Televison & Video Logo
Anonymous Posted on Nov 17, 2009
Moving a Mitsubishi HD1080 Medallion series 55
I bought a Mitsubishi HD1080 Medallion series 55'' TV in 2003. I now have to move it across town. Is there anything I need to know about moving it?
Anonymous
Level 1:
Scholar:
  • Contributor 39 Answers
  • Posted on Nov 17, 2009
Anonymous
Contributor
Level 1:
Scholar:
Answers
39
Questions
0
Helped
10668
Points
92
Actually no just need to HANDLE WITH CARE and make sure you protect the screen,you can cut a piece of cardboard same size of you screen to protected from any object,you TV has mirrors inside just be careful,other then that you will be OK.
Regards
Testimonial: "Thank you very much."
Distorted picture after moving across town
You may have knocked your guns out of alignment. There should be calibration settings in the main menu. Can you post a picture of the display so we can see what you mean by "distorted."
8helpful
2answers
I have an mitsubishi medallion hd1080 big screen tv model# ws-55819 getting code 1,2. (hold the menu and input)
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
I bought a Mitsubishi HD1080 Medallion series 55" tv back in 2003. I just recieved my new upgrade Direct tv reciever box. Now my tv screen says it has been locked and I need a passcode to un locke it? I...
On your Mitsubishi remote you will have a QV (Quick View) button. When the television asks for the code, just press and hold the QV and then number 9 button at the same time and it will unlock the set.
I would also go into the main menu and remove the code using the same procedure.
I hope that this helps you resolve your issue.
Thanks for using Fixya
asnowman
1helpful
Red streaks across my screen of my tv
is it like a double image kind of thing?i dont know what 'red streaks' are....
HELP
how many times does it blink it should blink a two digit code. let me know the sequence of blinks as it should be a self diagnosis code
23helpful
3answers
Manual mitsubishi medallion hd1080
MY MEDALLION WILL NOT TURN ON THE GREEN LITE IS GOING ON AND OFF THAT SAYS TIMER ON CAN U TELL ME THE PROBLEM.
Pinching in at the sides and has blurry rainbow coloring on top and bottom.
Sounds like a pincushion problem. You can obtain the service manual and free diagnostic upport at the following link. Hope this helps.
http://servicemanuals.vstore.ca/
Mitsubishi WS55809 "red" converge problem
Proper description is convergence IC ...part # STK392-570...
there are two in model # WS 55809...replace both.......T.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
