Question about Sharp Zaurus ZR-5800
My Zr-500 will not turn on. any ideas?
My Zr-5000 will not turn on. any ideas?
Replaced the batteries. first things first
Posted on Nov 18, 2009
Mg zr common faults
Bad cabling.
You need to check earth for the motor.
If you are getting bad earth then it will overload the fuse.
Jul 11, 2014 | 2005 MG ZR
Sputtering at 5000 rpm
AT 5000 RPM? What is the redline on the XT 600? I had a XT 500 Do not remember my year exactly, I was thinking the redline was close to 5000 RPM and if that is the case you could be possibly hitting a REV limiter or floating the valves.
Have you adjusted or checked the Valve clearance lately along with the Timing chain tensioner to be sure all are within adjustment specs?
The example you gave where it does it in 2nd gear, 3rd gear, I am sure it would do it in any gear as it sounds exactly as if teh engine is running up against a rev limiter or mechanical limits of teh valve train.
Jan 29, 2014 | Yamaha Motorcycles
My zr-7 has fuel leaking past the carbs into the pistion chambers and then down into the crank case. I don't know if I just need to re-jet the carbs or what. This is the second time its happened. There...
This is a leaking needle valve. One of the carb.s floats is hanging and the needle valve is sticking open. All it takes is the one to cause the condition you describe. Be sure to turn off the fuel valve on the tank when you park it. But it would be a good Idea to pull the carb's and check each one for the float and needle valve.
Sep 23, 2011 | 2000 kawasaki ZR-7
Sharp zaurus zr-5000 stopped working. Any way to get my backup flashcard (FL02M-20-11138-XX 15095) to read to anything?
I have lost all comm ports for exchanging info to and from my Zaurus 5000. It says my ports are being used by my mouse which is not true.
Anyone have any ideas on how to retrieve ports?
Ted
Oct 20, 2010 | Sharp Zaurus ZR-5700
I need an driver for my benq scanner 500
here is the download page for your benq scanner
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 25, 2010 | Office Equipment & Supplies
Fuel starvation problem kawasaki zr 7 any ideas.... list lots please... it has fuel and will tick over but will die if try to rev.
Check gas tank,lines,gas filter,fuel pump, drain carb. bowls to see if any thing comes out, if fuel goes in the carbs BUT it does not run right , the carbs. need to be cleaned and also synchronized,BUT, if it's your injectors and you do not have carbs. the injectors need to be cleaned.Is your air filter stopped up?
Mar 26, 2009 | 2000 kawasaki ZR-7
Zr500
Windows Movie Maker doesn't recognize digital camcorders.    You need a program such as Pinncale Studio to do that.
Oct 16, 2008 | Canon ZR500 Mini DV Digital Camcorder
Canon ZR 500 Problem
try turning your camera mode to the box with the "P" inside. Then, change the "EXP" all the way to -11. this should darken you surroundings and bring what you want to film into view
Apr 19, 2007 | Canon ZR500 Mini DV Digital Camcorder
Sharp Zaurus ZR-5800 Logo
214 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Mark Dewar
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
