Question about RCA Chaplin 841.670 Shelf System
Driver belt How do I put the driver belt back on? The turntable wouldn't turn so I took it off and the belt was just laying in there. I can't figure out how it goes back on.
  • 2 more comments
  • Anonymous Apr 28, 2008
    Turn table won't turn. All that shows up is Error
  • dumdittyqeen Dec 08, 2008
    Turn table doesn't work. Are the belts inside the wooden box or outside?
  • distantbird May 11, 2009
    The belt came off my record player, a Sherwood Belt Drive Semi Automatic Turntable System PS 1870. I saw that the belt is bigger than just the the two "finger-like" pieces that stick up underneath the table. What else might it need to go around?
  • distantbird May 11, 2010
    If I just put the belt around the two "fingers" there is way too much belt. It must need to fit around another part, but its not obvious to me what else it goes around.
    Scholar:
  • 70 Answers
This is for ANY belt driven turntable.
The belt is usually directly beneath the platter (the part your record sits on). If you lift this up and out of the way there are two wheels, a small one from the motor ( less than 1" in diameter) and a larger one (usually more than double the size of the small one). The belt goes on around both of these. So the setup looks like a rubber band between 2 fingers...
Jeff
Posted on Jan 11, 2008
    New Friend:
The belt for the Sherwood ps1870 goes around the raised 'lip' on the underside of the metal plate. Put the plate back on then gently grab the belt through one of the large holes in the plate and move the plate around till you get to the small brass coloured turning knob (located towards the front left of center) and hook the belt around that making sure you have not twisted the belt. Put the rubber mat back on the silver plate and your good to go. Hope that made sense!
Posted on Jul 07, 2013
You mean like around the 2 fingers?
Posted on Jul 13, 2008
Kenwood KD-491F belt come off How do I put it back?
You have got to lift the table on which the vinyl is placed underneath you will find the belt laying loose on the bottom of the table is a pulley on you fit the belt then on the right hand side or rear is the pulley on the motor which the belt also has to be fitted then carefully lower the so as not to let the belt come off again this should provided the belt is not stretched or snapped then it will have to be reaplaced
Oct 11, 2010 | Kenwood KD-291RC Turntable
The belt came off on my Technics Model SL-B30 turntable, and I don't know how to put it back on. I took off the table, but was unsure of how to position the belt. Can you help? Thanks! Eddie K
there should be slots under the turntable mat big enough to get your fingers in. make sure the belt is around the table pulley set it on the middle spindle and then put the held part of the belt onto the motor spindle. then you have it. good luck..
Mar 09, 2010 | Audio Players & Recorders
The rubberband came off the turntable, and i was wondering what the pattern is to put it back on. thank you
Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
Jan 04, 2010 | Kenwood KD-291RC Turntable
The drive belt on my Aiwa px-e860 turntable has come off. how do i put it back on
Dec 14, 2009 | Aiwa PX-E860 Turntable
How do I put my belt back on the turntable?
Oct 20, 2009 | Sony PS-LX250H Turntable
Belt location
1) Remove the platter - just lift up
2) Underneath the platter, you'll see a small lip section
3) Wrap the belt around this lip
4) Put platter back on turntable
5) Rotate platter until you see the motor shaft through the holes on the platter - a brass round looking piece
6) Pinch the belt around the motor shaft.
7) That's it.
- OPTiC
MasterTech
Digital Analog Therapy
Turntable Parts : Turntable Repairs
Jul 18, 2009 | Audio Technica USB Turntable
Ion turntable
7) That's it.
- OPTiC
MasterTech
May 09, 2009 | Technics SL-1200MK2 Turntable
Old record player spins too slowly
it sounds as if the rubber belt is to slack however also worth checking ithe attachment to the spindle itself is not loose 2make sure the belt is the correct type
Feb 09, 2009 | Crosley Traveler Turntable
Pioneer pl 990 turntable
Lift off the platter mat, then lift off the platter from the spindle - gently.
Underneath the platter is a sub-platter around which you place the belt - it should be held there by the stretch of the belt while you turn the platter back up the right way and place it back on the spindle.
Turning the platter by hand, you should see a small pulley come into view through one of the holes in the platter. You then stretch the belt slightly so that it slides over the pulley. Take care not to twist the belt while doing this.
Jan 10, 2009 | Pioneer PL-990 Turntable
Stopped Turning
I had a similar problem, what I ended up doing is taking it apart and jiggling the wires, the motor runs now, but when i opened it up, the belt was losely laying there, how do i put the belt back on? thanks.
Dec 13, 2007 | Crosley CR49 Shelf System
RCA Chaplin 841.670 Shelf System Logo
341 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
