Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
I have smoke coming out of the freezer fan grill and water dripping outside on each side of the shell between the freezer and refrigerator. What is the problem?
    Problem Solver:
  • 23 Answers
There is smoke with burning smell and smoke without smell that is fog like.if the first on your freezer fan burnout if second on your fridge drain blocked.
Posted on Nov 17, 2009
  • 11,896 Answers
Your drain may be plugged and water is getting onto the fan's electrical.
Go to back of the unit, remove access panel, check that the little drain tube is dripping water into the evap tray. Tray should be somewhat wet. You can use pipecleaner or coathanger to check for clogs in drain. Or cut the bottom rubber piece off to allow better flow..
Water draining into freezer Maytag MFX2570AEM
Certainly should be, if it is a blocked drain tube and not a broken fan or defrost unit.
Assuming this appliance to be a frost free unit, generally (as I don't know this particular unit), there should be an outside access panel on lower rear of unit. Behind this, you should see the compressor (large round or square sealed container) and a drain tube leading to it or to a receptacle on it, which allows the defrost water to drain from the freezer compartment, and evaporate using the heat of the compressor. It will be this drain tube that may be block with food debris or even (as I found on mine) a plug of mould. My tube just pulled off and I was able to completely clean through with fresh water. Inside the freezer, there must be a drain channel leading to the drain tube outside. This may be visible or hidden behind panelling and, If the outside drain tube was blocked, will probably be full of iced up defrost water and will need to be cleared, either by leaving unit switched of or, by careful use of a hair dryer - GENTLY - so as not to warp the plastic insides. Once this is cleared, ice can then melt off the hidden freezer grills when on defrost cycle and escape correctly to the outside for evaporation.
Mar 30, 2014 | Maytag MFX2570AEM French Door Refrigerator...
How do i remove a drip pan from a kenmore refrigerator
The drip pan collects water when the freezer goes into a defrost cycle. Most times there is very little water and the water evaporates quickly. When there is a problem with the freezer or the water does not evaporate between defrost cycles, the drip pan fills with water. If the front bottom of your refrigerator has a grille, you access the drip pan from the front. If there is no grille, access the drip pan from the rear.
Instructions
Rear Access
1 Unplug the refrigerator from the wall outlet. Pull the refrigerator away from the wall so that you can access the rear of the refrigerator.
2 Look under the refrigerator with a flashlight and locate the drip pan. Often when people install refrigerators they neglect to pull the packing from around the drip pan. The drip pan may have tape or styrofoam around it.
3 Remove any packing material away from the drip pan and pull the drip pan out from under the refrigerator.
Front Access
4 Pull the grille at the bottom of the refrigerator below the refrigerator door with your fingers. The grille secures to the refrigerator with plastic clips.
5 Remove any debris from the access area and throw the debris in the trash. The coils and fan under the refrigerator attract dust and dirt. Clean out the area with a lint brush if you have one.
6 Pull the drip pan out from under the refrigerator.
Apr 20, 2012 | Kenmore Refrigerators
Outside ice despenser is dripping, no ice
water dispenser -Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
ice maker - If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 30, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE side by side refrigerator smells on the outside!
Mix 1/3 cup of bleach and 2/3 cup of water , and pour down drain tube (rear bottom in freezer section . Too much bleach and the smell of bleach would be circulated by the fan to the room , so be sure to add water .
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leaking from icemaker on outside
If this is your water dispenser leaking
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
GE SIDE BY SIDE/MODEL #GSS25JMDCC
I also had a loud fan and it was caused by ice build-up on the fan in the back of the freezer. From inside the freezer, I removed the plastic grill that covers the fan (I think I also had to remove the side rails and ice maker) then just let the fan defrost in the sink. Made sure it was nice and dry before putting it back in or else ice would just form again. I also took a sheet of plastic and put it between the ice maker and fan grill to stop water from dripping onto the fan and haven't had a noisy fan since. I just need to remove the ice build-up from on top of the plastic sheet every now and then, but that's much easy than taking everything apart to get to the fan.
Feb 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
We have a side by side refrigerator/freezer. a water drip runs down the grille on the freezer side. a small amount. we cannot locate where the water comes from. Can you help?? model #ed20tqxfn00 Al...
If you have ice and water in the freezer door it would appear that the water line going to the water dispensor has a leak. First check where the door hindges at the bottom as this is where the line runs from the water container located in the fresh food compartment to the water dispensor in the freezer door.
Jul 07, 2008 | Whirlpool Refrigerators
Whirlpool Gold GS6NBEXRB01 - While Auto-Defrosting, the water drips into freezer from inside Grill
you have a frozen or blocked defrost drain behind the back panel with the vents in it remove the panel and clear the drain at the bottom in the silver pan
Jun 03, 2008 | Whirlpool GS6NBEXR Side by Side...
Frigidaire side by side refrigerator problem
is it coming from underneath or out of the units refrig or freezer bottoms ??
Jan 26, 2008 | Frigidaire FRS26R4A Side by Side...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
802 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
