Question about Swintec 7040 Typewriter
How do you show the print on the screen b4 u type
How do you show the print on the screen b4 you hit return to type it out?
  • Swintec Master
  • 3,594 Answers
Pressing the mode key (L. side of keyboard) the arrow will move on the display you want to leave it on LP.
DickyO
Posted on Nov 17, 2009
I've hit a wrong key and now it won't print what I am typing it just moves along the line
Just hit the mode key until TYPE, on the display, is highlighted. There are 3 modes, TYPE (where the machine functions like a normal typewriter), L/L (Where what you are typing shows up in the display and then prints when you hit the "RETURN" button. You can make corrections, in this mode, before you print the line, which saves using your correction tape.) and STORE (which is used to store memory information, such as format and phrases.)
Sep 28, 2015 | Brother EM-430 Typewriter
Change the font style on a Bee3 label maker
1. Press "Style." The screen shows "lines." Press "Return." 2. Use arrow key to select "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select "1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screen says "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREA Label." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312 fmi or a manual! Changing the font on your Sun BEE3 BEE3 label printers
Apr 10, 2014 | K-Sun Corporation BEE3FB - BEE3 LABELShop...
I have a Bee3 label maker and I need to know how to change the font size.
1. Press "Style." Thescreen shows "lines." Press"Return." 2. Use arrow key toselect "1 Line" (or "2 lines" of text, etc.). Press "Return." 3. Use arrow key to select"1a," "1b", "1c," or "1d" (text). Press "Return." 4. The screensays "vertical." Arrow down to "END?" Press "Return." Then the screen shows "AREALabel." Press "Return." 5. Type your text. Preview and Print. Call 1-800-622-6312for a reference manual. We can answer any other questions you might have too!
Jan 18, 2011 | Office Equipment & Supplies
I have a g 4 and can not remember my password
restart your computer. When the first white screen comes up, hold down command+s keys. the screen will change to white on black and some code writing will load. DONT FREAK OUT OR PRESS ANYTHING UNTIL AT THE BOTTOM OF THE SCREEN IT SAYS "root". then type in exactly:"/sbin/mount -uw /" hit return once then type in "passwd [username]" and hit return. where it says "type in new password" type in the password u want. hit return and retype the password. hit return one more time and wait for the codes to say "root". then type in "exit" and hit return. the computer should continue to start up and u should be able to log in.
Mar 05, 2010 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Print job won't cancel, window shows job is "deleting". Now nothing will print. It's been deleting for an hour. Is there any other way to clear print jobs from the cache?
Assuming a Windows OS (Win2K or above), you can kill the spooler queue from the run command line or in the command prompt window. Type "net stop spooler" (omit the quotes) and hit return. Then type "net start spooler" and return. Please note this will kill any fax monitor that you have running as well as the queue for all printers from your computer.
I strongly recommend rebooting the computer afterwards. If you do not run this in the command prompt window, entering only the first command requires a reboot and then a long wait for the action to finish.
I hope this helps.
Jan 05, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I print on labels and the print is too high. How can I lower Print on page?
hold go and return power on the printer until in the screen you see it start to veify ram then release. this will bring the printer up to registration hit select there will be 4 settings showing right left top and bottom. use the select button to move from setting to setting if the print is to high minus from the number showing in the top position make the same number change to the bottom setting untill the print is in the right position. remember or make note of these changes if the print gets further away reverse your changes
Nov 04, 2009 | Lexmark T640 Laser Printer
Typewriter printing different key than one hit
Check and see if the pitch selection is in PS.
DickyO
Mar 29, 2009 | Office Equipment & Supplies
IBM Wheelwriter doesn't type until I hit return button.
On the R. side of the keyboard is a key that says print mode press this key and the dl print on the displaywill go out.
DickyO
Mar 17, 2009 | IBM Wheelwriter 30 Typewriter
Print from memory
put mach. in NP mode
press the PRINT key ("name of file" should appear)
type the name of the file and hit RETURN key
then hit RETURN again
Sep 29, 2008 | Nakajima AE-740 Typewriter
Lexmark x5470 aarrggghhh
hmm..you got the AIO control software from Lexmark?
Apr 19, 2008 | Lexmark X5470 All-In-One InkJet Printer
Swintec 7040 Typewriter Logo
52 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
