I want to know how to key in to calculate 2 to the twelveth power to get anser.
  • Office Equip... Master
  • 8,073 Answers
You should specify your calculator and avoid posting the same question multiple times.)
Here is the solution for FX-300ES
Between the x`squared key and the log key there is a key with an x with a raised small figure of a solid square. That is the key you use to enter arbitrary exponents.
  1. If calculator is in MathIO ( a Math indicator appears on the upper band of the screen), enter the base of the power (here 2). A number 2 with a raised empty square appears.The cursor will blink in the raised square. Enter there the exponent (here 12) and press [=]. Result 4096 appears at the bottom of the screen.
  2. If in LineIO (no Math indicator appears on the narrow band at the top of the screen), press 2 and then the key I talked about above. On the screen a number 2 appears with a hat and a left parenthesis. Type in the exponent (here 12) , the right parenthesis and press [=]. The calculator should display 4096.000...
Hope it helps
Posted on Nov 17, 2009
  • k24674 Nov 17, 2009
    Do not forget to rate the 3 solutions Very helpful.
On calculator how to raise to the 5th power
Use the ^ key just above the divide key. For example, to raise 2 to the 25th power, press 2 ^ 2 5 ENTER.
Jan 09, 2014 | Texas Instruments TI-84 Plus Calculator
How to work to the 2nd and 3rd powers
Most calculators have a power key. It may be marked "^" or "x-superscript-y" or similar. This key can be used for any power, not just 2 and 3.
Many calculators also have a dedicated 2nd power key, typically marked "x-superscript-2". Some calculators also have a 3rd power key.
Nov 12, 2011 | Office Equipment & Supplies
I need to know how to put a number to the 20th power
Use the y^x key, just above the divide key. For example, to raise 2 to the 20th power, press
2 y^x 2 0 =
Feb 14, 2011 | Texas Instruments TI-30XA Calculator
I can see the x to the power 2 key is below PV key. But how do i calculate x to the power of 5 for example?
Use the y^x key just above the 9 key. For example, to calculate 2 to the fifth power:
2 y^x 5 =
Oct 13, 2010 | Texas Instruments BA-II Plus Calculator
I cant get a anser it comes out in scientific notation
Press [SHIFT][MODE] to enter the (SETUP) screen, then select the number to the left of FIX. Once you do you will be prompted to enter a number between 0 and 9. If you enter 4 all your decimal results will have 4 decimal digits. If you choose 0, all decimal numbers will be rounded to the nearest integer (whole number).
Regardless of the floating display mode (SCI, FIX or NORM) the calculator is configured for, the decimal results will be in SCIENTIFIC format if they are too small or too large.
May 21, 2010 | Casio fx-300ES Calculator
Fx-300ES Calculator: i cant get a anser it comes out in scientific nota...
May 18, 2010 | Casio fx-300ES Calculator
Codes for chorus mmds (EUROVOX)
These are only for boxes that work with Chorus digita MMDS not cable
hit menu
go to system information
hit ok
type 1969
go to navigation
bring up provider
if you are with chorus then
the codes are: PROVIDER ID 5E 01
KEY NUMBER 00
key data: CE 19 23 87 80 61 74 90
KEY NUMBER 01
key data: 62 FA 09 F3 CE 05 F4 79
make sure your provider name at the top is reading CHORUS if not go to the provider id and right arrow until 5E 01 appears and when you have changed the codes store and exit you should be laughing!!!
best of luck HAPPY CHRISTMAS!
chorus
00:CE 19 2E 87 80 61 74 90
01:62 FA D9 F3 CE 05 FA 79
Dec 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
How to get the square root using a ti-30xa calculator?
Come on now....there are dedicated "square" and "square root" keys on the TI-30XA....
Enter your number e.g. 4, then press the "root x" key to get 2...
Press "x squared" key to get the square of 2 = 4
There's the even more useful "y to the power x" key and it's inverse "xth root of y" key.
E.g. Enter 2, then press the "y to the power x" key, then 5, then =, answer is 32 (2 x 2 x 2 x 2 x 2). Starting with 32, pres 2nd then the "y to the power x" key, then 5, then =, answer is 2, the 5th root of 32....
Dec 01, 2008 | Texas Instruments TI-30XA Calculator
234 people viewed this question
k24674
jasbo
jasbo
