Question about Envision EN-7100e 17" Flat Panel LCD Monitor
Need a new dc plug - Envision EN-7100e 17" Flat Panel LCD Monitor
  • Envision Master
  • 20,929 Answers
DC = Direct Current such as a 12 volt battery, surely you mean AC (alternating current)?
AC power cords are available from any computer retailer like Future Shop or Best Buy.
Posted on Nov 17, 2009
My Q430's power connection is loose and not changing battery. Do I have to swap out motherboard?
The DC Power Jack is the jack you plug the AC adapter (Charger) into. (DC_IN)
The DC Power Jack for the Samsung Q430 series of Notebook PC's, consists of a;
1) DC Power Jack, which is connected to two wires.
2) The wires end in a small male plug connector.
It is now a DC Power Harness,
http://www.laptopjacks.com/part/Samsung-Q430-DC-Power-Jack-J-SM371300C1.html
FOLLOWING Anti-Static Procedures, the laptop is disassembled far enough to unplug the DC Power Harness, and plug a new one in.
Regards,
joecoolvette
Sep 10, 2011 | Samsung Q430 Laptop
Laptop screen won't come on. Laptop battery won't charge.
Sounds like you might need a new AC-power adapter or dc-jack. Does wiggling the power plug on the computer make any difference? If the screen comes on when you wiggle the power plug,then you need a new dc-jack. If not, then maybe the AC-adapter is bad, I see a lot of replacement adapters being sold for the Aspire One.
Worst-case scenario is that you have a power problem on the motherboard,let's hope not.
Mar 22, 2011 | Acer Aspire One PC Notebook
Laptop won't charge
You might need a new battery....you could try removing the battery, plug laptop into ac and restarting. Or you might need a new DC power jack. If you wiggle the cord where it plugs into the laptop, and it starts to charge normally, then the DC power jack needs replacing. http://www.insidemylaptop.com/take-apart-sony-vaio-vgn-s360p-replace-broken-power-jack/
Apr 26, 2010 | Sony VAIO Notebook
My comptuer was working it wont charge the battery or it wont work even when its plugged in
You most likely have a faulty DC Jack... The Laptop Will Need To Be Disassembled... The Faulty DC Jack Desoldered From The Motherboard, THe Motherboard Contact Pads Need To Be Retinned.. Then A New DC Jack ($6.00 on Ebay) Gets Soldered Into Place...
I would First Test Your AC Adapter... Use A MultiMeter To Do So... (they are sold at any Home Improvement Store For About $ 14)
Stick The Positive Test Prod In the Chargers Plug Tip.. And Touch The Negative Prod To THe Outside Of the Plug Tip, THen Test For Correct Voltage
Dec 04, 2009 | Acer Aspire 5100 Notebook
My 4520 Acer Laptop will not charge and will not work on AC power alone.......
You First need to test your AC Adapter Cord...
You can test if you have a secondary known working one.. plug that one in to see if same issue occurs.. OR you will need to test the AC Adapter using a multimeter (available at any home improvement store for under $7).. When testing the Plug End on the AC Adapter - Hold The Negative Test Prod Of the Multimeter to the Outer Side Of the Plug Tip, and Put The Positive(red) Test Prod Inside The Plug Tip... See If You Have Power Through The AC Adapter Tip... You Might Need To Slightly Wiggle The Cord Near The Tip End To See If THere Is A Short In The Cord....
If Cord Tests Good....
You Will Need To Replace The Laptops DC Jack...
The DC Jack is the port where your AC Adapter Plugs into on the laptop..
Your Faulty DC Jack Would Need to be desoldered, the motherboard cleaned of all old flux, Re-Tin The Contact Pads and then Resolder a New DC Jack Onto The Motherboard...
Nov 16, 2009 | Acer Aspire 4520-5582 Notebook
Need new ac power supply plug / the jack plug that goes into my laptop isnt connecting to keep my machine on / emachines m5116.
You will be able to get the DC adapter plug from eBay, and they are cheap around $7
have a look here >>>>>
http://cgi.ebay.co.uk/EMACHINES-M5116-M5122-M5322-Dc-Power-Jack-Socket-PJ13_W0QQitemZ190289528780QQcmdZViewItemQQptZUK_Computing_Laptop_Accessories_LaptopCables_Connectors?hash=item2c4e23c7cc&_trksid=p3286.c0.m14
Regards.
Sep 29, 2009 | eMachines M5116 Keyboard
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
BROKEN adapter PLUG IN ON SUPER NINTENDO
The dc jack where you plug in the ac adaptor is worn out which is why it is chipping and also why you can't make a good enough connection for the ac adaptor so you can turn on the Super Nintendo.
What needs to happen is your SNES needs to have the old dc jack taken off and a new one soldered on.
If you can find another broken SNES that has a good working dc jack then take if off of that one and solder it onto yours and your SNES will work like new.
May 28, 2009 | Nintendo Super NES Console
Lost the power plug what kind is it
1. You can buy a new power plug here.
2. You look at the power connector on your scanner and try to find a replacement with the following specifications:
Input voltage/frequency:
  • 100 Vac, 50/60 Hz (Japan)
  • 120 Vac, 60 Hz (North America)
  • 230 Vac, 50 Hz (Europe)
Output voltage/watt:
  • 12 V DC, 15 watt maximum
If you try to find an AC/DC converter yourself, make sure that the DC plug has the right +/- polarity and right size.
Jan 11, 2009 | Visioneer 4400 Flatbed Scanner
No power at all for my Dell Latitude D505
Sounds Like From Your Description That You Need Your DC Jack Repaired/Replaced..
THe DC Jack Is the Port where Your AC Adapter Plug Plugs into on the laptop.... THis can be proprietary or non proprietary.... But Either way, the Old Faulty Jack Needs To Be Desoldered and Removed, THe Board Cleaned and a New DC Jack Soldered On.. You Will Then Be able To Power On Laptop With AC Charger and Will again Be Able To CHarge The Battery..
Nov 19, 2008 | Dell Latitude D505 Notebook
Envision EN-7100e 17" Flat Panel LCD Monitor Logo
62 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
