Question about HP iPAQ HX4700 Pocket PC
HP iPAq HX4700 wont sync
My iPaq no longer will sync with either my home or work pc. I have done both a soft and a hard reset, neither of which have worked. It appears that activesync on my pda is not working. My cradle is ok as I've checked this out with a colleagues pda. Which will sync with my work pc as a guest. Is it Active sync on my pda that is the problem. Can you help?
  • fred bloggs Apr 01, 2008
    Never had a problem before but all of a sudden when I plug it in a message comes up that says USB device not recognized.
    It is doing it on both my laptops one on vista and one on XP also doing it on both sync cables I have
    has worked fine for years so the problem must be with the PDA
    Done soft and hard reset
  • 589 Answers
This is a VERY common problem with these, and HP is aware of it.
You can try these steps as per HP:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=420534&prodTypeId=215348&objectID=c00595366
Posted on Jan 11, 2008
  • brian c
    brian c Jan 12, 2008
    Why the rating?
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
Hx4700 wont work after failed update on ROM v1.10
Try hard reset: pressing and holding the calendar and iTask buttons and doing a soft reset for 2 seconds.
Hard resetting a WM 5 HX 4700 is to press and hold the Contacts and Mail buttons and then doing a soft reset. The boot screen will popup with a message “To perform a clean reset, which will clear all data in memory, press the [Calendar] button”
If that fails, try upgrading to wm 6 or wm 6.1 then downgrading afterwards.
I've upgraded from wm2003SE to wm6.1 alkor rc2.2 rom.
ROMs: http://wm6.winmobile.us/hpmain.htm
Jul 15, 2009 | HP iPAQ HX4700 Pocket PC
My HP iPAQ hx4700 Pocket PC will not start up. It
Slider switches ok and pointing at the right place in the bottom?
1. Main battery possibly needs replacing.
2. Replace backup battery..
http://www.youtube.com/watch?v=cYwc_-ISnsA
Jul 13, 2009 | HP iPAQ HX4700 Pocket PC
IPAQ 4700 hard resetting on its own.
I also own an ipaq 4700 and experienced the same problem. Even after reloading the OS I continued to have this problem. I did buy it refurbished but I fear this may be a common hardware problem. From my research it would appear the battery is the most likely culprit, I have not tried replacing mine but it may be worth a shot, if nothing else you have an extra battery which means less time at the charger :D
Apr 16, 2009 | HP iPAQ HX4700 Pocket PC
HP Ipaq 4700 stylus problem
ask HP yet, we are not HP , sorry and this thing is legacy retired product , what good is it?
here is the real HP forum
see if you can get tears there.
https://h30434.www3.hp.com/
Dec 02, 2017 | HP iPAQ HX4700 Pocket PC
My hp ipaq hw 6515
Try soft resetting your ipaq. If that didnt work then try hard resetting it, note that you will lose all the data in your ipaq
Oct 23, 2007 | HP iPAQ hw6515 Pocket PC
Do I have to hard reset after pc-break down
No!!!! ROM-update currently in ROM !!!!
Sep 14, 2005 | HP iPAQ HX4700 Pocket PC
Ipaq hx4700 dead :(
I would try a hard reset before you resign yourself to HP repair.
Hx4700
You need to sync the old one with your PC, then simply set up a new partnership with your new Ipaq and sync it with that same PC.
ActiveSync
try soft reset on your Ipaq and a restart of your PC.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ HX4700 Pocket PC Logo
374 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
