Question about LG Incite Cell Phone
Problem with wi fi conection - LG Incite Cell Phone
How to conect to nintendo zone
Be sure Wi-fi is enabled on your portable Nintendo device. Then, go to a Nintendo zone location (such as a McDonald's). Your device should connect automatically. If it does not connect, you may need to go into the 'Settings' menu of your device and connect to the Nintendo zone Wi-fi manually. Or you may not be close enough to the Wi-fi signal for your device to connect.
Dec 14, 2015 | Nintendo Video Game Consoles & Games
Why wont my wi-fi 4g advanced , setup
Richard we all need more information to work with
4g are you referring to mobile data on a mobile phone network. Richard ?
Setup what are you trying to setup a USB Dongle or are you connecting via a mobile phone ?
Or are you using a 4g mobile data wi fi modem hooked into each device via wi fi ?
what operating system is on your laptop ?
Dec 27, 2014 | Computers & Internet
I can't access internet through wifi
Hi spatra279,
what is the model of your laptop?
1. Before you conect to the Wi-Fi, make sure that your computer has installed drivers for Wi-Fi.
2. Make sure that Wireless is already open or st-up.
3. Look for the Wi-Fi spot area or zone, if there's no Wi-Fi access on that area you may not connect to Wi-Fi.
Hope this helps.
Thank you for using Fixya.
Sep 07, 2011 | Computers & Internet
Galaxy samsung phone. He can't find wi-fi
He should read the manaul or call his cell phone provider's tech support.
If he still can't find wi-fi the wi-fi is turned off or hidden which can be corrected by the person who manages the wi-fi acces point.
I hope this helps him.
Jun 16, 2011 | Samsung Galaxy S GTI9000 Smartphone
Conecting to wi-fi " the access point's security
There are several types of wireless security that wireless routers use to try to keep people that shouldn't be on your network off of it. Try going into your wireless access point's settings and changing the type of security it uses.
Mar 08, 2011 | Nintendo DS Lite
Ipod wi fi conection
Wi-Fi Functionality
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, iPod touch will scan for Wi-Fi networks and show a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show a lock icon (307189_1.jpg) next to them.
  3. Option to manually enter your Wi-Fi network name/SSID (if the Wi-Fi network is configured not to broadcast or be displayed to the public). If necessary, enter the password to join.
When iPod touch is connected to a Wi-Fi network, the Wi-Fi icon (307189_2.jpg) in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
Wi-Fi Settings
  1. Turn Wi-Fi on or off.
    Choose Settings > Wi-Fi and turn Wi-Fi on or off.
  2. Set iPod touch to ask if you want to join a new Wi-Fi network.
    When you are trying to access the Internet, by using Safari or YouTube for example, and you are not in range of a Wi-Fi network you have previously used, this option tells iPod touch to look for another network. iPod touch will display a list of all available Wi-Fi networks that you can choose from. Networks that require a password appear with a lock icon (307189_1.jpg).
    If "Ask to Join Networks" is turned off, you must manually join a network to connect to the Internet when a previously used network is unavailable.
    Choose Wi-Fi and turn "Ask to Join Networks" on or off. If you turn "Ask to Join Networks" off, you must join new networks manually.
  3. Join a Wi-Fi network manually.
    Choose Wi-Fi, wait a moment as iPod touch detects networks in range, then choose a network. If necessary, enter a password and tap Join. Networks that require a password appear with a lock icon.
  4. Make iPod touch forget a network, so that the device doesn't join it automatically. Choose Wi-Fi and tap the arrow (307189_3.jpg) next to a network you've joined before. Then tap "Forget this Network."
  5. Connect to a closed Wi-Fi network (an available Wi-Fi network that isn't shown in the list of scanned networks).
    Choose Wi-Fi, then tap Other and enter the network name. If the network requires a password, choose Security, tap the type of security the network uses, and enter the password. You must already know the network name, password, and security type to connect to a closed network. Some Wi-Fi networks may require you to enter or adjust additional settings, such as a client ID or static IP address. Ask the network administrator which settings to use.
  6. Adjust settings to connect to a Wi-Fi network
    Choose Wi-Fi, then tap the arrow (307189_3.jpg) next to a network.
Dec 27, 2010 | Cisco Linksys Wirelessn Router Black...
Just got bt wireless broadband but computer will not conect via wireless. computer only 4 years old thought it would have had wireless mode built in??
First check in your router your wireless option WI-FI is enabled.
Then check in laptop Wi fi driver are instaler and working properly.
Also make sure your wi fi is enabled in network plces property and wi fi switch on laptop is turned on in laptop.
Aug 07, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Problem wifi acer 4720Z
Remove on bottom covering Wi-Fi card. Unseat and Re-seat Wi-Fi Card.
Feb 25, 2009 | Acer Aspire One PC Notebook
Wi-fi is not working
wi-fi is not working
Nov 30, 2008 | Computers & Internet
LG Incite  Cell Phone Logo
42 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
