Question about HHB BurnIt CDR830 CD Recorder
HHB burn it...I record on coaxial from Tascam DAT. 1st five tracks are great but the 6th track sounds horrible like there is a scratchy sounding distorted delay. It does this every once in the while . What could this be? Thanks, Brian Saxtrax Productions
    Brigadier General:
  • 8,546 Answers
I had this happen a lot on my Pioneer PDR-509, which is pretty much the same machine, when using marginal mongrel-brand CDR's. It's annoying but I have seen nothing to explain or detect it in real time so something can be re-recorded.
Posted on Jan 23, 2011
I have a TASCAM PortaStudio 424 mkiii 4-track tape recorder-mixer. When I record a new track and listen back to it, everything sounds great. After a couple times of listening to it, and overdubbing other...
It is probably a hard to find record electronics problem and possible that the record bias is staying on partially. This will erase partially the audio and apply the clicks. You are going to need a good Technician for this. Try this guy- I have confidence in him.
New Jersey Factory Service, Inc.
16 Chestnut Avenue Suite 103 B
Emerson,New Jersey 07630
201-967-0060
Fax 201-967-0062
Mon- Thurs 8-4 Closed Fri Sat by appt.
Dec 17, 2010 | Tascam Audio Players & Recorders
I am having problems with my Tascam Da-88 8
Maybe you could just clean the heads. If anything visible comes off they're TOO dirty. Or or look at it yourself with a strong light source and see the wear by evaluating reflections from the head surface.
May 31, 2010 | Tascam HHB DA30 Tape for DA-88
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
How do i hook up my tascam 414 portastudio to my PC??
Assuming you want to keep your recordings at the highest possible quality, wouldn't it also work if you had an outboard component CD recorder? That way you retain the highest resolution at the first analog-digital step and once it's on CD you can rip to your heart's content or run it through the mixer again.
I have a Pioneer Elite PDR-509 that I have used for years. There are several 'professional' decks made by Tascam, Marantz, HHB and others that add the ability to use vanilla CDR's and CDR/W's instead of CDR-Audio and CDR-A-R/W media as mine uses and some can defeat the SCMS codes so you can do digital-digital multiple generation copies. Home audio CD Recorders will only digitally copy a first-generation digital original, unless the source was was made on a PC. Then it's always considered first-generation. The cost of the media isn't that much different these days. A standalone CD Recorder would also let you digitize those LP's and tapes you have hanging around or record Live through your mixer to CD. How about that!!!
There are plenty of them on eBay cheap and I'm still looking for the right one in case mine should ever decide to die. I see 7 pro models right now on eBay. I'd look for one that has Coaxial Digital inputs and outputs as well as Optical ones.
As for hooking up your Tascam, that would depend a lot on what sound processing software and soundcard you have - not my strong suit as I still do everything in the analog domain prior to cutting the CD and then ripping it to MP3 for portability and fast access. The physical hookup would be Line Out to Line In. After that it's all software.
Apr 30, 2009 | Tascam Starter Pack for 4-Track Cassette...
I have a Tascam DP-02(not 01) and need to seperate songs
You can use the track edit functions to mark the beginning and end of a song to cut or copy and then insert the song onto its own track(s). (If it's in stereo you'd have it recorded on two tracks).
Or you could consider just exporting the whole track(s) via USB (or using the SF card) onto a PC for editing with the program of your choice.
Apr 10, 2009 | Tascam DP01 All-In-One Recording Package...
No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Sep 26, 2008 | Tascam US-144 Sound Card
I record using a pre recorded sound track, no problem there, then I recorded the voice.. Now how do I get to master this. IT tells me the track is too short and won't let me go into the Master mode. And...
how long is the track you are trying to master i believe it has to be over 30 seconds if your just sampling 8 or so seconds it wont work i know on some models its over a minute to be able to master mix a track.
thanks,
Nate
Aug 22, 2008 | Tascam DP01 All-In-One Recording Package...
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Tascam us 144 sync problems with cubase le
Hey lea,
i have a similar setup (Cubase LE & Tascam 144) and each time i start up Cubase i have to make sure there is no digital input going to the tascam. once cubase is started up but no project loaded i plug in my spdif from my DAT machine and then open my project and all is fine. does that answer part of your question?
i have a different problem though, i'm trying to record my DAT tapes which are recorded at 32khz and cubase doesn't recognize that sample rate properly. it'll record no problem, and play them back fine, but exporting always creates mismatched sample rates in the exported file. sucks big time and i have got no idea on how to fix it either.
Mar 04, 2008 | Tascam US-144 Sound Card
Burn CDs from Tascam US-122L
The answer is yes, but it may not work as simply as you think. You can't just save your Cubase file / mix and then send it to your recorder. You'll want to render down the song you have to one stereo .wav file and send that to burner as a wav file. (That's the quick way). Another option is to render each file you have seperately so acoustic guitar, bass, vocal, etc are all seperate tracks. So the answer is yes, a .wav file is the format for audio cds. You'll record your seperate tracks and then you'll have to mix down, render, or export them when you are done. In Cubase, use "export".
Feb 07, 2008 | Tascam US-122 USB Audio/MIDI Interface...
HHB BurnIt CDR830 CD Recorder Logo
137 people viewed this question
Top HHB Audio Players & Recorders Experts
John
John
darren dillon
Level 1 Expert
Are you a HHB Audio Player and Recorder Expert? Answer questions, earn points and help others
