Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
My Oster A5 twin-speed clippers lost power half way through grooming a dog there was also a slight burning smell. I'v cleaned out the fur from inside the body but its made no difference?
  • Hot burning smells are usually associated with the armature but without checking its hard to tell.
  • 448 Answers
The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device (if they are worn, they should be replaced. They, and the Bakelite gear, are available from various dealers through Amazon under Oster Parts). The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). Check it for worn or missing teeth.
If you don’t have a tube of oster grease, a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The small pads on each side of the lever (in the case) are oiled, not greased.
The bearings for the Oster are sleeve bearings that require oil (the one closest to the blade is served by the oil port; the little round chrome looking thing with the spring loaded ball in it). The other end is more difficult and would require disassembly, at which time it probably should be replaced.
Oster clippers, by the way, are known for getting pretty warm. Oster blade wash will help with that, as well as oiling the blades.
Hope this helps you.
Posted on Jan 30, 2010
  • 61 Answers
Bushens inside, i can replace
Posted on Jan 19, 2010
How do I change the blade?
There is a small button at the bottom edge of the blade, push it in and at the same time push the blade teeth away from the clipper. The blade will hinge away from the clipper, you then lift the blade up off the tongue. When fitting another blade pop it onto the tongue, turn the clipper on and snap the blade shut.
Mar 31, 2015 | Oster Turbo A5 2-speed Dog Pet Clipper...
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Jun 21, 2014 | Oster Turbo A5 2-speed Dog Pet Clipper...
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Feb 06, 2013 | Oster A5 Turbo Clipper Kit-10,40 Blades&5...
Oster clipper
It sounds like a faulty motor if they are under a year old send then back who you purchased them from otherwise it could be a costly repair.
Dog Clippers
Jan 15, 2013 | Oster Grooming Golden A5 2 Speed Clipper &...
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Aug 03, 2012 | Oster Golden A5 Single-Speed Clippers
I have a brand new set of Oster A5 model #78005 clippers. We own two large dogs--we cliipped the first one and it worked beautifully--we were about half finished with the second one and all of a sudden...
I'm sorry if this sounds academic, but regardless of whether or not the problem lies with the clipper or the blade set itself, since it is brand new, return it to the seller.
Apr 09, 2011 | Oster Golden A5 2-Speed Universal Motor...
My oster A5 2 speed will cut for short time and than won't go though my dogs fur. It's like the blade lifts up and is not tight on the clippers. I have had these clippers for three years and have had no...
make sure the blade clicks into place and cannot be removed without depressing the release latch, secondly check the two screws are tight either side of the hinge assembly, faults in either can cause this fault.
Dec 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
225 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
