My GE Profile washing machine will not drain at all , it washes fine but does not drain Model # S3200YIWW
  • 2 more comments
  • kwood698 Nov 17, 2009
    wherre is the main access panel what does it look like and where is it and how is it removed
    are u still available
  • kwood698 Nov 18, 2009
    It is not the drain we pulled it all apart nothing stuck it seems to be like a sensor or something , it did start to drain but stops as the water gets a little low but did workif u mess with the tub . seems to be a glitch in the position when it switches to the drain spin cycle/
    If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
    To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
    Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
    If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
    Let me know, if needed further assistance.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    That solution did not work there is nothing stuck the washer seems to have a glitch when it goes to the drain spin cycle like if we mess with the tub it starts again. I dont know if it is a wire somewhere or a sensor or the door closure
  • 17,970 Answers
It possible something is jamming pump impellor, like a coin or hair pin, or pump itself is seized, or impeller is broken or loose.
Remove front panel, there are two clips in between front panel and top that you have to push in with metal putty blade or thin slot screw driver while pulling front panel away on either then pull up from bottom clips. Shop vac water from machine clamp off hose going from tub to pump.
Lean machine back if poosible so remaining water goes to back of tub, remove hoses, remove wiring to pump.
Unscrew pump from base observe inside ports for objects or broken or seized impeller on shaft if there things in pump remove them reatach wires put machine to drain or cancel and see if pump impellor turns freely, if so reassemble and try, otherwise buy new pump. Not very expensive.
Hope helped.
Posted on Nov 18, 2009
Testimonial: "cant do that i weigh 100 lbs. but thank you "
  • 10,515 Answers
Hope i helped you.
Posted on Nov 17, 2009
  • taran_2005
    taran_2005 Nov 17, 2009
    Thanks for your response!!
    Access Panel means the you need to open the washer. Read the below article that would tell you What i meant :-
    http://www.essortment.com/home/household...
    Thanks!!
Our ge washer will not drain water out before it goes to spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 23, 2011 | GE Profile WPSR3120WWW
My ge profile washer will not spin
heatman101
Jan 18, 2011 | GE Washing Machines
My GE Profile Prodigy WPSE4200A Washer does not spinning for drying and it smells like burning rubber. But it does aggitate for washing. It is a belt issue or could be some electronic device issue?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Oct 03, 2010 | GE Profile Prodigy WPSE4200A
GE top load Profile washer. Spin cycle not
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Ge washer # WBVH6240FWW
We have a GE washing machine that works fine with no load, but will not finish the cycle with a full load.
Aug 15, 2008 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
191 people viewed this question
Top Washing Machines Experts
