Question about Nokia 6125 Cellular Phone
What can I do for start nokia 6125 ? or how can I format nokia 6125 ?
When I turn on the nokia 6125,start boot,display the image for 1 second,restart the boot atutomaticly for 3 times and after shut down automatical.how can I to format nokia 6125 ?
  • Anonymous Mar 25, 2014
    there is no signal available in the phone
  • 192 Answers
This is phone's software problem and it will not be put right by formatting etc. It seems that are corruption in it's system files and needs reflashing. Technician with smart software repairing tools only can do this for you.
Posted on Jan 10, 2008
2 Suggested Answers
SOURCE: when I turn on the nokia 6125,start boot,display
I have same problem and i didn't fix it jet. Where are the expert help us. Pleas hurry Up.
Posted on Jun 17, 2010
Blue creen with blinking cursor
you can do a clean install from your usb. i use this setup for all my flash drive boots.
WinSetupFromUSB - Install Windows XP from USB Flash Drive
This guide will show you, how to use WinSetupFromUSB to create a bootable USB Flash Drive including all Windows source files, plus the following installation of Windows XP. Compare to the different USB_Multiboot versions, WinSetupFromUSB comes with a Graphical User Interface (GUI) and is in my opinion easier to use.
Here you can get the latest version of the program and you will also find many detailed informations about WinSetupFromUSB.
I've tested this guide with a 32-bit version of Windows XP and a 64-bit version of Windows Vista and it worked flawlessly.
Prerequisites:
All you need is:
a USB Flash Drive with at least 1GB of storage
the original Windows XP Setup CD
WinSetupFromUSB
If you use nLite to slim down your version of Windows XP, please keep the following in mind:
DO NOT remove "Manual Install and Upgrade"
under Operating System Options!
I also recommend to integrate Service Pack 3 into your Windows XP source files.
1. Preparations
Download and install WinSetupFromUSB. Default installation path is C:\WinSetupFromUSB.
Create a new folder with the name WINXPCD in the root directory of drive C:\ and copy all files from your Windows XP Setup CD into this folder. Depending on your version of Windows XP, the content of C:\WINXPCD should look approximately like this:
Content of WINXPCD
The following files will show you, which Service Pack is already integrated into your CD:
WIN51IC.SP1, Sevice Pack 1
WIN51IC.SP2, Sevice Pack 2
WIN51IC.SP3, Sevice Pack 3
2. Start WinSetupFromUSB
Connect the USB Flash Drive to your PC and start WinSetupFromUSB. It should show up under USB Disk Selection :
WinSetupFromUSB - main window
3. Select your Source Path
Click on Browse under Windows 2000/XP/2003 Source and navigate to the folder with your Windows XP Source Files. It should be C:\WINXPCD:
Browse to Folder
Click OK and C:\WINXPCD should show up under Windows 2000/XP/2003 Source :
WinSetupFromUSB - source path
4. Format USB Flash Drive
PeToUSB or HP Format Tool are used to format the USB Flash Drive. There is no need to download these programs seperately as they are already included in WinSetupFromUSB.
USB Flash Drives up to 2GB should be formatted with PeToUSB in FAT16, USB Flash Drives with 4GB or more with HP Format Tool in FAT32.
I will use PeToUSB to format my Kingston Data Traveler with 2GB.
In the main window of WinSetupFromUSB click PeToUSB under Format target using to start the program. The USB Flash Drive should show up under Destination Drive. Check USB Removable, Enable Disk Format and Quick Format. Uncheck Enable File Copy under File Copy Options :
PeToUSB
Click Start and answer the following two questions "Continue?" with Yes.
All existing volumes and data will be lost!
If everything goes well, the message "Operation Completed Successfully!" should appear. Click OK and close PeToUSB.
The process with HP Format Tool is similar.
5. Copy Windows XP Source Files
To start the process of copying the Windows XP source files to the USB Flash Drive, click GO in the main window of WinSetupFromUSB. Depending on the write speed of your USB Flash drive it may take a while to copy all files.
WinSetupFromUSB - file copy
At the end the following notice about the Windows installation process should be displayed:
WinSetupFromUSB - notice
Click OK and close WinSetupFromUSB with EXIT.
6. Windows Installation - Part 1
Connect the USB Flash Drive to your PC and turn on the computer. Press ESC at the boot screen and you will be able to select the USB Flash Drive as your boot device from the boot menu.
The ESC key is used by ASUS for the Eee PC series.
Other manufacturers may use other keys, e.g. F8 or F12.
After booting from USB Flash Drive, the following menu should be displayed:
Windows XP/2000/2003 Setup - First and Second parts
Press Enter or wait 10 seconds to get to the next menu:
First part of Windows XP Home Edition setup
Second part of XP Home Edition setup+Start Windows for first time
First part of Windows XP Home Edition setup is already selected. Press Enter or wait 10 seconds to start the Text mode part of setup. During this part you can create, delete and format partitions and finally the setup files are copied to your hard disk. At the end the system will restart automatically.
7. Windows Installation - Part 2
After restart, boot the PC again from your USB Flash Drive. The same menu should be displayed:
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to start the GUI mode part of setup. During this part you will be asked for your product key, timezone, usernames and other necessary informations. At the end the system will restart automatically.
8. Windows Installation - Part 3
Second part of XP Home Edition setup+Start Windows for first time is already selected. Press Enter or wait 10 seconds to Start Windows for the first time. The Windows installation process will be finished and finally the Windows Desktop will appear.
DO NOT disconnect the USB Flash Drive too early!
At next startup you can boot into Windows from your hard disk.
Notes:
After successsful installation, the following boot menu will always be displayed during startup:
Please select the operating system to start:
Microsoft Windows XP Home Edition
USB Repair NOT to Start Microsoft Windows XP Home Edition
If you don't plan to use the repair option and want to boot directly into windows, you have to do the following:
Open the file boot.ini in the root directory of drive C:\ with Notepad:
[Boot Loader]timeout=30
Default=multi(0)disk(0)rdisk(0)partition(1)WINDOWS
[Operating Systems]
multi(0)disk(0)rdisk(0)partition(1)WINDOWS="Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
multi(0)disk(0)rdisk(1)partition(1)WINDOWS="USB Repair NOT to Start Microsoft Windows XP Home Edition" /noexecute=optin /fastdetect
Delete the following line:
DO NOT delete the wrong line!
Your computer may not boot the next time!
Save changes to the file.
At next startup the boot menu will not be displayed.
If you want to keep the repair option, you can reduce the time to display the operating system options from 30 to 5 seconds:
[Boot Loader]
timeout=5
At next startup the boot menu will be displayed only 5 seconds.
gd luck
Mar 09, 2014 | Computers & Internet
I had 6125 and he restarts he goes for 2 sec in
its a issue of installation software, so please formate & reinstall software.
Oct 28, 2009 | Nokia 6125 Cellular Phone
Hello, i have a latitude D 600 and tried to turn it on today, after the boot screen has shown and Microsoft started to load, the image on the screen started to blink and image was moving from bottom to top...
I think as per your question this seems to display resolution problem happens some time with games.
For this follow these steps
1. Switch on the Laptop
2. When you get screen before use F8 function keys for few seconds until you got a list of options.
3. Then select "Safe Mode"
4. After entering into safe mode then reset the default display settings to 800by600 and apply.
5. Restart the system.
Hope this information is useful
Thanks & Regards
M. NANDA KISHORE REDDY.
Oct 22, 2009 | Dell Latitude D600 Notebook
Gud evening sir im ravi my mobil model no is nokia 3110 c i have one problam my musiplayer is not opening how will solve that prolam
1.Format your memory card
2.Make shortcut on your mobile so u can access very fast to your media player
2.1. In SETTINGS/DISPLAY/ACTIVE STANDBY/ACTIVE STANDBY MODE (TURN ON)/PERSONALIZE VIEW (MAKE IT THAT SHORTCUT BAR IS THE ONLY ONE THERE)
2.2. In SETTINGS/MY SHORTSUTS/NAVIGATION KEY make it so that standby key is 2nd
2.3. Get back to main screen and press DOWN key, options, select, select media player, and save, in organise shortcuts make it 1st and save your progress
3.Upload up to 5 songs
4. Update your media player, mobile will restart him self! BUT!!!...
5. In order to stop restarting u have 3 sec to start updating music library again
6. If u done all at step 2, u need to press fast one time down, central button, left blue line, down, central, up, and central (Need to be pressed in 3 seconds)
7. If u success in this 6th step u hawe solwed problem!
8. Next step is to upload next 5 songs and repeat steps 4-6
(9.) If you cant press so fast buttons to restart uploading I suggest to create a folder named "Amp3" so he can be first when u access to your memoru card so you could
erase him fast to stop restarting, instead formating whole card (In SETTINGS/MY SHORTSUTS/LEFT SELECTION KEY(Make it Gallery, so you can access fast to memory card to delete folder "Amp3"))
(10.)Buttons to erase "Amp3 folder" - While in main screen press : Left blue line, center, left blue line, down, center, center (Need to be pressed in 3 seconds)
(11.)You hawe stopped restarting and kept pics, and images on memory card
Dec 04, 2008 | Nokia 3110 Cellular Phone
N-gage mobile software problem
it has nothing to do with the mmc. its the phone..have you ever try formatting it?if not try this..'7', '*', 'call'(green button), 'on/off'..at the same time.long press(until it finish the formatting) if the phone start, do this *#7780#.it is for resetting..youll be ask for a code..key in 12345..hope it will work.
Nov 15, 2008 | Nokia N-Gage QD Console
Nokia 3230 boot failure or cannot star-up
Do a Full phone formatting following steps below:
1. Make sure you have at least 3/4 charge of battery power left.
2. Backup your contacts list and personal files to MMC memory card.
3. Switch-off your phone.
4. Press and hold 3 keys;
  1. Green dial key,
  2. * Star key,
  3. no. 3 key on keypad
and then press the power on/off to switch on the phone.
Do not let go the 3 'press and hold' keys until you see a the word 'formatting' is displayed on the screen
Aug 05, 2008 | Nokia 3230
How can I format my Nokia 6125
Here’s how to hard reset or format your Nokia mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
May 02, 2008 | Nokia 6125 Cellular Phone
NOKIA 3230 GOES OFF ON ITS OWN
you should format the hand set
press *,3,callbutton, and swithon button for few seconds upto "formatting "display comes.if not try some more times
Nov 20, 2007 | Nokia 3230 Cellular Phone
Nokia 6125 Cellular Phone Logo
618 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
