Question about General Heating & Cooling
Legacy propane space heater mod# rmc-lc30lptf, the pilot seems to burn very rich is there an adjustment?
  • 41 Answers
SOURCE: We have a model VP1600E Propane Space Heater
Not sure I can help but will try. Sounds like you have a blockage in the pipe or jet and when it heats up it is choking. Best way to clean Propane and/or Gas heaters is to blow compressed air through the pipe. You may be able to just blow the air down the pilot light and main jet and it could fix the problem and clear the jet.
If not you will need to pull off the covers to expose the piping and look for the pipe going to the jet or pilot and if you can undo the pipe and blow compressed air through it. You may find a bit of dirt or carbon is causing the blockage. If you undo any pipes make sure you tighten them back up. Hope this solves your problem.
regards
Bryan
Posted on Mar 11, 2008
SOURCE: COMFORT GLOW PROPANE HEATER, THE PILOT LIGHT WILL NOT IGNITE
i vacuumed the line out, i taped the angle adapterso there was only a little bit showing and stuck it on the pilot hole for 3 minutes (I turned the gas off) and it fixed it
Posted on Jan 21, 2010
  • 17 Answers
SOURCE: My glo-warm propane heater keeps shutting off automatically-pilot and all.
Clean the pilot and if that does not help replace the thermocouple. Also make sure you have correct ventilation to the room as that can also cause this type of heater to shut down.
Posted on Nov 18, 2008
  • 24 Answers
SOURCE: Pilot will not stay lit. No instructions or parts catalogue
home depot
Posted on Sep 30, 2009
SRF518
  • 232 Answers
SOURCE: Dyno-Glo propane heater Model RMC-FA100DLX. It
find the thermostat and jumper out the two wires if it shifts into high heat, replace the thermostat.
Posted on Oct 26, 2009
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Have a rmc-40lpt when i lite the pilot flame burns bout 12inches high an wont lite the barwhars wrong
have yuo adjusted pilot flame to just engulf thermocouple 2/3 of its length?
Oct 28, 2013 | Heating & Cooling
I have a Dyna-Glo RMC-50LPT propane heater that is about 5 years old and I can't get rid of the yellow flames when it operates. I have tried: - removing the heater and blowing everything out with a...
Dennis easy fix what is your out going gas you will need a manometer to verify it accurately or adjust your gas valve til your blue flames are gone. Let me know what you find!
Dec 16, 2010 | Heating & Cooling
Pilot flame burns above pilot tube in propane heater. the sensor does not register. the pilot top of the tube shoul glow red. I have cleaned the tube, in few occasions it has lit and worked for above 10 to...
Hi it there a leak on the pilot causing it to burn that high can you adjust the pilot gas going in to the pilot ?
have you cleaned the pilot injector out or is the hole in the injector too big
Jan 25, 2010 | Williams 2509612 Ceramic Mid-Size Heater
I want to connect the unit to the main propane
First of all I am only concerned with your safety when I ask you to only have a qualified service tech install this heater for you. PROPANE is very dangerous if you aren't well trained in the operation/installation of gas fired equipment.Natural gas isn't quite as dangerous as it is lighter than air and will dissipate easier. Propane is heavier than air and will pool in the lowest spaces and collect there. To answer your question, yes most regulator can be adjusted, but again only by a qualified service tech because he needs to adjust the gas pressure to the equipment rated gas pressure specs. Again I am only concerned for your safety.
Nov 28, 2009 | Dyna-Glo RMC-8001SS Heater
I have Legacy ventless propane heater 15,000btu.
Try to take pilot assembly apart and clean real good. This will work most of the time. If it does not work for you, you will need to replace the gas valve. It's expensive but I'm about positive that cleaning it will fix it. Gas burns dirty and after a couple seasons a scale builds up that causes this problem. It's pretty common and nothing to worry about after it's cleaned. Good luck.
Oct 17, 2009 | Dyna-Glo Heating & Cooling
Propane convection heater won't maintain full flame
Seems like the valve is not opening up fully or the adjustment is out of adjustment. Try adjusting the flame.
Feb 15, 2009 | Mr. Heater Mr Heater Portable Buddy...
How long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
Jan 18, 2009 | Dyna-Glo RMC-8001SS Heater
Heating & Cooling Logo
746 people viewed this question
Top General Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Bill Long
Are you a General Heating and Cooling Expert? Answer questions, earn points and help others
