Question about Nokia N70 Cellular Phone
My phone keeps coming up to offline and when i set to general it says insert simcard which is already in phone.
My phone is N95.it shown the offline mode bt when i changed the profile and select the general profile after that it does not work.pls help me how i can open my phone lock..........
This is not a lock.This problem occurs when Sim card IC is damage,Sim Case damage.But one thing you can try is Clean the sim Case and Sim card.Insert the sim and switch in the phone .If the problem still persist Contact mobile repairing shop.Good luck Thanks
Jul 25, 2011 | Nokia N95 Cellular Phone
My 6720 nokia phone has gone into offline mode and can not get it back online can you please help as this is a company phone, i have tried taking sim card out, and memory card out, still does not work
This problem occur when the phone gets dropped on a high place, water damage or setting on your mobile is changed.
Please follow this basic solution :
1. with the sim inserted on your phone, go to profile and select GENERAL. might you accidentally set your profile to offline mode.
2. check the simcard socket if its clean or well align,might corrosion is the problem that's why the sim fails to recognized.
3. Also clean the simcard itself using an pencil eraser.
4. align the battery terminal,might the power supply is not sufficient if the ground (middle terminal) doesn't reach the battery interface. as well as clean the battery connector.
If the above method doesn't work,consult a mobile service center for assistance,maybe the sim IC or some components related to insert sim problem maybe damage.
Good luck...
Jun 22, 2011 | Nokia 6720 Classic Cell Phone
MY PHONE HAS BEEN SHOW ON SCREEN OFFLINE . MY CELLPHONE CANT ACCEPT ANY SIM CARD SO DO NEEDFUL
Here are the following guidelines.
1. Insert your sim on your mobile, try to go to your profile and choose general then wait until the signal and network will comes out.
2. Try to check your simcard socket pins if its clean and align,as well as clean the simcard using an eraser from pencil or any.
3. this will turn into a hardware fixing cause might the simcard ic is damage or connected parts related to simcard reader,and with this,you need to visit a mobile service shop near you.
good luck.
Jun 21, 2011 | Nokia N70 Cellular Phone
Offline 5230 t mobile
Try this method ma'am :
* Try to check if the simcard is properly inserted.
* Go to profile and change the settings to general etc.
* Resetting the phone may helps too. just type *#7780# and the settings will be back in default (no data will be erased.
* and lastly,if the above method doesn't,consult a mobile repair shop for assistance.
hope this solution helps...thank you for visiting Fixya.
Jun 12, 2011 | Nokia 5230 Cell Phone
My nokia 5230 shows `offline`. when i go to profiles and select `general`, it says `insert sim card` but it is already inserted. i have reinserted sim card, but that doesnt work. HELP
Your phone is not openline, meaning its locked for one network only. You must go to phone technician to unlock your phone, and convert to openline, in that way you can use any simcard for your phone. thanks
Jan 09, 2011 | Nokia 5230 Cell Phone
PHONE IN OFFLINE MODE . hOW DO YOU CHANGE IT TO on line mode
Ok let me give you solution about this problem....
Offline mode is the mode in cell phones which barred your every calls sms and even your internet connection simply you can say that...
It stops all of your connection......and you can use only those things which do not need the connection or network.
So to deactivate this offline mode their is two way
1. You can restart your phone after inserting sim card and if the sim card is in good condition and readable then the cell phone will ask you wheather to continue in offline mode?
Just press no that is upper right button of your cell phone and it will be deactivated.
2. Just press on/off button gently and it will show you profile i.e. to select mode
General, silent, meeting etc. you can select any of them except offline mode.and again it will be in normal mode.i hope that it will help you,
By: Neuron
http://www.digixtream.blogspot.in
Jun 15, 2010 | Nokia E51 Cellular Phone
How do i change my n95 from offline mode
hi my n95 phone is in offline mode, when i select the general profile the massage is shown on the screen insert sim card.please help me how i can change the offline mode
Nov 11, 2009 | Nokia N95 Cellular Phone
Nokia N70 Cellular Phone Logo
19 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
