Question about Sony Bravia KDL-32V4000 32 in. LCD TV
My tv has a buzzing sound coming out of the speakers. It never did it before. I recently moved and that is when it started having a slight buzzing sound from the speakers.
2 Suggested Answers
  • 2427 Answers
SOURCE: speaker buzz
Well yes your speaker is damaged, the cone actually has a tear, so audio that has low base or high pitch will cause distoration..
Simply remove it, take it with you and buy a similar one.. Same size, same watts, same ohms and just put the new one in.
speakers are standered only brand names are different..
BTW if you feel that you dont want to purchase a new one, simply stick the tear with duct tape, or you can hot glue it together.. If its plasctic, plastic weld works good(ask for it at a hardware)..
Posted on Jan 14, 2008
Clicking sound when you plug it in. picture won't come on
Plasmas are notorious for a slight humming or buzz that emits when they are on...
A clicking sound when plugged in isn't nececessarily bad. However, the picture not working is bad and this may require a technician.
Are you using the proper power cord that came with your tv? Are you able to use the included remote or use the power buttons on the television itself?
Has the tv been moved or dropped recently?
Dec 24, 2013 | Philips 50PFP5332D 50 in. Plasma...
Internal speakers buzz very badly now. The tv was moved recently, but not batted around during move. I think the speakers are bad. Is there a way to tell for sure? Or could the speaker connection just...
the speakers are definately blown buddy they are so easy to fix..................just open the bezel up and buy some speakers that are the same size any speakers will work as long as they fit inside the tv or another thing you could do is buy a cheap surround sound system
Feb 16, 2011 | Samsung LN37C550 37 in. TV
I recently connected my satellite reciever to my
Iassume you mean you hear the buzz independently of the audio program - simply connecting the cable causes the buzz?
If tanything in the mix is powered from different AC sources you may have a different ground potential. Sometimes manipulating the orientation of one or more ac plugs will solve hum problems.
Apr 02, 2010 | M&K Sound Mp Series MX-350 MK II THX...
Samsung P237HD tv/monitor,unit buzzing when on.
I would take it back unless you have time to investigate the problem before the return policy expires.
If the sound is coming from the speakers then it is interference and would likely happen with another TV.
The interference type can be electromagnetic or radio frequency, both of which can be defeated.
Start with plugging it into a different outlet. If that doesn't work, then unplug anything from it one device at a time to see which thing is the culprit. If it is one of the devices, move any audio cords away from power cords and/or position the device further from the television.
Household appliances and fluorescent lighting also can cause signal interference in electronics that is audible.
A device known to help with such interference are power line conditioners from such brands as Tripp lite, and ferrite clamps. You can place ferrite clamps on the power cords of your devices and their analog audio connectors.
Jan 10, 2010 | Samsung P2370HD 23 in. TV
I recently purchased a 52 inch LCD. I have
This could be the speakers are vibrating onto the casing and need padding out more to prevent this.If this isnt the case, you may have a sticking coil on one of your speakers..When the sound distorts, remove one speaker in turn to see which one(s) are the offending unit(s) and replace. Is there a buzzing noise coming from the speakers especially in low volume? If so then you may have a faulty capacitor in your power supply producing hum on sound. Hope this helps :)
Oct 17, 2009 | Toshiba Televison & Video
Quasar 1989 tv makes a buzzing motor sound
Hi and welcome to FixYa,
Initially, if you have confirmed that the source of the buzzing sound is from inside the TV, then that would indicate a component about to fail or would need attention. Let us try process of elimination:
  • tuner - most unlikely, the tuner is responsible for selecting the channel. No component/part of the tuner could make such a mechanical buzzing sound;
  • speaker(s) - most unlikely, the speaker could have a buzz but generally would not affect the video nor cause snow (weak TV signals);
  • transformer - a strong possibility although without knowing the exact model, at most generic ideas; power transformer, flyback transformer, horizontal drive transformer (unlikely);
  • arcing - another strong possibility. This could be caused by damp, dusty surroundings of the components especially at the FBT area. Another area that could have adverse effect when dusty/damp would be the anode cap.
This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Nov 26, 2008 | Televison & Video
Koss KLD2700 LCD TV no picture
http://www.fixya.com/support/t860220-screen_blank
As in almost all lcd type tv/monitor the backlight will go out and the inverter should be replaced at the same time. Your cost about 50.00 if you do it yourself.
Take care
Kevin
Jul 31, 2008 | Televison & Video
Buzzing sound
You haven't specified where the buzzing sound is coming from, if it is coming from speakers, changing capacitors in the audio section will fix the problem, especially the filters. Now if it sounds like a hissing sound from back of the tv, the CRT base socket is the culprit. It is an easy thing to fix, and the base is cheap, but make sure you purchase the exact same type of base or it will harm the CRT. Good luck.
Jan 22, 2008 | Samsung TXN2775HF 27" TV
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
Audio interference
Is the sound comming from the speakers on the TV or the back of it? Plasma TV's can doing buzzing sounds when moved to higher elevations.
Jan 27, 2007 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Sony Bravia KDL-32V4000 32 in. LCD TV Logo
43 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
