Question about EliteGroup 915G-M Motherboard
ECS 915G-M Onboard audio and XP
I just put in a new hard drive and installed Windows XP MCE. I can't play my avi files and when I try, I get this error
"Windows Media Player cannot play the file because there is a problem with your sound device. There might not be a sound device installed on your computer, it might be in use by another program, or it might not be functioning properly."
    Problem Solver:
  • 42 Answers
Try to install the motherboard's driver for the sound devices...
Posted on Jan 10, 2008
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Xvid for windows vista
I've spent a lot of time this weekend finally setting up Windows Vista Media Center, and I suddenly realised that Vista Media Center won't play Xvid and Avi files even if Windows Media Player will. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the Media Control Plugin For Windows Vista Media Center.
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)). FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
The Media Control Plugin for Windows Vista MCE also adds the following additional features:
  • Switching embedded audio and subtitles streams while playing a video: works with AVI, OGM, MKV
  • Switching between external subtitle files (.SRT, .SUB)
  • Switching between FFDShow presets (audio & video)
  • Setting and loading bookmarks inside a video with visualization of the pictures of the saved bookmarks
  • Real fastforward (and rewind) exactly like in the TV module (with 3 different speeds)
  • Switching and setting post-processing filters in FFDShow (video filters only)
  • Separate application to assign keyboard/remote control shortcuts to the commands and the MCML pages of the plugin.
  • Full remote control support (6 buttons are mapped by default, but this can be changed)
  • Default mapping (works in full screen while watching a video, except the blue button that is always caught) :
    • Fast forward / rewind buttons
    • Blue button : loads the startup page of the plugin
    • Red button : switches audio stream
    • Green button : switches subtitle stream
    • Yellow button : switches subtitle file
May 06, 2011 | Dell Computers & Internet
Installation of XP MCE won't finish
You need to set the pc to boot from the install disk. Then it should detect the failed install. Either select a new location or over write or format the disk and install.
Trying to recover from a failed install is usually far more trouble than its worth. You usually end up with a unreliable install and nothing but headaches.
Mar 23, 2010 | Microsoft Windows XP Media Center Edition...
Media center does not work on my windows xp
You should reinstall it using the installation cd because there is no downloads on the net for this.
Feb 22, 2010 | Microsoft Windows XP Media Center Edition...
Problem with sata HDD probably?
check the bios settings first. if you can see your sata hdd and dvd rom drive then you can install it with no problem. or else try to replace the cables of the hdd if the hdd is not showing up in the bios.
also check that the hdd is set to master drive and dvd also set to master as they are on different connections.
Apr 21, 2009 | EliteGroup ECS 915-A Intel 915GV Chipset...
Can't play AVIs.
dear friend
you are missing a codec
just download klite codec pack from link below
klite
thanks
Apr 12, 2009 | Computers & Internet
I disabled the lan and when i enabled it again it won't work
Hi, well now you have windows registry confused. The PCI card may have come with software & you installed it. (See if its listed in add/remove programs & uninstall it), than go to this link & download the free software to clean your registry. (Keep the onboard lan disabled in the bios).
http://www.pctuneuptips.com/recommends/clean/?gclid=CL2RiIrTmpICFSFMGgodODIPzg
When the program finishes close the program & shut down the system. Than boot the system & enter the bios. Enable the onboard lan. Save & exit. With any luck windows will see your lan & ask for the software. You can use the CD to guide windows to the lad driver software or you can download it from ECS. The online lan may be a bit newer or may not be. Click here to go to ECS web site:
http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=474&DetailName=New&DetailDesc=915G-M%20%20(V1.0)&CategoryID=1&MenuID=82&LanID=0
If you are running XP install through windows device manager.
Run into trouble, just let me know what the trouble is & we'll go from there.
Mike
Sep 28, 2008 | EliteGroup 915G-M Motherboard
I am trying to instal a new copy of xp professional in a AWRDACPI OF PHONIX THECHNOLOGIES.
different mainboard have a different shortcut key.. it's usually DEL, F12, F2.. just try any of this key to enter bios.
Sep 15, 2008 | Intel D915GAG Socket 775 Motherboard -...
Well I'm one of you guys so you can bet I was confused, this is a computer problem installing XP SP3 on my PC.
clean install ............. floppy... fdisk deleting all partitions first.... and then making a partition of the whole disk.. then formatting.... then do the install and of course ntfs.... and see how that goes
Robert
Sep 01, 2008 | Intel Motherboard
No video in Live/Recorded TV
  • try installing the necessary video codecs required to playi.e., based on which format your tv tuner plays,also install the software once again from your tv tuner cd
Nov 05, 2007 | Microsoft Windows XP Media Center Edition...
EliteGroup 915G-M Motherboard Logo
97 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
