Question about Cameras
Casio Exilim EX-Z850 and the lens has extended
Hi
I have a Casio Exilim EX-Z850 and the lens has extended and will not retract. I cannot take photos. The green light near the viewer flashes on then off quickly. Nothing works. Any help please!! Thanks.
SOURCE: Casio Exilim EX-Z850 Red Light Flashing
I have been having this same problem. It doesn't happen everytime, but there have been a number of occasions when my Exilim Z850 would display a blinking red light and refuse to take pictures. I thought it was a battery issue, so I tried buying a new battery, eventhough I observed this problem soon after the camera was newly purchased. The new battery didn't help resolve the issue. So I do hope someone out there has figured out what's wrong and will let us know.
Posted on Dec 27, 2007
mcomijohns
  • 477 Answers
SOURCE: Casio Exilim Ex-S880
I have had this issue on several Casio camera the lens comes out fine and then goes right back in some times it just gives you two beeps and nothing else. the problem is with the lens its focus motor is out of ajustment. According to Casio this is not covered under any type of warrenty coverage and that ****.but hehe sometimes you can take it back to places like bustbuy and if you have your receipt they will sometime swap it out. But lets say they don't. well you sometime can get a replacement lens for it off ebay for pretty cheap. This is only if you are sure that you can fix the camera. If you choose to have it fixed make sure you shop around there is a huge diffrence between shop to shop.
Posted on Mar 28, 2008
help kid
  • 35 Answers
SOURCE: Casio Exilim EX-Z60 won't turn on
This happened to me too, fiddle with the lens as its obviously stuck. Don't be too rough but try to figure out if it is slightly bent.
You will only be able to this if the lens is sticking out a little, enough to get a grip.
Good luck
Posted on Apr 23, 2009
  • 102366 Answers
SOURCE: lens error with Casio Exilim EX-Z80 and makes a weird buxxing sound please I need help
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 23, 2010
Ranglo
  • 1194 Answers
SOURCE: i own a casio exilim
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
  • If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Good luck and have a nice day.
Rating the solution is highly appreciated.
Posted on Sep 11, 2010
Turns on for 1/2 second and turns off
It sounds like the focus element inside the lens is stuck. This is usually either due to an impact knocking the elements out of alignment, or to sand/debris entering the focus motor's gear drive and preventing it from rotating. The buzzing sound you hear is the focus motor attempting to rotate, but buzzing up against some obstruction. When the lens extends, you hear a buzzing sound, and then the lens retracts - this is usually the cause of the issue. Unfortunately there is not much you can do externally to fix this problem. The camera will need to be taken apart and repaired by a professional or by the manufacturer. David Millier http://advancecamera.com/repair
Jun 05, 2007 | Casio EXILIM EX-Z1000 Digital Camera
Lens error - the lens doesn't open
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Oct 11, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Casio Z850 froze & nothing works
just took out battery and memory card and out them back in.
Jun 05, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
LENS ERROR
then it's time to take it in for a repair estimate.
Apr 24, 2009 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Lens error of casio EX Z300
The lens error is usually caused by mechanical faults concerning lens assembly. This happens because there is dirt inside the lens (sand dust), or one part in the lens assembly is bad or went out of place.
Because of this he lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
If if does not extend tapping gently the back of the camera, and if it does not retract helping lens back in while turning camera respectively on and off.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 18, 2009 | Casio EXILIM EX-Z300 Digital Camera
Casio exilim s600 LCD/Camera problem
You can get a manual here: http://support.casio.com/pdf/001/EXS600_e.pdf
Dec 04, 2007 | Casio Exilim EX-S600 Digital Camera
Lens on Digital Camera won't r retract
Send into Casio Repairs. Call them at 800-706-2534 and keep choosing option 1. If you have to lie and tell them you already talked to tech support otherwise they will try and tell you to call tech support and they will just tell you what I just did. LOL
Jun 28, 2007 | Casio Exilim Card EX-S600 Digital Camera
Casio EXILIM ZOOM EX-Z850 Zoom button doesnt work
You have to send it in to repairs. You're lucky that the lens even still comes out.
Apr 14, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
