Question about Nintendo Wii Console
My Wii will turn on, but is not recognizing the remotes. I have tried to re-synchronize the remotes to the console, but they just keep flashing and don't connect.
    President:
  • 787 Answers
First unplug your Wii from power cord and wait 30 min.Then plug it again and turn it on.Press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.Then try to sync it again.Push the red sync button on the console, then open the batteries cover on your Wii Remote and push the red button there.If this not help may be you have problem with bluethoot device on your Wii and this need service.
Posted on Nov 18, 2009
Our wii has been boxed away awhile we cant get it to reconize our emotes can help
Here is a step by step instruction on Syncing your Wii remotes to you console!!http://www.nintendo.com/consumer/systems/wii/en_na/setupWiiRemote.jsp#Synch
Synchronizing the Wii Remote with the Wii Console Synchronizing the Wii Remote to a Wii console allows the Wii Remote to communicate with the console. The Wii Remote included with your system should already be synchronized to your console. However, all additional Wii Remotes you use with your system also need to be synced in order to function properly..
There are two different modes of synchronizing (syncing):
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please click here.
  • ONE TIME MODE - This mode allows you to temporarily use your remote on a Wii console other than your own, or to use a friend's remote on your console. It can also be used to change the order of the Wii Remotes, without the need to turn off the Wii console. One Time Mode does not delete the Standard Mode setting stored in the Wii Remote. In this mode, the Wii Remote will only communicate with the Wii console while the power is on. When the power is turned off, the Wii Remote will lose its sync with the Wii Console. For instructions on One Time Mode setup, please click here.
Note: Only a Wii Remote in Standard Mode can turn the Wii console power ON or OFF.
Standard Mode Synchronization
Note: Make sure you have placed batteries in the Wii Remote (how to).
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button just below the batteries on the Wii Remote; the Player LED will blink. Quickly press and release the SYNC button on the inside of the SD Card compartment on the console.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote added to your system.
Sep 12, 2011 | Nintendo Wii Console
I dont know how to sync my wii and its nanchack>> not sure of thats whats it called
  5. wiiremotesynchstandard.gifThis procedure must be followed for each additional Wii Remote addedto your system.
    Go to the Next Step (Playing Game Discs) >
    One Time Mode SynchronizationNote: This mode temporarily removes Standard Mode synchronization setup for all Wii Remotes until the power of the Wii console is turned off. When the power is turned back on again, the Standard Mode settings will return.
  1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
  3. Select the Wii Remote Settings option from the Home Button menu.
  5. Select the Reconnect Option.
  7. Press the 1 and 2 Buttons at the same time on the Wii Remote that you want to synchronize with the console. If you are syncing multiple Wii Remotes, press the 1 and 2 Buttons on each Wii Remote immediately (without a significant pause) in the order you want them synced. The order in which you synchronize Wii Remotes determines the player order (1 through 4) for multiplayer games. The Player LED will blink during the syncing process. When the blinking stops, the connection is complete.
Set Up and Use of the Nunchuk
  1. Feed the cord on the Wii Remote's wrist strap through the connector hook. nunchukwristattach.gif
  2. Insert the Nunchuk plug into the Enternal Extension Connector on the bottom of the Wii Remote.
  4. nunchukhold.gif nunchukclipclose.gif Note: Place your hand through the wrist strap of the Wii Remote and hold the remote firmly in your hand. Slide the strap lock up so that the strap will not fall off of your wrist. Do not over tighten the strap lock so that it's uncomfortable. It should just be light enough to hold the wrist strap in place. (For more information on using the wrist strap, click here).
May 04, 2011 | Toys
Wii hand will not show up we tried syncing, taking out batteries, unplugging and plugging sensor bar and nothig works
Jan 27, 2011 | Nintendo Wii Console
My Wii Fit is synchronizing just fine with the console but it disconnects the remote when it does. Also, when it asks me to turn on the Wii fit the light flashes and then goes off. The batteries are brand...
I had the same problem myself. After nearly 40 mins of trying and trying the Wii fit board eventually synchronized with out the Wii remotes being affected. The main thing is to make sure you do not hold down the red button on Wii console for more than 10 seconds as this unsyns the remotes. Hope this helps
Jan 07, 2010 | Nintendo Wii Fit for Wii
Pressed red button for more than 10 seconds remotes not working help
hai. I am one of the user of wii....... i also got many problem like this..... i solved my problem using wii repair guide....click here to help you........
Dec 08, 2009 | Nintendo Wii Console
Our wii remote wont turn on. we tried new batteries and all it does is the blue lights flashes and turns off. What is wrong and how can we fix it
Sounds like it's not synchronizing with the infrared bar. That might've come loose. Double check to make sure that's plugged into the Wii. If that's not connected the Wii Remote will not stay on because it's not connecting.
Oct 14, 2009 | Nintendo Wii Console
My wii counsel turns on fine, my remotes are with new batteries and flash when pressed the red light, but yhe remotes don't seem to be able to connect to the screen?
if your Wii Remote is not responding It may need to be synced up. I have given you both ways of syncing your Wii. After doing this Please don't forget to rate me as " Very Helpful" & feedback is appreciated - thanks
  • STANDARD MODE - The Standard Mode procedure is used when adding additional Wii Remotes to your system or if you want to re-synchronize your original Wii Remote. Once synchronized, the Wii Remote will stay synced to the console unless you overwrite the settings by syncing the remote to a different console. For instructions on Standard Mode syncing, please read below.
Standard Mode SynchronizationNote: Make sure you have placed batteries in the Wii Remote
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
Sep 22, 2009 | Nintendo Wii Console
My wii system does not recognize my remote
    wiiremotesynchstandard.gif This procedure must be followed for each additional Wii Remote added to your system.
Dec 22, 2008 | Video Game Consoles & Games
Wii remote keeps beeping and not working
try this! I found it on Nintendo.com under support:
  • Wii Remote not being recognized by the Wii Console (lights on the Wii Remote flash when you press a button, but then go out) - Most Common:
    Getting the Wii console to recognize (or "sync" with) a Wii Remote, especially one that did not come in the box with your Wii console, may require doing a few additional steps before it can be synced. Additionally, a Wii Remote that was working, but is no longer being recognized (or has "lost its sync") may need to be re-synced. Please use the troubleshooting steps listed below, which our experience has shown can solve many Wii Remote issues.
      Try these steps!
    1. Turn the Wii console power OFF by pressing the POWER Button on the front of the console. Unplug the power cord from the wall outlet for a few seconds. After a few seconds have elapsed, plug the cord back into the wall outlet.
    2. Turn the power of the Wii console ON. When you see the Health and Safety screen, open the small flap on the front of the Wii console to find a red button labeled "SYNC." Press and hold the SYNC Button down for 15 seconds. This will clear all the syncs on the Wii, allowing you to get a clean start to begin the process described below.
    3. After holding the SYNC Button on the Wii console down for at least 15 seconds, you can now "re-sync" your Wii Remotes:
      1. With the first Wii Remote you wish to sync, remove the battery cover on the back of the Wii Remote to find a small red button just below the batteries.
      2. Press and release the small red button just below the batteries on the Wii Remote; the blue lights on the front of the Wii Remote will blink.
      3. Quickly press and release the red SYNC button on the inside of the white flap on the front of the Wii console (picture).
      4. When the Player LED blinking stops and stays lit, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
      5. This sync procedure (steps "a" through "d" above) must be followed for each additional Wii Remote added to the system.
    If you are still unable to get the Wii console to recognize your Wii Remote(s) after carefully following the steps above, please call 1-800-255-3700 for further assistance.
  • Sep 01, 2008 | Nintendo Wii Console
    Wii fit
    are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
    but try this first
    Synchronizing the Wii Balance Board with your Wii Console
    IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
    • This procedure must be followed for each Wii Balance Board compatible Game Disc.
    • These synchronization settings will be saved even if the console is turned off.
    • This procedure can be completed only if a compatible Game Disc is running in the console.
    1. Press the EJECT Button on the front of the Wii console and remove any
      game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
    2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
    3. Open the SD Card slot cover on the front of the Wii console.
      NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
    4. Remove the Battery Cover on the bottom of the Wii Balance Board.
      NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
    5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
    Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
    1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
    2. The Power LED will stop blinking and light steadily once the synchronization is
      complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
    • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
    • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
    • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
    Aug 01, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    105 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
