Question about Fargo Persona C30 Thermal Card Printer
Ribbon keeps breaking - cards get stuck, or cards come out in funy colors
    Problem Solver:
  • 14 Answers
Try to run the diagnostic utility as instructed
clean the printing path by fargo cleaning kit
Posted on Jan 11, 2010
Printing to dark and intense. tightened screws now the ribbon keeps breaking and not print properly
It's hard to say based on the fact that your have already tightened screws. Without knowing which ones this may have caused the issue. One of the screws on the printer head is a set screw for the angle. If this is not set correctly it may break the ribbon. Based on your description of the colored ripples this means you are printing too hot and the ribbon is wrinkling under the heat. The only way to adjust this is to alter the printers internal head resistence settings. You would either have to succefully print a test card, or look at the under side of the print head to find the value. This should not be adjusted more then 300 points from the default value on the print head itself. to adjust go to printers and faxes, and right click the printer, go to printer properties (or just properties), device options, tools, properties, in the command line you must put the new value.
!R_XXXX ( where "_" is a space, and the xxxx is the value on the print head. hope this helps.
Oct 13, 2012 | Zebra P330i Thermal Card Printer
Have tried to tape, wind, etc. as shown in the instruction manual but it repeatedly breaks. Interestingly enough when it does break it is always on the yellow panel which is entirely imprinted on the...
Ribbon breaks on those older models are usually traced back to only a couple of things.
1. The ribbon-type may be set incorrectly in the printer driver. The C30 and C30e color ribbon type if doing single- or dual-side printing in full-color is #044200 - YMCKO; the ribbon type if doing dual-side printing with full-color front and black-only back is #044210 - YMCKOK. Open the driver, then "Printing Preferences", select the "Device Options" tab and verify that the ribbon type setting matches what you're using. Note that you can only make a change to the setting if you have sufficient (Admin) Windows privileges.
2. There is a mechanical issue with the printer, where an o-ring is broken, or the head-lift motor has gone out. Either is very bad, as the printer has long been out of production and parts are no longer available. (But you can contact us for a replacement - new or refurbished!)
Nov 18, 2017 | Fargo Persona C30 Thermal Card Printer
DataCard printer ribbon breaks
First, what color is it breaking on? Yellow, Magenta, Cyan, Black, Topcoat?
Next, I would do is clean all the rollers in the printer with isoprophyl alcohol (99% if you can find it, 91% is ok, 75% is you're in a bind). This is a common problem
Then, load the Printer Diagnostics from your print driver CD. In diagnostics, you can set the BASE POWER for YMC, K or Topcoat. The base power is totally different from intensity. As the printhead gets old, you may need to back off the intensity to keep the ribbon from breaking.
Lastly, take a look at the ribbon:
Is the image placed in the same spot of the ribbon on each panel or does it move (creep) higher or lower? This creeping action is caused by many things and would be best to be serviced by a technician.
Finally, printhead replacement. About $695 MSRP
May 26, 2009 | Datacard Group ImageCard Platinum Printer
Ribbon is breaking constantly in every print of card
in order of most likely
1 edge to edge settings in printer tool box are off.
2. print ribbon carriage (blue part you put the ribbon on is bad)
3. Bad ribbon
4. dealer needs to service to calibrate print head temp
tulsabiz.net for more info
Mar 27, 2009 | Datacard SP35 Printer
Printer keeps breaking the ribbon
first, try to calibrate the ribbon, if it does not work, you probably have worn out rollers, and possibly a broken o-ring. if you want more info, call us at 310-671-8018, thanks adi
Mar 25, 2009 | Fargo DTC400 ID Card Printer Package
It might be because the printhead is heating up too high, and burning the ribbon.
Try lowering the heat in the driver.
Dec 31, 2008 | Fargo Persona C11 Thermal Printer
Ribbon Breakage
You can try to lower printhead setting values (color and black), if not resolved then try another ribbon, old ones trend to fail this way.
Regards
Jul 10, 2008 | Zebra Eltron P310I Thermal Card Printer
Data card sp35 plus ribbon break
There could be either of the following issues:
1. Check the print head temperature to make sure that it is hot enough to transfer the ribbon to the card.
2. The surface of the PVC card may not be image compatible. Try another brand of card or opt to 60/40 composite cards for testing.
For technical assistance by blog for id card printers, see our blog at www.safecardid.com/blog/
Jun 20, 2008 | Datacard SP35 Printer
Fargo Persona  C30 Thermal Card Printer Logo
669 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
