Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
I have a hotpoint WT 540, it will fill then all it will do is click, like a relay is opening and closeing but the drum does not move.it will also drain but not spin. could it be the pcb board....
    Genius:
  • Hotpoint Master
  • 1,461 Answers
More than not motor brushes Carbon type are worn you need to fit new ones parts cost about £12...
Posted on Nov 17, 2009
Hotpoint aquarius 1000 extra
have you checked belt or brushes in motor
Jan 26, 2012 | Hotpoint Washing Machines
Stay in high flats 4up low water pressure is there away of reducing the pressure in the hotpoint wt 540 washing machineso it will take in te water
If your water pressure is to high or even to low then just check the taps at back where hoses are fitted. Make sure they are fully open if pressure is to low, also make sure there are no kinks jn the pipes. If pressure is to high then just turn taps down a little.
Mar 12, 2010 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wt 540 mini light and on off lighs flash changed mogel board switched on and all lights now flash hotpoint w
f01 was the origional fault motor triac failure-when replacing module was it prorammed correctly-clarify on what lights are now flashing-if everthing is flashing like a bad connection then the main board is a faulty one
Nov 09, 2009 | Washing Machines
Hotpoint wt 540 will not run All indicator lights are flashing e-mail derek.emery@talk21.com
i had a greyhound that would not run so i kicked him up the *** that did the trick
Oct 03, 2009 | Washing Machines
Lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
May 22, 2009 | Washing Machines
Control panel
Its the door latch its playing up you need to get it looked at by a pro
Jul 07, 2008 | Hotpoint WMA32 Front Load Washer
Drum wont turn
I WOULD CHECK THE FLYWHEEL THAN LISTEN FOR SOUND OF THE MOTOR IF YOU HEAR IT SPINING THAN IT IS POSSIBLE THE SHAFT IS BROKEN OR SEIZE
Jun 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Drum not turning
My problem is the same as colins my hotpoint wm63 is starting okay i.e. water fills up but drum is not turning. I can hear it clicking through the cycle but drum doing nothing. i to have just put in new carbon brushes but still no joy please help
steve
Apr 08, 2008 | Hotpoint Aquarius WD63 Front Load...
Circuit board
It sound like a malfunction circuit board issue that shouldd be replaced.
Jun 20, 2006 | Hotpoint WD52 Front Load Washer / Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
203 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
