Question about Kenmore Sewing Machines
WHY DOES THE BOBBIN KEEP POPPING OUT.... - Kenmore Sewing Machines
  • 5,603 Answers
Depends what type bobbin you are using and the machine.
Was just told today to use the plastic bobbins that have the sides slightly angled and smooth. The METAL ones with holes have a core that is out too far and the thread catches on it as it passes over the bobbin.
Posted on Nov 18, 2009
The bobbin won't stay in place
Your bobbin is too short. The correct bobbin must be even with the bobbin case. If it is the bobbin case that is moving around then you must adjust the inner rotary hook bracket assy. It must allow the thread to move between the corner (near screw) and the bobbin casing. Rotate the hand wheel towards you to make sure the thread fits between the corner and the casing. Make it as tight as possible without a snag taking place.
Feb 14, 2015 | Brother SE400 Computerized Sewing and...
Janome sewist 525s my bobbin shuttle keeps popping out
try another bobbin, that one might be warped
use a can of computer air in the bobbin area for lint
if the problem persists then the machine should be checked
Mar 29, 2014 | Janome Sewist 525S Mechanical Sewing...
Singer 2662 bobbin case keeps popping out.
Check our bobbin for burrs and damage. If the thread catches a rough edge it can pop the bobbin out. Try a different bobbin with new thread... see if that helps. If it does your current bobbin is likely trash.
Hope that helps.
Jul 14, 2012 | Singer 2662
The bobbin case keeps popping the bobbin up when trying to sew. How do you fix this problem?
Hi Kathy it sounds like maybe something is in/under your bobbin case. If you have a manual it should show you how to take the bobbin case out and clean it. Hope this helps
Jun 18, 2012 | Sewing Machines
The bobbin case on my singer 5050 keep popping up?
is this a top or front or side loading bobbin case?
Jan 16, 2012 | Singer 5050 Mechanical Sewing Machine
My bobbin keeps popping out. There is a small hole under the bobbin casing. I pulled what appeared to be a wick out of there. It was frayed on the end and I thought it was part of my tension problem. Is...
Hi, the wick will not interfere with your tension, it is there to oil the hook shaft.
If you e-mail me at dupina@mweb.co.za i will send you the instructions and pictures on the bobbin case settings. Take special note of the retaining bracket, plate spring position and the Reverse rotation stopper. It sometimes happens that the reverse rotation stopper bends upwards, allowing the bobbin case to move underneath it. Press it slightly down to prevent this.
Aug 25, 2011 | Singer Touch Sew 7462 Mechanical Sewing...
MY THREAD KEEP BRAKING
it could be several things
check the needle to see if bent-roll on flat surface to see if it roll correctly
if the needle makes a popping sound when it penetrates the fabric is blunt
check to make sure the needle is not in backwards
check upper tension it may be to tight
thread may be hanging up in bobbin area-clean bobbin case area for lint or loose threads
check to make sure the thread is not caught somewhere
try using different thread
Sep 02, 2010 | Singer CE-200 Quantum Futura Computerized...
My machine seems to jump alot and the underneath stitches are just tying itself into lots of knots.
Is it just the bobbin that is jumping? This will happen if you have the bobbin in upside down. Both sides look the same, but you want to make sure the bobbin will turn in the same direction as the little arrow on the metal right by the bobbin slot. If you goof, the bobbin will keep popping up and down and you'll get knots.
Jul 02, 2010 | Janome 1017 Mechanical Sewing Machine
Brother LS2020 Unable to sew because bobbin locks up
Okay I think i can help- i have mastered the lower bobbin threading after 4 hours and am now trying to sew but thread keeps bunching up. Anyway you have to line finger of boobin in the top notch, this will keep your bobbin from getting stuck. Hope i helped Lesnbek
Jan 13, 2009 | Brother LS2020 Sewing Machine
Sewing Machines Logo
64 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
