Question about HTC G1 Smartphone
Made a call on my g1 this morning, then no signal for the rest of the day been in a 6 mile radius and nothing, i have taken out sim and battery, reloaded and still no signal, or sat signal. helppppppp
97 chevy tahoe 5.7 engine 2 wheel drive. im having problems in shifting into 3rd an 4th gears. some days itl shift in the morning an give some touble thur the day. while on other days it wont shift in the...
The torque converter clutch issue, won't effect the
shifting issues
I would stop using it,unless your prepared to
completely rebuild it, in a few weeks.
It has to be diagnosed and resolved, now,quickly.
Having once owned a trans shop, I don't like the
fact your driving it at all,hung shifts for 7 miles
will do it in
Mar 17, 2011 | 1997 Chevrolet Tahoe
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
Where to insert sim card for g1
remove the back cover and the battery and look for the little picture that looks like a SIM card and insert the sim card with the gold part facing down and the cut corner of the card towards the camera lens.
May 20, 2010 | HTC G1
Received G1 replacement phone i put my existing SIM card into the replacement and in the notifications bar it says SD card removed, insert new one. the SIM card works fine in my current G1
Sounds like you are replacing the SD card, not the SIM card. The SIM is underneath the battery. It's a small white rectangle missing a corner.
Feb 20, 2010 | HTC G1
My g1 got wet but the buttons still light up but the screen wont turn on
take the battery and sim out dry it with a cotton swab and then put all the items in individual bags of rice to absorb any extra moisture let sit for 5-6 hours or a day then put back together and try it hope this help (please rat and vote)
Jan 06, 2010 | HTC G1
We have a TMobile G1 phone that we purchased as soon as it came out. We have never had any problem with it except for a defective sim card 6 months ago. A few hours ago when playing a game, the screen went...
hi ....outthere can someone help me solve this?I have a htc {dream}G1 astriod phone...lent out to a family member....well it came back not working correctly..everything works ..but wont let me make or receive calls...found puk no. but still no good ....pls someone help me.
Nov 13, 2009 | HTC G1
Need unlocking code and steps for g1 phone
The only way to get the unlock code is to have T-mobile service for at least 90 days(unless you're lucky). Call the service help line and tell them that you are going over seas and would like the unlock code for your G1. They will need your account info as well as the IMEI number of your phone(this can be found under the battery on the phone). In roughly 24hrs. you will receive an e-mail from HTC with your phone's SPECIFIC code(codes don't work for other G1s).
HOW TO:
1. Turn off the phone and remove battery/SIM
2. Insert other carrier's SIM and replace battery/cover
3. Power up phone and enter unlock code in menu that comes up.
4. Enjoy your unlocked G1
Mar 16, 2009 | HTC G1 Smartphone
S710a problems
I am having the same problem - it won't hold a charge. Red light shows it is charging, but nothing. It may be the battery. I just called S.E. and they said it may be the battery. I ended up getting a new phone since batteries cost almost as much as a new phone.
Jul 03, 2007 | Sony Ericsson S710a
HTC G1 Smartphone Logo
126 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
