Question about Jeep Radios: Genuine Am/Fm/Cd with 3 band equalizer.
How do i set the radio stations on my 2001 jeep wrangler
CRTN
  • 716 Answers
SOURCE: How to set radio station memory for jeep cherokee 2000?
Go To The Station You Want In The Memory And Press And Hold The Number You Want It On.
Posted on Jan 12, 2009
  • 82 Answers
SOURCE: How do I set my radio stations?
Manually turn to the station you are wanting and hold the number 1 button you wish that station to be on until it blinks and or makes a beep sound. then manually turn to the next station and hold down the number 2 button til the screen blinks again, and so forth.
  • 328 Answers
SOURCE: 1998 Wrangler Sahara - radio not recieving low freq FM Bands
if you are receiving stations on the higher frequencies then your radio is the problem and not your antenna or anything else
Posted on Jan 15, 2009
  • 13 Answers
SOURCE: reset stations on jeep wrangler 1999
If we are talking about your radio, dial to the station you like then push and hold on the button you want until you hear a beep. The stion you like will be on the button you selected.
Posted on Aug 03, 2009
  • 149 Answers
SOURCE: 2001 Jeep Wrangler HP loss
1. did you put oversized tires on the vehicle, if so that changes the gear ratio and will result in power loss,
2.. the catylitic coverter is plugged, often the coverter breaks apart and the pieces find there way to the outlet pipe and restrict exaust flow .
3. a fuel pump probem, low fuel presure under a load, however this condition will make the eng run lean, and most likey set a check eng light,
Posted on Oct 18, 2009
How do I set the time on a 2000 Jeep Wrangler sport ?
open glove box read operator manual(radio 1,2,3,4,?)
is this RADIO time of day
or to time cam ?
or how to time spark.?
"time ' means nothing,really lacking other nouns'
Feb 09, 2017 | 2000 Jeep Wrangler
Where is the resister bank on a 2001 jeep wrangler sport
we cant guess,, TJ jeep
is this an HVAC question? heater?
my wild guess is its the heater blower resistor block.
its same on all cars, (its air cooled is why) it mounted to the blower casing.
FSM book, chapter 24 covers this. page 25
jeep calls them resistor wires.
see TJ, jeep 2002, here, page 25 and do defeat air bags first or be injured.
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
if blows on high ok but not other speeds, see here.
Mar 28, 2015 | Jeep 2001 Wrangler Sport
2002 X Jeep Wrangler radio won't work CD still comes in and out but nothings plane
all features dead? only the eject and insert works
radio dead, AM and FM?
does dial light up, and show that search stations scans and stops
on a station, (regardless of sound or not) if not ? all that is dea check fuses.
if fuse are good, its a bad head end.
time to upgrade to media center, no?
Nov 12, 2014 | 2002 Jeep Wrangler
The lights under the dash (by your feet) stay on (2001 Jeep Wrangler). What fuse is that or what to do?
join a wrangler forum find it by googleing wrangler forums or try 2001 jeep wrangler fuse layout
Feb 06, 2013 | 2001 Jeep Wrangler
Clock in radio will not display or radio station number will not display on my 1999 jeep wrangler am/fm tape player. radio only displays the numbers 1 thru 9. the radio and tape player both work.
I won't sware this will cure yours but I took the front cover off mine and where the little metel slot things plug into your radio i took some steel wool and cleaned and shined them up. The cover should come off by gently prying on the ends. Mine even had a spring that when you pushed on it it poped out a little. But becareful not to pry to hard. If it won't budge the get someone who can help you pull it off. You should see the metel contacts that almost look like you could take it out to prevent theft of the radio. Let me know if this helped. Just a guess mind you. Please no bad marks, Good Luck, Raz
Apr 17, 2010 | 1999 Jeep Wrangler
1998 jeep wrangler radio wiring
my radio is only getting one radio station in each town that i go threw
Apr 10, 2010 | 1998 Jeep Wrangler
2001 Jeep Wrangler makes whistling sound except when you accelerate. Everytime you put your foot on the gas, it stops....take your foot off the gas and it whistles
if you have an aftermarket intake on the jeep the throttle body is making the whistle... there are many aftermarket throttle body spacers out there that can eliminate this...
if you dont than I think that we have the same problem... might be a vacuum leak if the jeep idles funny or it could be an exhaust manifold leak... I'll let you know if I figure out mine. :)
Oct 03, 2009 | 2000 Jeep Wrangler
Reset stations on jeep wrangler 1999
Jul 22, 2009 | 1999 Jeep Wrangler
Jan 13, 2009 | 1998 Jeep Wrangler
Jan 12, 2009 | 2000 Jeep Grand Cherokee
Car Audio & Video Logo
104 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Kevin Daniels
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
