Question about LG VX-8700 Cellular Phone
Im having problems with the speaker in my phone, It seems i have a bad contact between the lower part and the upper part of my phone for the speaker signal, I don't hear a sound. If I close the flap just a little bit to change the angle, i get the sound. If i put it on speakerphone, it helps, but sometimes, i dont hear anything there also. Is there anything I can do at home to correct the problem? I am an electronics technician, so i have probably everything i need to fix this, I just need some pointers. Thanks Francois G.
My sony ericsson has stopped playin my ringtones and is totally silent i have checked all my settins and everythin seems fine
When you go to set your ringtone, if it plays from there then it may be a problem with the settings still. If not, then you may have bad speakers or wiring. Best thing to do is check your warranty, if it is good then contact http://www.sonymobile.com/us/support/
Sep 20, 2012 | Sony Ericsson Satio Cell Phone
I have got Nokia E63....my phone is not ringing... every time when i got incoming calls or messages...it just vibrates..even i can't listen to music by my music player..there is no problem in my...
It seems the speaker or buzzer is already busted and need replacement.sometimes it happens when the phone drop on the ground or been playing sounds fully loud for a long time.parts is available in any mobile service shop near you.
Jul 11, 2011 | Nokia E63 Cell Phone
When im talking on the phone the other person can hear me but i cant hear them
then the speaker seems off. Did you drop the phone. Its most likely the contact are away from the speaker. Try to call using the headset supplied. If that works you need to bring the phone in for repair. If its out of waarenty you need to open it and restore the contacts to the speaker by gently prying the contact up a little and clean with some alcohol
If you never opened a phone before visit a phone shop.
good luck
rene
May 28, 2011 | LG Xenon GR500 Cell Phone
Enough hot water for 1 bath. Replaced upper and lower elements and replaced both thermostats. could it be a sedament problem? heater is 5 years old. I never ran out of hot water before now.
You have 240Volt Marathon water heater.
These heaters have element burn-out problems.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Yes sediment can cause decreased amount of hot water when water cannot circulate around lower element, and sediment can cause lower element to burn out.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Following list is overview of tank troubleshoot:
If you have some hot water, then that says several things:
-Upper element is working.
-Electricity from circuit breaker to upper thermostat is good.
-ECO reset button is not tripped.
-You do not have overheating event.
-Access doors and insulation are in place and thermostat not exposed to cool temperature that causes overheating.
That leaves following suspects:
1) Check if TP valve is stuck open, or pipe cracked, or faucet leaking and running hot water down a drain.
2) Upper or lower thermostat is bad.
3) Lower element is bad -and- maybe tank has built-up sediment
http://waterheatertimer.org/How-to-test-water-heater-element.html
4) Loose wire. Open covers and inspect. Tighten screws very tight against copper wire.
5) Bad wire between upper and lower sections of tank.
6) Do complete 30 minute troubleshoot before replacing any parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater or any do-it-yourself project.
We are always less expensive than a service call.
Jan 25, 2011 | Rheem MR105245 Marathon Electric Water...
Upper Oven doesn't heat in bake or broil. Lower /Ctrl panel OK
check to see if both ovens are the same circuit if they are you have a internal problem with your upper oven internal circuits or damaged wirering contact a qualified service tecnitian
Oct 07, 2009 | Ovens
Burns [blows out the 50v bridge rect] on power up. cant find the short??? all conds and resistors seem to check out OK ??? The four Z-diodes seem ok also ??? All transistors seem ok [no low ohms-only...
I'd suspect the 6800uF caps, but I don't know for sure.
If it helps, here are the schematics for the upper and lower boards:
Upper board
Lower board
I wrote to KLH to ask for them, and explicitly asked for permission to post them here.
Jun 15, 2009 | KLH ASW10-120 Subwoofer
Mobile speaker
Try adjusting the volume using the volume keys on the right side of the phone, try to lower it then make it higher if you are able to adjust it means there is no problem with the volume.try to have it checked in a repair shop cause in some cases the speakers migt have a defect or needs to be cleansed.
Jan 07, 2009 | Nokia 5300 Grey Cellular Phone
LG VX-8700 Cellular Phone Logo
79 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
