Question about Garden
Volvo ec25 will start and run for about 10 seconds then cuts out ?
  • 235 Answers
Fault in the ign switch circuit is not keeping the current on to the pump stop solenoid .
Posted on Dec 31, 2009
2002 volvo s80 was running perfect. car sat for 2 days and now it will start and run 5-10 seconds then die
You need to scan the system for fault codes, this takes a OBD2 system fault code reader like the one below.
It is from Walmart and is about $15.00
Feb 27, 2017 | Volvo Cars & Trucks
How can I find the parts list for my Volvo Excavator EC25? Can someone sent me some photos with parts catalog? Thank you for helping.
You need to download Volvo Excavator EC25 Parts Catalog from this link: http://selz.co/EJJzRRbv$
Is exactly what you need, just print it and start using.7cf7475d-6180-4ffb-b013-efbaee984f6b.jpg
Nov 01, 2016 | Volvo Cars & Trucks
98 volvo glt. TPS
When you turn the vehicle on the PCM does a check on the system. For most sensors, it checks power and ground. Turns the light off if all is good. Since yours comes on after a few seconds, you need to check the signal return wire. Wires tend to break right at the plug. You'll need a volt/ohmmeter to check it. Also check the continuity of the wire from the TPS to the PCM. Anything over 5 ohms needs replaced. I just cut the wire and run a new one.
Sep 24, 2016 | Volvo S70 Cars & Trucks
2001 volvo s80 My ac works for 10 to 15 min. Then gets hot. If I cut the car off and re start it. Its cold again .what could it be?
Have your ac system recharged you dont have enough refrigerant to maintain pressure on the low side when the ac is running
Jun 11, 2015 | Volvo Cars & Trucks
1996 volvo 960 cranks and runs but will not idle
Take the fuel line off the fuel rail , or depress the schrader valve on the fuel rail if you have one to see if you are getting steady fuel flow, OR hook up a fuel pressure guage to inspect your fuel system. You may have a bad fuel pump.
Aug 28, 2014 | Volvo 960 Cars & Trucks
Volvo 850 glt starts runs short time cuts off barrtey dead again what is problem
The voltage should be between 13 and 14V when the engine is running. If not, 12V or less, you most likely have an charging problem. You need to remove the alternator and get it checked then get it rebuild.
Feb 19, 2013 | Volvo 850 Cars & Trucks
My volvo 96 850
all you need to do is clean the throttle body using gumout throttle body cleaner which should only cost about $6 givr or take
Mar 10, 2009 | 1994 Volvo 850
1998 V70 2ltr Non starter
Try the fuel injection relay they are located under the hood. They blow out every few years on my Volvo. The car starts to quit all of the sudden. It is either red or green colored. It is located in the fuse box under the hood.
Apr 25, 2017 | 2002 Volvo V70
Garden Logo
364 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
