When we turn the heater on you hear something turn on but sometime it doesn't blow any air out. If we turn it off and on a few time we can usally get it to work. When tries to turn on again when it reaches below the set temp. its sometimes does work and sometimes not. Do you know whats going out possibly?
  • 4 more comments
  • wildcat1828 Nov 17, 2009
    Its the central unit that sits on top of the house. It runs off gas for the heater part and electricity for the a/c part
    The heating the ac part works fine
    do you need to know the brand will that help?
    We are hoping my husband can fix it. When he gets home for lunch I will have him get of the roof and get the brand and modle number
  • wildcat1828 Nov 18, 2009
    it is a Amana model PGA30R0452A
    The MFG is P1164604C
  • 11,896 Answers
Sounds like a relay clicking but not activating. You can test it with an ohmmeter to see if it is good or not. You can check power to the motor itself with a voltmeter if you'd like to see if the power is getting cut off at the power supply.
Posted on Nov 18, 2009
    Sergeant:
    Novelist:
  • 174 Answers
What kind of heater is this? A gas furnace, portable plug in space heater, gas fireplace, etc...
Posted on Nov 17, 2009
  • 3 more comments
  • Brandon Undeberg Nov 17, 2009
    I'm assuming that this is probably a space heater with a thermostat control on it. My guess would be that the thermostat wires are loose or have a bad connection in them. The noise you hear is probably the heating elements turning on, it should then automatically turn on the fan when those get power. There is probably just a loose connection. I would check those first, sometimes the soldered connections get loose. Let me know what kind of heater it is though and I can try to get a better answer for you.
    Is this question about the heating portion of it or the a/c portion of the unit?
    OK, with a gas furnace of any sort there's usually a pilot light, when your thermostat gives the signal to the furnace that heat is needed it will open a valve that allows gas to flow to the element. This usually flares up and heats for a bit before the fan kicks on. There will be an internal thermostat of some sort that will tell the fan that it's time to turn on. If your fan kicks in sometimes I would think that there is some sort of problem with the communication between the fan and thermostat. Are you going to fix it yourself or hire someone?
    yes with a brand I can possible find a wiring diagram
  • Brandon Undeberg Nov 18, 2009
    Follow the wires back from the fan to the relay, or internal thermostat. It will usually be a small box, usually black. This is not a super expensive part. Just make sure if you have to cut any wires, that you use good ends to splice it back in. I would recommend soldering it back together with a solid solder wire and flux, no flux core solder. This is corrosive and will eventually cause a big problem. Any heating place will be able to order your new relay. I couldn't find a wiring diagram for it. Sometimes on the back of the inspection cover they will have a permanent wiring diagram.
My heater blows cold air 85% of time
You got a bad heater door module most likely or the door itself may have issue.
Jan 08, 2015 | Cars & Trucks
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
I replaced a carrier standard programmabe therostat model number TSTATCCSAC01, there are five wires from the wall that lead to the thermostat, the thermostat wire receptacle is labaled: Y C R G W O.
Need more info, Wire colors; to see if the installer used tstat wire, also what kind of system yo u have. I'm guessing you have Boiler/furnace and cooling. If so, and I don't get back to you in time, try this.
If you can open the acess cover on the heater and look at the transformer( it usally has a slight hum to it). Look at the color wire. Also if unsure, that cover you just removed, turn it around, it will have feild wiring or low voltage wiring makings on it. That is the t'stat wiring. Just match them up with the t'stat. The R/RC is the hot from the transformer( usally red in color) . The C is the common from the transformer(usally black in color).Note, this was used most of the time for t'stat power. may not be needed for new tstat if it's battery powered. The W is used to turn the firing on( what ever your flavor is) (Usally white in color). The G is the indoor fan (usally green, sometimes brown in color). The Y is used to turn the outdoor condensing unit on(cooling) (This wire is usally blue or orange, sometimes yellow). The "O" is usally used for a changeover valve usally only on heat pumps. Most of the time on t'stats you willl have O/W markings, but the way you listed it, you have a seperate connection for it, odd.
SO, before you start, turn power off to indoor and outdoor units. Indoor unit, most of the time, will have a light switch mounted on the side of unit or above. Some places call for the switch to be mounted at the enterance of the area where the heater is. The sould be marked with a red switch cover. If unsure, follow the wire (romex, or metal sheilded) powering the heater. Then go outside by the condenser, you should see a box mounted adjacent to the unit,open it up and pull the disconnect out.
Take your time and look at the wiring detail on the heater, and match the wires. THIS DESCRIPTION IS NOT FOR A HEAT PUMP SYSTEM. This is only for a conventional system. One heat, one cool.
After you've connected all the wires, Turn t'stat to off. power up all units.
Then
Turn to t'stats fan to on. You should hear the fan go on.
Then
set fan to auto, and set t'stat to heat and set it to higher temp that room temp. Listen for ignition,
Then
listen for fan. Fan may take a few mins to turn on due to heat exchanger comming up to temp.
Then,
As long as it's not below freezing ouside. switch to cool, then set t'stat below indoor temp. see if outdoor unit and indoor fan turns on. You will not harm compressor doing this for a short time.
Good Luck!.
Mar 04, 2013 | Heating & Cooling
Heater unit doesn't blow any air
If you have no air blowing out it sounds like the blower motor has quit
Dec 28, 2012 | 2005 Jaguar Vanden Plas
I have a Toyota Highlander 2001 When i turn the heater on the red it will blow cold air?
have any coolant leak repaired lately?sometimes it is very hard to get the air trapped in the cooling system out.also there is something called a air blend door motor/valve under the dash.if you move the control from cold to hot you should hear something moving under the dash.
Oct 07, 2012 | 2001 Toyota Highlander 3.0
It keeps over heating after putting on a new water pump and thero and there no holes in the hose
check for water locks by draining and catching water from bottom pipe.then refill leaving top pipe off bottom on then check the difference in the amount of water lost to refill if u get me!
Jun 11, 2010 | 1997 Pontiac Trans Sport
2004 Corolla - A/C and heater problem!
the blower motor could be on its way out other possibility's is a loose connector.
Aug 12, 2009 | 2004 Toyota Corolla
Heater in 1984 Bronco blows cold.
There may be a few reasons for this - just check them all in turn.
  1. Low coolant - Check your expansion bottle.
  2. Airlock in heater matrix - Can you hear trickling water sometimes, have you changed the coolant or had to top-up? - Bleed the air out through bleed valve or loosen a hose while engine is running.
  3. Faulty heater valve. This can actually be the link to control the heater valve rather than the valve itself. - How does the hot/ cold switch feel? - is it very loose ? Sometimes the valve gets stiff, and the next time it is moved, the control wire snaps. Often the valve needs replacing and the broken link to cure it. Not a major expense - just fiddly to do.
  4. Blocked heater matrix - from using radweld or similar quick-fixes. Replacement is better than flushing.
Jan 05, 2009 | 1984 Ford Bronco II
Heater blows cold air
With the car warmed up,feel the heater hoses,are they both warm/hot near the firewall in the engine compartment?If they are both warm/hot,then the heater core should have circulation through it and it may be a "blend door" issue in the heater a/c assembly.If they are not warm/hot then the heater core could be dirty and plugged up and needs to be flushed.
If the above does not help,a drain and vacuum of the cooling system and vacuum refill will remove any trapped air.
Sometimes,clamping off the top rad hose and holding the engine rpm at 2000 rpm will force trapped air out of the heater core.(Watch temp gauge when trying this)
Lastly,a NEW thermostat doesn't mean its working correctly.
May 18, 2017 | 2005 Lexus SC300
Heating & Cooling Logo
117 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
