Question about Asko T793 Dryer
Continues to have water condensation inside. clothes do not dry - as wet as when I put them in. Dryer bought 8/2009. Replaced control board & moister sensor 10/2009.
    Sergeant:
  • 172 Answers
Sounds like the heating element is out ...Does it get hot at all
Posted on Nov 17, 2009
Indesit widl126 does not dry
Had the same problem, very hot but wet clothes. This is a condensor drier. The fack that the clothes are hot rules out the heater or its control. If yoy hear the fan running and there is no blockage the fault is caused by the 3 stage water valve. During drying a small amount of water is passed through a condensor chamber, the cold water causes steam the condense backi into water then is pumped out through the drain. If the water valve fails no condensing takes place and the clothes remain wet. The valve is easy to change and costs about 15 pounds.
Dec 04, 2012 | Dryers
Amana electric dryer timer doesn't advance during
If this is one of the electronic models: Clean the sensor strips located inside the drying area. As wet clothes rub against these the control monitors the resistance changes and knows the clothes are still wet therefore it continues to operate. When buildup from dryer sheets and fab softener get on them strips a barrier is formed that repels dampness. Therefore the control does not know the clothes are wet and goes to the end thinking all is Kosher. Clean them sensor strips with Windex and party on!
Jun 18, 2012 | Dryers
I have jst purchased this washer today, however the dryer takes ages,,,,,,their seems to be water going in when its drying, clothes come out hot, but still as damp as when i put them into dry.
Hi, this is normal for a washer dryer, water isn't actually going in, it is condensating and then being pumped away.
when you use the dryer program your are only meant to put half the washing load or less in at a time if there is too much wet washing in the machine it will take forever to dry as it cant get rid of the amount of condensation quick enough so some of it is reabsorbed into the clothes and so it goes on.
so the trick is only to put in a maximum of half the full washing load.
Hope this helps.
Feb 11, 2011 | Hotpoint Ariston WD440G Front Load...
Kenmore dryer will stop in mid cycle and beep 3 times in succession. What does that mean? Already had a repairman out and he replaced the circuit board.
Use some windex to clean the wax buildup off the dryer sensors under the filter housing inside the dryer.9bc0002.jpg Autodry VS electronic sensing: First, wet clothes are electrically conductive. With electronic sensing dryers as the wet clothes tumble, they touch the two metal bars in the drum. (Auto dry dryers utilize a system of cycling the timer motor with the element, and has nothing to do with how wet the clothes are by the way.) There is a capacitor on the control that is trying to build up a charge, but when wet clothes create a short from one bar to the other, this charge is released to the frame of the dryer, therefore discharging the capacitor. As long as the capacitor charge is low, the control knows the clothes are wet. As the clothes become dryer, they short the bars fewer and fewer times. Once the capacitor charge builds to a certain level, the control knows the clothes are mostly dry, and it advances the program to the final timed portion, usually less than 20 minutes, some of which is a cool down portion to reduce wrinkling. If your dryer is shutting off after only 10 minutes, that means the control capacitor is never getting discharged. This can be due to a few different reasons: 1. Sensing bar wire is disconnected or broken; 2. Load is not large enough (remember the bars must be contacted repeatedly); 3. Bars are "coated" by fabric softener build up and need to be cleaned with Windex or 409. 4. Defective control board. 5. Airflow is restricted and moisture can't escape the drum. 6. Corrosion built-up on sensing board connection.(yank out the board and clean the contacts that sometimes is all it takes) Address the airflow condition and load size. Clean the sensor bars and make sure the wires are all connected securely. There is a diagnostic mode you can enter to test the control's ability to sense the bar contact that is illustrated in the tech sheet which is located within the control panel on many models. No sensing bars means you have auto-dry a totally different animal. Typically an orange wire is connected to the high limit on the heater element housing which feeds the timer motor when the element is not in operation. Bad control thermostat or air restrictions are the Autodry type dryer's worst enemy. Special thanks to a.g.
Jun 02, 2010 | Kenmore 63952 Electric Dryer
Auto dry mode does not work properly...the 3 levels "More - Less" seem to have no effect at all on the load dryness when the cycle ends. Is it a sensor problem ?
There are two metal strips in the front ,right, inside of your dryer. (You have to put your head in the dryer to see them.) I have seen metal (a paper clip, hairpin, staple, etc...) making contact between the two pieces of metal causing your machine not to recognize wet clothes. The washer recognizes the wetness as an on off contact from the water as the clothes come between the two strips. Try cleaning the strips very well. If this does not work you must check the wires coming from the strips all the way to the control board to make sure the wires are not broken anywhere. Check the continuity with an ohm meter. If all this is fine, you have a bad control board and will have to replace the power control board that the sensor hooks into. You should be able to use the timed dry just fine if you decide not to replace the control. I don't have your model number but they can be more than $200.
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
I have a GEW9250PW (about 4 years old) that will not start. I noticed a small build up of water in the drum and, upon removing the lid, noticed condensation on the electical board. Not sure why there is...
is the air flow to the unit good and the vent pipe clear of lint and the inside free of wet lint so as not to leave humid air inside dryer all the time?
Oct 28, 2009 | Whirlpool GEW9250 Electric Dryer
Water collects under dryer. Clothes dry. floor wet. Vent open.
You said, Water collects under Clothes dry on floor.This sounds like a condenser dryer that needs the water retention bottle empdied or the hose to the bottle is leaking.
Check these two things
Huuum
Please leave a rating before you leave the site!
Feb 01, 2009 | Dryers
Burning smell coming from the dryer!
You have a serious clog somewhere in your dryer exhaust ventilation. I would recommend you STOP using the dryer immediately and clean both the interior and all the vent ducting from where it exits the dryer to where it exits the home. the burning is coming from lint build up in and around the heating element and its beginning to smolder. This is a potential fire hazard and may end up causing the heating circuits to fail. The condensation comes from the the inability of the hot air (which is mixed with humidity from your clothing) condensating inside the vent duct. The lint starts to collect and get wet to the point of saturation. Then it begins to cause water to form and leak out of the ducting and on to your floor. You do not want this condensation inside the dryer where the heating circuits are. The following link will provide with some guidance for future reference:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention the paragraph where it discusses proper dryer ventilation. I hope this helps you. Let me know if I can be of further assistance.
Sep 28, 2008 | GE DBSR453EBWW Electric Dryer
Dryer runs but wont auto shut off
On auto dry cycles, the cycle is controlled by moisture sensing bars located on either the rear or front bulkhead, ( visible inside dryer ) if the moisture sensor bars are shorted together (normally by wet clothing) the dryer will continue to run. If the dryer continues to run when the clothes are plenty dry, check and see if there is anything stuck between the sensor bars, (sometimes a metal sequin will cause this) or see if they are damaged. If not, you may have a problem with a timer contact, if the timer advances and stops moving at the same spot each time, I would suspect the timer. If this is an EvenHeat dryer, examine the control board located to the right of the timer in the control panel, for any burned components. Hope this helps.
Sep 15, 2008 | Kenmore 73952 Gas Dryer
Dryer model # RES7648JQO Serial # MK2707517 I put up a load of clothes to dry and when the cycle is done the clothes are still wet and there is water on the door inside the dryer. I've tried adding a...
it sounds like an airflow problem. check everywhere the air flows. inside the lint catch. the vent behind the dryer may be clogged or kinked. the exhaust line in the floor or wall of the house might be clogged. 689b12c.jpg
Aug 01, 2008 | Roper Dryers
Asko T793 Dryer Logo
82 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
