How to delete windows from a laptop
How to delete windows xp from a laptop
  • Computers & ... Master
  • 19,031 Answers
You wish to scrub the hard drive clean so no data or Windows XP remains?
Tap F8 as the computer is booting. Choose Command Prompt. Type the following;
format c:\
Press enter.
Posted on Nov 17, 2009
    Champion:
  • 206 Answers
You can't delete your system unless you are installing a new OS. If you are trying to do that, you need a disk with OS installation on it, insert it, restart your computer, go into BIOS and under BOOT SETTINGS choose your cd-dvd rom for the first boot device. Press F10, and then YES
After rebooting, your computer will start a boot from the ****. Afterwords, just follow the instructions, and that's it.
My PC-GP1-C7M laptop getting restarted during windows start with blue screen
you should delete the system partition and then set it back again without deleting the other partitions (with data) of course, then format it normal not quick then continue installing your win xp 3.
May 19, 2012 | Computers & Internet
I install windows 7 on my IBM thinkpad r51... now I want install Windows XP .. but Xp could not be installed .... What I do.....? thanks in advance
Have you delete your partition and format it?. Or maybe the installer that you have is not working try to use other CD installer for XP and re-run the whole process, But be sure to delete the partiotion in which you are going to install the windows. If you have an old partition then you have your files intact on the partition, DO NOT include deleting that partition, just the system partition on your drive. Hope it helps thanks.
Sep 21, 2011 | IBM ThinkPad R51 Notebook
Sir, i have hp mini 210-1000 laptop without cd/dvd. while installing windows xp i have deleted the partitions & tried to install xp from usb but failed. please help me to install windows xp .
Check the BIOS to see if you can make the USB as the first boot device, if you can then you will be able to install XP from the USB flash memory stick.
The reason why your XP installation failed is because in most older laptops, the USB port does not work until Windows XP has been installed.
Your hard disk may have an Windows XP install partition that you can access to reinstall Windows, provided you have not deleted this partition.
Jul 10, 2011 | HP Mini 1000 XP Notebook
I have a laptop pc ( compaq presario cq60) vista O.S base model.now i want to install windows xp on that. when i installing windows xp a blue screen come and stop my process. please give an solution for...
Hello
In the setup process for xp,you need to delete and format any partition on drive c.
This will completly erase any vista os files and allow xp to install.
Mar 31, 2011 | Computers & Internet
I reformat my gateway netbook from xp to windows 7 starter... but when I restart it shows an option of windows xp and windows 7. I need to choose windows 7 before the windows start....pls help i dont know...
that happens because you didn't delete your original install of xp. basically you are dual booting operating systems. the best way to recitify this is to reinstall wndows seven and do whats called a destructive install. You should be prompted as to whether or not you want to do an upgrade or a custom install. choose custom and install. this should completely remove xp from the system. if you need any existing data from xp be sure to save it prior.
Dec 09, 2009 | Acer Aspire One Netbook 8.9" Notebook
Remove linux from my computer I have a laptop with a dual boot system; Unbutu9.04 and windows xp. I need to remove Unbutu. How do I do it?
Sir,
Follow the steps below.
1 Turn on you laptop and Boot on with Windows Xp
2 After entering into the windows xp go to My computer.
3 Right click on the drive where Linx is Installed
4 Chose the option Format
5 Format the drive with the Format of FAT32
These step will lead you to remove Linux from you system.
Oct 21, 2009 | Toshiba Satellite A100-S8111TD Notebook
WIndows xp on dell
hello
you have to delete vista for intalling xp,after xp you can can install vista,format vista first with linux
Nov 07, 2008 | Microsoft Windows XP Professional for PC
XP ON VISTA
hiii,u can just format vista by vista cd.then install xp.
Sep 04, 2008 | Microsoft Windows Vista Ultimate Edition
Dell inspiron 7500 pentium 3, 18 gigs
Hopefully your other OS's are on a different drive letter (d: or e: for example). As long as they are then there is no conflict with XP.
You could effectively remove access to them by editing c:\BOOT.INI . Note that you will have to right click boot.ini, select "properties" and remove the "read only" and "hidden" properties for the file before editing it. I would recommend making a copy of the boot.ini first for a backup.
Then just open it with notepad. There will be one line for each OS in there. just delete the extra lines. Then you can just erase or format the partitions for the other OS's.
Dec 13, 2007 | Dell Inspiron 2200 Notebook
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Apr 21, 2018 | VIA Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
