Question about Exercise & Fitness
Ironman M2 treadmill starts but then stops right away
Hello, I just sold an Ironman M2 treadmill to a lady who says its missing a leveling foot. She has the cord attached to the emergency stop but still the treadmill will start but then stops. Can you tell me if the missing leveling foot may be the issue or if there is another possible quick fix?
Thanks,
Jenni
    New Friend:
  • 64 Answers
Most treadmill will run for a second or two but stop if the speed sensor don't pick up a speed. If the treadmill was moved there is a good possibility that the sensor is off line. Not 100% fimiliar with this particular unit but if you remove the motor cover, these are the usual places for speed sensors. The front roller- the side where belt come from the motor. The other popular place is on the motor fan. The sensor has either two or three wires with the sensor at the end. On the roller, the sensor needs to be close enough to pick up the magnet on the side of the roller. On the fan make sure the teeth are clean and sensor has a good connection. Hopefully one of these will do it for you.
Posted on Nov 17, 2009
Thanks, that advice pointed me in the right direction - if anyone else has same problem , I checked the sensor which was mounted beside motor fan and everthing looked ok - the distal end of the lead from the sensor to circuit board, was not easily visible as tucked under the motor - It clips into the circuit board here and that had come loose - once clipped back in , problem sorted.
Posted on Feb 06, 2010
Ironman treadmill shows code SI 1. what is it? how to fix?
The SI 1 error code means there is no safety key in place. Unplug your treadmill, wait a few minutes, then plug it back in.
When you try to use it again, make sure the safety key is firmly in place, and make sure the metal piece below the Emergency Stop sticker is still in place.
If neither of these work, it may be appropriate to take your treadmill to a servicer.
Hope this helps!
Feb 21, 2012 | Ironman 220t Programmable Treadmill (225...
Missing manual for Ironman 320T.Where can I find or download one?
Hi
Click the follwing link for ironman 320T manual
Ironman 320T
I hope this helps.
Dec 10, 2011 | Ironman 320T.1 Treadmill
How to fold my afg 5.0 treadmill for storagae
Dear Sir: Hello , i hope everythign is o.k
Please do the following:
FOLDING Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra Managua, Nicaragua C.A.
Sep 25, 2011 | Horizon AFG 5.0 AT Treadmill
Bought a proform ekg treadmill from a lady on line
Mine did the same thing. I had to take the display apart and clean the contacts on the circuitboard that are underneath the buttons. After I put it back together it has worked perfectly. Mone came from a house where the people smoked and it was the nicotine and tar that was in the smoke that had seeped inside and cause it to stop functioning properly. Well I guess thats why they sold it to me. They likely were not using it anyway. Well I hope this helps
Mar 13, 2010 | Proform 730 Folding Treadmill Model...
Why does my Ironman Triad treadmill motor slow when people try to run on it, the belt completely stops
When running or walking on my Ironman Triad Treadmill it jerks like it is going to stop every once in a while not all the time. Do you have any idea what makes it do this. I have had this Treadmill for 5 years and never had a problem before.
Dec 19, 2009 | Ironman Exercise & Fitness
Missing Owners Manual for the Ironman 250E Ellipitical Trainer.
I was having the same problem as my owner's manual has been misplaced as a result of several moves and I found this online. Hope it helps.
http://www.academy.com/images/pdf/Ironman/Ironman_Elliptical_530e.pdf
May 03, 2009 | Ironman Fitness Achiever Elliptical...
Repair service in Sacramento?
call GYM DOCTORS  888-876-4321.  They service the sacto area and should be able to help you out.
Mar 01, 2009 | Ironman Fitness Achiever Elliptical...
Ironman Triathlon Sleek Ladies watch Band problem.
try simple free or a citrus solution often found in household cleaners. js
May 24, 2008 | Watches
Exercise & Fitness Logo
571 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
