Turn Off Your Mobile Phone
[ format = power + press & hold call + * + 3 ]
Jul 19, 2009 | Nokia N91 Cellular Phone
I have a nokia 7610, some message is coming in outbox pls find the solution for it
JONYCHEMIST FORMAT PHONE MEMORY BY THIS WAY, To format nokia 7610 phone memory follow the steps: 1. Switch off ur mobile. 2. Press *,3,green buttons together 3. Now switch on ur mobile. Press these buttons till you notice a formatting screen on ur mobile Note : Make sure that mobile is fully charged & transfer all the important files, messages, contacts to memory card. bye dis is JONYCHEMIST
May 04, 2009 | Nokia 7610
Bluetooth
I think you need to restart your handset once. Then check if problem persists.
Jan 09, 2009 | Nokia 7610
How to format phone memory
format using "" *#7370# "",.,.,.,the phone wil restart
attacked by any virus? ya ofcorse
Aug 31, 2008 | Nokia 7610
Not working
RESETTING PHONE BY NOKIA SECRET CODES (steps 1 and 2)
1st step : SOFT RESETTING NOKIA MOBILE
Take backups of ur phone books,calender and others, then simply enter the code
*#7780#
2nd step : HARD RESETTING BY CODE
Just enter the code-
*#7370#
Then it asks for security code enter ur security code whose deafault value is 12345
NOTE:
The battery must be full or the charger has to be connected to the phone so that it does not run out of power and make the phone unusable.
Take backup of the contacts and other important data in MMC .
FLASHING
3rd step :FLASHING : ANOTHER METHOD FOR HARD FULL FORMATTING
This step is known as flashing of phone. Always do this step at last (after 1st 2 steps are over and u are not successfull)
1. Make sure you phone is fully charged. (At minimum 3/4 of bettery should be left)
2. Backup your contacts list and personal files to MMC memory card (if possible).
3. Switch-off your mobile phone.
4. Press and hold these three keys together
-Green dial key,-Star key (*)-Three key (3)
then press the power on/off to swtich on the 6600 phone.
Do not let go the three keys until you see the “formatting” screen displayed
5. After a few minutes, the format will be complete. Your mobile will now be at its original factory settings (It will reach the same state as that in when you purchased it)......................enjoy
Regards :
dilipbagdi
Technical Associate
Apr 01, 2008 | Nokia 7610
Restarting nokia 7610
dear
you have to do the manual format.press *, 3,call button and now switch on the handset .keep pressing for few seconds upto the message comes "FORMATTING" then release the fingers .but you will loss the data.try this
Nov 23, 2007 | Nokia 7610
Nokia 7610 Logo
47 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
