Question about Sony Ericsson w580i Cellular Phone
The phone is on vibrate mode but it won't vibrate
How can I open my nokia E73 ? because it can't switched. every i tap the button of the power it only have vibration.
Hi Karen, The link below is a YouTube video showing how to fix your phone, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
May 09, 2016 | Nokia E73 Mode Cell Phone
The vibrate mode on my phone will not work
Go to phone app, dial the following number-
*#0*#
You will get a screen with following options (Not All)
Click on Vibrations as shown above. If the phone vibrates, then there is some issue with Settings or Software. Restart or Reset should help you. Of it doesn't vibrates, time to visit the service center.
How to Fix Vibrate not working on my phone
Good Luck :)
Sours- How to Fix Vibrate not working on my phone
Feb 20, 2016 | Samsung Galaxy S6 Edge
IPhone won;t stop vibrating ,blank screen won';t charge help ??
If phone was dropped or got wet, it needs to be taken to a tech ASAP. Try restoring it, putting the device on DFU mode.
Nov 01, 2014 | Apple For iPhone 4/8GB LCD Screen...
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
CAN THE SAMSUNG C3050 VIBRATE WHEN THERE IS AN INCOMIMG CALL
Welcome to Fixya.
How to know if your Samsung Phone has a vibration feature.
Press and hold the # key. Phone will enter to silent mode. You will feel it vibrate. Select a phone profile and edit it. You will be able to find the vibration option in the "call type".
If the phone does not vibrate while entering the silent mode, it means it does not have the vibration feature.
Thank you for using FixYa!
Jun 17, 2011 | Samsung C3050 Cell Phone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Samsung d900
To place the handset in silent / vibrate mode follow the steps below: To place the handset in Silent Mode, hold down the pound key (#) for about 2 seconds. To exit Silent Mode, perform the same action while in Silent Mode. You will see a confirmation message for Silent Mode, each time you enter or exit Silent Mode. The phone will vibrate rather than ring when you receive a phone call, message or alert while in silent / vibrate mode.
Aug 23, 2007 | Samsung SGH-D900 Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
