Question about Samsung 710N V2 17" LCD Monitor
Samsung 710N My samsung monitor, is blinking a few times for a 3 sec. And then comes black.I have tried with auto, but same thing happens.What can I do?
  • Djordje Jan 12, 2008
    I have tried on another computer but same problem accours.I guess something wrong is with electronics.Thanks
    Champion:
  • 238 Answers
Hi, try with another crt monitor to check if the display card is ok..if that works fine then u will have to take it to the service center.. let me know..
Posted on Jan 10, 2008
    Scholar:
  • 36 Answers
Hello
I am a technician-informatic. I have repaired about 80 Lcd Samsung monitors with theese problems. I offer the repair manual.
Manual has been done with the experience of the repairing Samsung Lcd monitors. Manual was made by me and shows how to open monitor, how
to solve dark screen problem, how to check and replace capacitors, how to solve the problem non-optimal mode (without reprogramming MCU or
changing the main board) photo are included. 100% functional. The repair process is very simple 30-40min. (does not need a lot of
experience in electronics and expensive instruments) and is not expensive. With this manual you can solve problems by yourself and save
money.
"Not Optimum Mode 1280x1024 60Hz"
- The monitor turns on but turns off by itself, the LED blinks green.
- If you detach from the PC points to "control cable" the picture runs continuously in the vertical direction or presents while line , and
as soon as it is reconnected, the monitor goes off.
- The monitor does not turns on and dont dispaly anything, the LED blinks green-lit, if you detach from pc points to "control cable".
- The monitor turns on, works well some time, but after a window apiers "Not optimum mode. Mode recommended 1280X1024 60Hz"
- The monitor turns on, works well only with low resolution 800x600, when try to change a window that reads "Not optimum mode. Mode
the manual you can find on ebay (my ebay name is asnerejas123):
Samsung monitor repair manual guide 710n,913v,510n more
220498646211
Riparazione - repair Lcd Samsung monitor 710n,913v,510n
220498645860
Reparaturhandbuch für Samsung 710n,913v,510n und andere
220499443698
Posted on Oct 27, 2009
Samsung SyncMaster 710N Monitor SLEEP MODE
The monitor is not going to sleep the power supply board is shutting down. If you can solder you should be able to repair the monitor yourself. The problem is caused by blown capacitors on the power board. Go to our web site at : www.ccl-la.com/badcaps.htm We have pictures of what to look for. Open your monitor and look at the power supply board for any blown capacitors, replace all that you find. The replacement parts can be ordered from several places on the internet or we can supply them for you. The replacement parts will need to be high temp and will be marked 105c. The values you need to get will be marked on the sides of the ones you take out but will be something like 220uf, 470uf, or 1000uf etc. and then a voltage rating. When you install the new ones be sure to insert them with the polarity stripe going the same direction as the old ones come out. If you don't want to do the repair yourself we do offer a repair service for $35 plus return shipping. If you have any questions just let us know
I hope this helps if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Oct 17, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Half of the screen is black - Samsung SynchMaster 710N
hello
money.
220498646211
220498645860
220499443698
Sep 05, 2009 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung 713N screen goes black
OK. IN XP GO TO DEVICE MANAGER AND CLICK ON THE MONITER AND UPDATE THE DRIVERS.IF IT TELLS YOU IT CAN NOT FIND A BETTER DRIVER UNINSTALL..REBOOT AND DOWNLOAD NEW DRIVERS FROM CO. WEB SITE.RICHARDM69
Aug 31, 2009 | Samsung SyncMaster 713N 17" LCD Monitor
Samsung 913N Monitor went out after a power outage.
try a known good monitor on the PC, is the light blinking green or orange?
www.aa1consuling.com
Jul 24, 2009 | Samsung 226BW Monitor
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
I have 2 samsung 710N LCD monitors that are exhibiting the same symptoms. When they are powered on, they display fine for about 10 seconds, and then go completely black. If you turn them on and off again,...
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
or just enter number in search field: 220409788372
thank you
Mar 19, 2008 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung 710n
Press menu button for more than 10 sec. Afterwards OSD menu should be unlocked.
Good luck
Jan 12, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Samsung syncmaster 711p power issue
Its a general fault however all these units are under a 3 year warrantee the dates printed on the back, just call 08706010309 speak to a service engineer and they will arrange a swap out within 5 working days, no need to a receipt as they can tell the units age from the serial. the replacement will be under the same 3 years cover in my case it was for another 6 months
Nov 24, 2007 | Samsung SyncMaster 931B 19" LCD Monitor
LCD problems... Can you help me?
it has nothing to do with your computer, if you put the monitor on a different computer it will do the same thing. the message comes directly from the monitor itself. you have to keep your screen resolution at 1280 x 1024
Mar 23, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Samsung 710N V2 17" LCD Monitor Logo
640 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
