Question about Fedders AEY18F7G Y Chassis Heat/Cool Room Air Conditioner
Can i us a wall mounted air conditioner to build a small cool room for chilling lamb
    President:
  • 1,515 Answers
Hi, correct me if i am wrong, but you want to use a wall mounted a/c to chill Lamb or other foods? Well, air conditioners are considered De-humidifiers, and medium temp. units, so if you cleaned out this room and put in the right materials on the walls and ceiling, you would have to maintain a safe temp 38*F and use this product as I am not sure what the shelf life would be? Check the sq. footage and get a unit more than large enough to maintain this temp. I know on a walk-in Refer, health inspectors want these boxes to be maintained at 38*F, and you can't accomplish this without modern refrigeration equipment. To chill it for a short time, maintain that temp and keep for you're own use.
Sincerely,
Shastalaker7
Posted on Nov 17, 2009
What does E2 code indicates on a Winchester brand ductless air conditioner?
Try turning the power off for 15 minutes.
Tech Tips: How to Resolve E1 and E2 Error Codes - YouTube
? 1:48
https://www.youtube.com/watch?v=COIxQBT-J2k
Oct 14, 2015 - Uploaded by MitsubishiHVAC
In this Tech Tips video, Jeff explains the E1 and E2 error codes, possible causes and some ways to resolve ...Missing: winchester ‎brand
Error Codes - Room Air Conditioner - LG
www.lg.com > Home > Support > Product Help > Help Library May 19, 2017 - An error code on the display of the room air conditioner can usually be ... P2 or FL; CH34; E1 or CH02; E2 or CH01; E3 or CH03; E4; E5; F1,F2, ...
Pioneer Air Conditioner AC Mini Split ERROR CODES And ...
https://removeandreplace.com/.../pioneer-air-conditioner-mini-split-error-codes-and-tr... Jun 19, 2017 - Pioneer AC Ductless Wall Mount Mini Split Indoor Unit Error Code = E2 What Does The AC Error Code Mean? = Zero-crossing signal detection ...
QSHX-242 24000 BTU Mini Split Air Conditioners With Multi-Fold ...
https://www.pinterest.com/pin/542894930052841690/
Panasonic S22NKU-1 Cooling Only Wall Mounted Ductless Mini Split ..... Room temperature, set point temperature and status codes are all indicated on the ... The Goodman brand is well known for affordable pricing covered by some of the ..... Winchester Air Conditioner Quick Connect System 4rac36q-30 - 36000 Btu 13 ...
Sep 27, 2017 | Heating & Cooling
Our wall mounted air con is set at 16 degrees but it is not cooling the house at this temp. Could it be the thermostat
most wall mounted ac units are designed to only cool a room, not a house
close all the doors to the room along with all windows
generally a 3kw unit (32,000btu )will cool a room 12ft X 12 ft X 9 ft quickly but anything bigger, the time that is taken to bring the temp down gets longer and longer depending on the setting and 16 C is far too low
Dec 07, 2016 | Heating & Cooling
040463610
How large a space are you hoping to cool? One room? One LARGE room? One SMALL room? One floor of a two-story house? A whole four-story house?
What's your climate like where you live? Very hot, dry, year-round? Cool most of the year but two weeks of hot during the summer? Just a little too warm in summer? Blazing hot all summer, including nighttime?
How's the insulation in the building you want to cool? Is it a plain steel building with no insulation? Is it a trailer? Is it a frame house with 4" walls and R13 fiberglass insulation? An old frame house with no insulation? An adobe building? A timberframe house with 8" of polyisocyanurate foam insulation?
All these are important to know when you select an air conditioner.
For most of the USA, assuming a frame house with 4" of fiberglass insulation, a 10,000BTU air conditioner will cool one large room or two small rooms pretty well, or a 5,000BTU AC will do one medium-sized room. Different places, and different house designs, and different types & amounts of insulation, will all have a profound effect on how much AC you need/want.
Jul 25, 2014 | Goodman Heating & Cooling
I have had a MWK-05CMN1- b17 5000 btu window mounted air conditioner unit that i bought last year. It was only used a couple times. It never cooled down the room. And when i finally used it and relized it...
From what you are saying, it sounds like the air conditioner is a lemon.
Unfortunatly, these small room size air conditioners are not worth the cost of reapir.
May 12, 2014 | Heating & Cooling
Delonghi pacl90. Lost manual, don't know what setting is best for cooling my house. I have a small 850 sq ft place. Should 1 side be blowing out hot air, and the other side have cool air?
Unfortunately, I don't think you're going to be able to find a setting to best cool your house. The model that you have, is a room air conditioner that only generates 10,000 BTU's and is only rated for up to 400 square feet. That's about half the square footage of your house. It simply will not cool your entire house.
To make the most of what you have, place the unit in a room where you spend the most time. Close the door to that room and only air condition it. To keep the other areas a little more comfortable, close the drapes or blinds during the hottest periods of the day. If you have a ceiling fan in that area of the house, run it a fast as you can comfortably stand, in a clockwise rotation. Generating a wind chill in the area that's not air conditioned will help make it more tolerable.
I hope I was of help to you. Thanks for choosing fixture.
Jul 24, 2011 | DeLonghi PAC L90 Portable Air Conditioner
Ice buildup in wall mounted unit
Icing on evaporator is caused by:
Dirty evaporator
Bad cold control
Low charge
Low ambient air temp
May 25, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Can I mount a window unit with no outside access
You could/can, but don't forget that (a) there is a good chance of heavy condesation, so size pan appropriately, or drain...and (b) The enclosed space where the drip pan is, is going to get quite warm. Hope this helps
Jul 13, 2009 | Frigidaire FAC124 wall/Window Air...
Friedrich RS10J10-C: Only half the coils are chilled...
If the evaporator coil is only half coated with water, this means it is low on Freon. You need a repairman to fix the leak and add Freon, but this costs way over a hundred dollars.
Jul 23, 2008 | Friedrich QuietMaster RS10J10 Air...
Fujitsu air conditioner - too much humidity
This can happen if the unit is too small for the room. Going by the model number I sounds like a big unit. I would also try cleaning the filters. Also set the temperature higher.
I take the time to help and answer your question so please rate me
Thankyou
Mat
Jul 02, 2008 | Fujitsu 18C1 Air Conditioner
Fedders AEY18F7G Y Chassis Heat/Cool Room Air Conditioner Logo
73 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
