Question about Watches
Trouble setting clock on my santai St-2609L - Watches
How do I change the batteries in a Dalvey St Elmo clock
I woud try this link then their link to customer support or the contact us at the bottom of the window http://www.dalvey.com/shop-online/clocks-barometers?gclid=CKKZ0vTuqMMCFQqSaQodvkEAdg
Jan 04, 2015 | Watches
How to set up watch with time date and alarm modes
Right side lever hs different levels , you pull it and each level hs different functoionality , it might be clockwise or counter clockwise. try rotating both sides for each levels
Jan 09, 2014 | Santai Watches
How do I change the time on my fossil watch dq1185
Time Setting Instructions:First press and hold ST/STP for a few seconds and make sure it says (Time 1). This watch has a (Time 2) to use in other time zones.You change from Time 1 and Time 2 by pushing the ST/STP button for a few seconds.Time 1 setting:- Press and hold the SET button (Light Function will blink) use the ST/STP button to select on or off. Then push the Mode button to go to the next function.- The Chime function will blink. Use the ST/STP button to select on or off and then push the Mode button to go to the next function.- Next will be to select 12hour or 24hour time by using the ST/STP button then press the Mode button to set the Hour, Minutes, and Seconds.- Continue to set the year but when you get to the Month/Day you have the option of putting the day first then the month, use the ST/STP to select then push the Mode button to enter the month and day.- When satisfied with your settings push the SET button and your done.
Time 2 Setting:- Press and hold the ST/STP button it will say Time 2 and then go away only showing the time and date for Time 2- To adjust this time to another time zone you push and hold the SET button.- Use the ST/STP button and the RESET button to move ahead or behind in hours depending on time zone. Push the SET button when done.-Your time 2 is set for a different time zone and your Time 1 is set for your local time. Remember to use the ST/STP button to go back and forth from Time 1 to Time 2.
Jan 25, 2011 | Fossil Watches
Need a replacement crown for a st dupont watch model 155 F1 Bl07
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | S.T. Dupont Watches
Can't set the time on my Columbia CL 5008 watch.
Press and hold "set" until the "Chime" screen comes up.
Let off "set" and then press "mode" - This will take you to the clock. adjust the numbers by using "st/sp" and "reset". Use the mode button to cycle through the hour, min, sec and date.
Please rate 4 thumbs for the free answer
Mar 07, 2010 | Columbia All Sport Digital watch
Change watch setting from 24 to 12 hr clock
armitron watch 40/6601 instructions
Jan 19, 2009 | Watches
Please i need help i dont know how to set my timer and it wont st
See response to Turn off Beeps, its the same. Just click on the Mid Size Sports 1440 Black Nylon Strap Watch link and look for Turn Off Beeps solution.
Dec 29, 2008 | Timex 1440 Nylon watch
How to set time on columbia cl-5008 watch lost manual
This was a pain in the **** until I figured it out.
Nov 10, 2008 | Columbia All Sport Digital watch
Trouble with setting date.
hello,to set the date:
push and hold the mode button for 3 seconds,then push the mode 1 time it will take you to the time,press the st/stop 3x's to reach the month,use the lap/reset button to change,4x's to reach the date,use the lap/reset button to change,5x's changes the day of the week,use the lap/reset button to change.when yor done push the mode button to set.
Dec 11, 2007 | Timex 1440 53591 Sports Quotient...
Mid size sportsman, time set problem
sshuman:
your 3 button watch is set by the atomic clock at 1:am daily,to do it manually press lap/reset it can take up to 2 minutes to flash set at that point clickmode and begin,any questions ray726@yahoo.com.
Dec 10, 2007 | Timex 1440 Nylon watch
Watches Logo
482 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
