I have a Toshiba Qosmio G30-175 - overheating?
I have a Toshiba Qosmio G30-175 and it now seems to get hot, the fan runs very noisily and then the screen flickers and hangs. Any idea what is wrong?
    President:
  • 987 Answers
The processor fan needs to be replaced ...
Posted on Nov 17, 2009
Qosmio f60 fan goes on high speed and freez. It keep freezing.The only way to reboot it is to hold down the power button to turn it off and then turn it back on.
I have the same "computer" qosmio f60. I've replaced the hard drive, installed a new window 7 OS, changed RAM paging, power options, run the things with a fan pointed at the computer fan.
The fan goes to high speed and the HDD LED unblinking. I've brought the laptop to two computer shops whose owners knew less about computers than I did. I tried to go to a Toshiba recommended shop in Toronto except they changed to Apple-service only. I tried phoning Toshiba, they just want to change 4 bucks a minute for technical assistance. I've had this Toshiba-thing going on 3 years with the troubles starting after the first year. No one cares about this problem. If I see a Toshiba factory I'm going to chuck this red brick of cra through the window.
BTW it's not a virus or rootkit. I had to learn how to partition a HDD sector through some crazy BIOS program before installing windows. There's no virus or rootkit that's causing this problem.
It's mostly been freezing on me with games.
Aug 31, 2013 | Toshiba Qosmio G15 Notebook
I hear noise coming from the back vents and I think it might be the processor fan. Is there a way to fix/clean it so that noise goes away and do I have to open it from the bottom? This is for Qosmio G25.
You probably need to replace the cooling fan, but you can try cleaning it out first. Get a can of compressed air or use an air compressor to spray pressurized air into the vent to spray dust out. If this doesn't work, you probably need to replace the fan. I actually found a guide for opening up the Qosmio G25 and replacing or cleaning the cooling fan. Check it out:
http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm
Sep 24, 2011 | Toshiba Qosmio G25-AV513 Notebook
I need to replace my fan for my toshiba laptop, nad need to know how to disassemble the laptop to get to the fan.
Toshiba Portege A100 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A100/remove-systemboard-replace-fan-1.htm Toshiba Portege A600 or A605 http://www.irisvista.com/tech/laptops/Toshiba-Portege-A600-A605/disassemble-laptop-1.htm Toshiba Portege M700 http://www.irisvista.com/tech/laptops/Toshiba-Portege-M700/take-apart-tablet-pc-1.htm Toshiba Qosimo F40 or F45 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-F40-F45/laptop-disassembly-1.htm Toshiba Qosimo G25 or G20 http://www.irisvista.com/tech/laptops/toshiba-qosmio-g25/replace-cooling-fans-1.htm Toshiba Qosimo X305 http://www.irisvista.com/tech/laptops/Toshiba-Qosmio-X305/laptop-disassembly-1.htm Toshiba Satellite 1955-S805 http://sites.google.com/site/electrochain/toshibafan Toshiba Satellite 2410 http://mardou.dyndns.org/Privat/homepage_cms.ns5/content/homepage_tutorials_toshiba_satellite_2410_-_luefter_tauschen.html?Open&lang= Toshiba Satellite A35extlink.png http://www.irisvista.com/tech/laptops/ToshibaA35/Satellite-A35-fixing-overheating.htm Toshiba Satellite A60extlink.png http://tech.icrontic.com/articles/clean_laptop_heatsink Toshiba Satellite A105extlink.png http://www.paulstravelpictures.com/Toshiba-Satellite-A105-Laptop-Overheating-Dust-Removal-Guide/index.html Toshiba Satellite P10extlink.png http://loblog.wordpress.com/2006/03/08/toshiba-p10-schaltet-sich-ab/ Toshiba Satellite P305Dextlink.png http://www.insidemylaptop.com/clean-cooling-fan-toshiba-satellite-p305d/ Toshiba Satellite X205extlink.png http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm List of a lot of pc fan repair guides:http://repair4laptop.org/notebook_fan.html
May 09, 2011 | Computers & Internet
Random temporary freezing
that issue could be system overheating- or bad memory. The way to tell if it is the memory is to run the diagnostics for your system (you may need to contact Toshiba tech support for an assist w/ that). If the system is overheating, the judge is your hands- if it is burning hot, the laptop is too hot. If you smell hot plastic/burning insulation from your system, CONTACT TECH SUPPORT IMMEDIATELY AND DO NOT USE THAT SYSTEM! It is a severe safety issue if your system is doing that- as in, you get a replacement system and not a repair.
Jan 09, 2011 | Toshiba Qosmio 18.4 LCD, Core i7, 4GB RAM,...
Overheating, sometimes i see the fan go on and off is it normal?
Under load the fan will kick in and stop as the temperature gets hot. This is normal.
If it is doing this on a reguar basis, you can do the following
1.) Download a copy of a hardware monitoring tool (everest is good) as a trial, note the indicated temperatures that appear on the toolbar, up to 60 degrees is ok under load, after that, you have an overheating problem.
2.) Either take the laptop to a shop and get it cleaned out (dust and dirt accumulate in the fan and coooling matrix), or try this yourself. You can try vacuuming the intake and outlet ports for the fan, but this is not the best solution.
3.) Obtain a USB cooling pad, these are ludicrously cheap on the lies of ebay at less than £4.00 delivered from some suppliers and reduce operating temperatures by 15-20 degrees if placed correctly
Jan 01, 2011 | Toshiba Qosmio F45-AV410 Notebook
I was given a qosmio G15-AV501, but it appears to be overheating about 10 minutes of operation. It will run for a little while, then just shuts down. Between 5 and 15 seconds before it turns itself off I...
No particular problem with your unit. In your case it appears that the fan isn't operational - open the laptop and replace it.
Also check in the BIOS the shutdown temperatures, they might be set way too low.
Sep 08, 2010 | Toshiba Qosmio G15-AV501/R Notebook
Toshiba Qosmio f20 not booting up
Dear Sir,
Try this, remove the power plug and battery, wait for five minutes and plug the computer to power with out the battery and try to start it.
Dec 31, 2009 | Toshiba Qosmio G15 Notebook
Tosibha qosmio f15 av201 does not turn on when power button pressed
i am no whizz, but i think, just THINK maybe you should get some friend or relative to check the wiring to the fan and the power button, maybe when cleaning the fan, the wires were losen, as the button is millimeters away from the fan.
i hope it might help, if not i already said, i'm no whizz
Aug 11, 2008 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba satellite p105-29722 overheating/vid car
I had the same problem. I sent it back in to Toshiba and they fixed it.
The problem was the fan on my motherboard. I think it had some bad bearings because it would run sometiems and not others; and when you would hear it run; it would do a lot of clicking.
It was overheating the core, and while I was playing games it would just stop processes.
Just call up Toshiba and tell them; they should let you send it into the UPS store for free. It will take about a week or two.
Jun 10, 2008 | Toshiba Satellite P105-S9722 Notebook
Power failure
your laptop may become overheated and that is why it shuts down, make sure the laptop is on a hard service so that the fan can get air. hot weather can cause problems as well.
May 28, 2008 | Toshiba Qosmio G25-AV513 Notebook
Computers & Internet Logo
317 people viewed this question
David Payne
David Payne
