Question about Casio fx-300ES Calculator
What do i key in for 2 to power of 12?? - Casio fx-300ES Calculator
  • Casio Master
  • 8,068 Answers
Between the x`squared key and the log key there is a key with an x with a raised small figure of a solid square. That is the key you use to enter arbitrary exponents.
  1. If calculator is in MathIO ( a Math indicator appears on the upper band of the screen), enter the base of the power (here 2). A number 2 with a raised empty square appears.The cursor will blink in the raised square. Enter there the exponent (here 12) and press [=]. Result 4096 appears at the bottom of the screen.
  2. If in LineIO (no Math indicator appears on the narrow band at the top of the screen), press 2 and then the key I talked about above. On the screen a number 2 appears with a hat and a left parenthesis. Type in the exponent (here 12) , the right parenthesis and press [=]. The calculator should display 4096.000...
Hope it helps
Posted on Nov 17, 2009
Calculating chemistry 1 scientific equation divided into another?
Use the rules for exponents and you will calculate it by hand
(1*10^-14)/(5*10^-12)=(1/5)*10^(-14+12)= 0.2*10^-2=2*10-3
To enter powers of 10 use the short-cut key [EE]
For example to enter 6.02*10^23 type in 6.02* [EE] 23. When you use the EE key, the base (10) should not appear.
Apr 06, 2014 | Texas Instruments TI-30XA Calculator
When I plug my scanner in to the dlc the scanner turns on with the key off but when i turn the key on the scanner has no power and won't communicate i had a blown fuse and replaced it but still...
all diagnostic link connectors with 16 terminals the the 16th terminal bottom far right the OBD 2 DLC IS THE 12 VOLTS POWER SOURCE TO POWER UP SCANNER.IF YOU NOT GETTINNG 12 VOLTS AT 16TH TERMINAL YOU HAVE PCM PROBLEMS.
Nov 09, 2012 | 2002 Ford Taurus
Please give me a power dvd 12 ultra working serial key
Download link: http://filesmy.com/2n7rs for CyberLink PowerDVD 12 Serial Key + Crack .
You can activate PowerDVD 12 Ultra free in no time. Instuctions are in the file and the video on link Free CyberLink PowerDVD 12 Serial Key and Crack .
Apr 21, 2012 | Computers & Internet
How do I do like 12 to the 252 power
1 2 ^ 2 5 2 =
The ^ key is above and left of the 7 key. This is the key you use for raising a number to a power. If you don't get the correct answer, it's because 12^252 is outside the range of the calculator.
Apr 11, 2011 | Texas Instruments TI-30 XIIS Calculator
2002 NISSAN SENTRA DIED WHILE DRIVING KEY ON ENGINE OFF .NO ENGINE LITE .NEITHER ENGINE OR NATS PROGRAM WILL PULL UP WITH CONSULT 2.REPLACE ECM NO CHANGE .POWER TO RELAY 1 AND 2 6 AND 7 ----- 3 AND 5 NONE...
Hello! There isn't power to ECM pins 109 and 111 because the ECM relay is not pulling...Pins 1 and 3 (White/Black wire) are tied together in the harness and should not show a change in symptom if jumped together...Also, Pins 1 and 3 are fed battery from fuse # 36 (15A hot at all times) and both pins must read +12 volts...Pin 2 of the relay coil is the pulling ground from the ECM...Reading across pins 1 and 2 with the key in the ON position should not read +12 volts...If it does the relay coil is open...With the key on the relay would show a voltage drop across the coil...Check pins 1 and 3...must be tied together and have +12 volts from fuse # 36 (15A hot at all times)...Replace ECM relay...See photo...............Guru....Saailer...
STANDARD MOTOR PRODUCTS Part # RY412 Cost
Jan 26, 2011 | Nissan Se R Cars & Trucks
How to find nth root using Casio FX-83ES
You use the power root function key accessible with the key sequence [SHIFT][X ^]. I am inserting a screen capture from the manual to show you the sequence.
On the third line of the capture (power root) is the key you must press. In the small rectangle to the left of the radical sign you enter the order of the root: 2 for square root, 3 for cube root, 4 for 4th root and son on.
To calculate the decimal log you use the [LOG] key as shown on capture. For natural log (ln), use the [LN] key. The argument (2/3) in your example should be enclosed inside the parentheses.
Jun 04, 2010 | Casio fx-300ES Calculator
I want to know how to key in to calculate 2 to the twelveth power to get anser.
You should specify your calculator and avoid posting the same question multiple times.)
Here is the solution for FX-300ES
Hope it helps
Nov 17, 2009 | Office Equipment & Supplies
2 to the twelve power equals what
In the exemples above I used 2^12. But you can enter any base (2, 3, 5.5, 16/47, ) and any exponent ( 12, 13/48, 0.007654, even negative values).
Hope it helps
Nov 17, 2009 | Casio Office Equipment & Supplies
Basic Q's
The LOG and LN keys do what you have done.
To get 9 to the 16th power, enter 9, "y to the power x" (under the OFF key) then 16, then =
3 to the 12th power is the same, enter 3, y to the power x, 12, =, result 531,441
The inverse key sequence: value 1, 2nd, y to the power x, value 2, returns the xth root of y, e.g. 531,441, 2nd, y to the power x, 12, =, gives you 3 back
Sep 07, 2008 | Texas Instruments TI-30XA Calculator
Audio settings
default values of the secret E370 audio menu by inputing *#8999*8378*
Normal
MIC gain - 0
Tx PGA - 70
Side PGA - 0
Ear gain - 3
HFR gain - 9
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv3 - 11
Rx comp - Lv 4 - 29
Rx comp - Lv 5 - 30
Key vol - Lv1 - 64
Key vol - Lv2 - 64
Key vol - Lv3 - 64
Key vol - Lv4 - 64
Key vol - Lv5 - 64
Headset
MIC gain - 0
Tx PGA - 64
Side PGA - 0
Ear gain - 13
HFR gain - 3
Rx PGA - 128
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 20
Rx vol - Lv 3 - 42
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 146
Rx comp - Lv 1 - 11
Rx comp - Lv 2 - 11
Rx comp - Lv 3 - 11
Rx comp - Lv 4 - 30
Rx comp - Lv 5 - 28
Key vol - Lv1 - 10
Key vol - Lv2 - 20
Key vol - Lv3 - 42
Key vol - Lv4 - 76
Key vol - Lv5 146
Loud SPK SUP
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK SDN
MIC gain - 0
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK EXT
MIC gain - 1
Tx PGA - 226
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 92
Rx vol - Lv 1 - 16
Rx vol - Lv 2 - 27
Rx vol - Lv 3 - 45
Rx vol - Lv 4 - 76
Rx vol - Lv 5 - 128
Key vol - Lv1 - 5
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Loud SPK Out Only
Tx PGA - 160
Side PGA - 0
Ear gain - 12
HFR gain - 5
Rx PGA - 120
Rx vol - Lv 1 - 10
Rx vol - Lv 2 - 28
Rx vol - Lv 3 - 40
Rx vol - Lv 4 - 50
Rx vol - Lv 5 - 96
Key vol - Lv1 - 1
Key vol - Lv2 - 2
Key vol - Lv3 - 3
Key vol - Lv4 - 4
Key vol - Lv5 - 4
Yamaha AMP vol.
31
Yamaha MEL vol.
Normal
Lv 1 - 6
Lv 2 - 12
Lv 3 - 18
Lv 4 - 24
Lv 5 - 31
Melody key
Lv 1 - 2
Lv 2 - 4
Lv 3 - 11
Lv 4 - 18
Lv 5 - 25
Power on/off
Lv 1 - 1
Lv 2 - 10
Lv 3 - 14
Lv 4 - 18
Lv 5 - 22
ISS Normal
Ear gain - 12
HFR gain - 3
Rx vol - Lv 1 - 121
Rx vol - Lv 2 - 186
Rx vol - Lv 3 - 268
Rx vol - Lv 4 - 376
Rx vol - Lv 5 - 564
Rx vol - Lv 6 - 802
Rx vol - Lv 7 - 980
Rx vol - Lv 8 - 1560
Rx vol - Lv 9 - 2167
Rx vol - Lv 10 - 2863
ISS Headset
Ear gain - 10
HFR gain - 3
Rx vol - Lv 1 - 164
Rx vol - Lv 2 - 328
Rx vol - Lv 3 - 492
Rx vol - Lv 4 - 656
Rx vol - Lv 5 - 820
Rx vol - Lv 6 - 984
Rx vol - Lv 7 - 1148
Rx vol - Lv 8 - 1312
Rx vol - Lv 9 - 1476
Rx vol - Lv 10 - 1640
Bluetooth
Tx PGA - 255
Rx PGA - 12
Side PGA - 0
Oct 04, 2007 | Samsung SGH-E370 Cellular Phone
Casio fx-300ES Calculator Logo
165 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
