Question about M-Audio Audiophile 2496 PCI Digital Audio Card System
M-audio connections - got sound for headphones but mic not working - how do i connect a 3.5 jack to 2496 card Thanks - E HUGHES
robotek
  • 1512 Answers
SOURCE: No sound through M-Audio preamp and condenser mic
Hi micoach
The condenser mic you are using requires phantom power for it to operate. Pay to check that that is turned on m-audio. Just to be sure.you say you can get sound off the m-audio headphone socket. Just need to check that. You will need to check that you have selected the device for recording from the preferences--audio I/O options menu within audacity. Perhaps check these things and get back to me here if you still have problems.I can go into more detail with you.
regards
robotek
Posted on Jul 04, 2008
frcs68
  • 1605 Answers
SOURCE: M-audio 2496: computer is asking to restart
check for virus
get a good virus software. I suggest AVG it is free.
Posted on Oct 13, 2008
technical114
  • 1851 Answers
SOURCE: how to use yamaha mg102c with m audio usb
You must connect:
the mixer output to the "line|optical" input of the Transit
the mixer input to the line (in case of an analog signal) or to the optical (in case of a digital - optical signal)
The USB connector on the other side is going to be connected at the USB port of the pc.
Just keep in mind that the signal flow goes as the arrows on the Transit.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
Posted on Feb 25, 2010
JulesPCaut
  • 702 Answers
SOURCE: hi,
Not sure what OS you are using, but here is an article with some ideas on how to fix sound recording problems in Windows Vista.
http://www.pcauthorities.com/multimedia/how-to-fix-sound-recording-problems-in-vista
Posted on Mar 19, 2010
  • 10406 Answers
SOURCE: Sound through headphones only.
Try the speakers on another computer, to see if they work at all. If they do, then the problem is the audio-interface on your computer (or DVD-player, or home-stereo system).
Posted on Apr 10, 2010
How can I connect my Onkyo TX-SR507 to a PC to play MP3 files
The easiest way is to use a 1/8" stereo to dual RCA cord and connect the output of the sound card to an AUX input on the receiver. These cables are readily available and cheap. You shoul dhave 3 mini jacks on the back of the computer related to the sound card setup.
1) Audio input mic
2) Audio input line
3) Audio output line
Connect the receiver to the audio output line jack.
Dan
Jan 30, 2010 | Onkyo Tx-sr507 A/V Receiver
How to connect a microphone to Logictech z-340 ?
Hi there and happy new Year , Your Microphone has to be connect to your PC in the Red or Orange Color COded Jack Input , it cannot connect too your Speaker System ...
Hope this helped bud
Dec 26, 2009 | Logitech Z-340 Computer Speakers
Whow i connect my xenyx 1002 mixer to audiophil 2496 sound card
You must connect:
the main out of the 1002, or the ctrl room out of the 1002 at your power amplifier's input.
the line in 9/10 of the 1002 at your 2496's line out.
the cd/tape out of the 1002 at your 2496's line in.
in case of a cd connect it's line out at line in 3/4, or line in 7/8 of 1002
some mic at the mic 1 or mic 2 of 1002.
That's the way you're going to have control for:
the mic level from channel 1 or 2.
cd level from channel 3/4 or 7/8.
pc playback from channel 9/10.
master speakers from main mix or ctrl room.
All the above connections are not absolute and may vary depending on your needs.
Thanks and regards
Stelios
Dec 03, 2009 | Behringer Xenyx 1002fx Mixer 10 Input 2...
How to use speaker and earphone in the sound card
When you activate the headphone jack it mutes the speakers. To us both you need a Y cable for the speaker jack to connect both and have them work.
Oct 13, 2009 | Computers & Internet
I bought inspire m4500 but only 2 speakers are working....
put the black pin of ur headphone in mic jack of laptop(mostly red color) and green pin of ur headphone in output audio (mostly green).
hope this helps u.. cheers Rajeish
Jul 05, 2009 | Creative Labs Sound Blaster Live! 5.1...
Audio not coming out input 3 in
input to the tv is incorrect select av3 0r what ever the front jack is marked on you tv. good luck farr64
Apr 30, 2009 | Mitsubishi WD-73735 Television
Line in / Mic jack help
So we're talking PC here, right?
I don't understand what you want to record. Going from the PC Headphone jack to the PC Line IN might be unwise in order to prevent a feedback loop. External (non-PC) source and PC MIC might work but you would probably want to monitor it on headphones again because of possibe feedback.
Does your MIC work?
Right click the speaker icon again and select Adjust Audio Properties or open Control Panel and select Sounds & Audio Devices. Select the box to place the icon on the Taskbar for future use.
Right click on the little speaker icon in your Taskbar and select Open Volume Control, if it's there. From there you're on your own. I have a sound card so I don't know what you will see. Look around, there may be a bunch of audio outputs and inputs with Master and individual volume & balance controls plus one for your Mic. Make sure it's not muted.
Apr 21, 2009 | Audio Players & Recorders
Mic not working when headphone plugged in
Try changing the Windows Default Audio devices
  1. Go to control Panel
  2. Sounds and audio devices
  3. The Audio tab
  4. Then change the Sound Recording Device to Logitech Headphone INPUT
Hopefully this will work
Apr 07, 2009 | Logitech Premium Headset
Speakers not working.................
Check the following,
  • Speakers, connecting cables and Sound Card are working fine by connecting to another computer.
  • Speaker Cable is connected to an audio port (Audio/Video port in system box).
  • Volume is MUTE / Low (in Volume Controller).
  • Audio drivers have installed.
To Check follow the Steps:
• Go to Start>
• Control panel>
• Double click on "System" Icon> (it shows the System Properties Window)
• Select “Hardware” Tab>
• Select “Device Manager” Tab> (it shows the Device Manager Window)
• Select “Sound, video and game controllers”>
• Expand “+” symbol> (check the audio Codecs, Legacy Audio Drivers and others are not in Questioned Mark (?) symbol with yellow color. If there need to install the drivers ).
  • If not, insert the motherboad CD, browse>select audio driver>install. After completion, restart computer and check.
Sep 21, 2007 | Computers & Internet
Line Recording with H5500
i think that audio jack is for headphone-microphone combined (those cable plugs have a three black lines , top for left audio, center for right audio, last line for microphone) so you can use a headphones with mic directly with this 5500. the mic is i said before is the last line. what you need is a monophone plug. (mono mic) i dont think stereo mic will work.
Sep 12, 2005 | HP iPAQ H5555 Pocket PC
Open Questions:
I just installed my M-Audio Audiophile 2496 PCI card (it seems this is part of the Delta series of cards?) in Windows 7 (64-bit) and it successfully registered and installed the driver, but when I disable my old sound drivers in Device Manager (the Realtek ones which is the sound integrated on the motherboard) I don't hear anything and I checked the Audiophile driver settings and see no headphone or speaker devices listed like there was in the Realtek driver. I re-enabled the Realtek driver and it seems my headphone jack is connected to the motherboard so it's using the built-in Realktek sound card. How can I get sound from my Audiophile card to my headphones? Do I have to remove the Realktek drivers completely or can I leave them just disabled in Device Manager? I don't see a Headphone jack labeled on the Audiophile card. First screenshot shows the two Realtek drivers (ATI HDMI Audio and Realtek High Definition Audio) and my M-Audio Audiophile driver in the Device Manager: http://img694.imageshack.us/img694/4369/audiophile1.png Here you can see how I right clicked on the Realtek driver and disabled it. I did this for the other one. After doing this I tried to play a movie and got no sound: http://img715.imageshack.us/img715/9194/audiophile2.png Here is my Control Panel -> Hardware and Sound -> Manage audio devices: http://img132.imageshack.us/img132/4720/audiophile3.png As you can see the Speakers (this seems to be device associated with my headphones) are showing the Realtek driver. When I disable the Realtek driver in Device Manager and then go to this same screen it doesn't even show the Speakers device any longer. BTW my headphones use a 1/8" (3.5mm) jack. I don't see anywhere on the Audiophile card where I can plug them in there are only RCA inputs and RCA outputs and the breakout cable has SPDIF inputs and outputs. None of these will accept the 1/8" jack! HELP PLEASE!
Feb 27, 2017 | M-Audio Audiophile 2496 PCI Digital Audio...
M-Audio Audiophile 2496 PCI Digital Audio Card System Logo
166 people viewed this question
Top M-Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
SHIVAJI YADAV
SHIVAJI YADAV
Carlos L. Burgos
Carlos L. Burgos
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
