Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Freezer auto defrost doesn't work - GE Profile PSW26P Stainless Steel Side by Side Refrigerator
    Problem Solver:
  • 23 Answers
Turn timer to defrost position and wait for 25 min.,If refrigerator starts auto. and compressor works. Replace Defrost thermostat.
Posted on Nov 17, 2009
3 Suggested Answers
  • 13 Answers
SOURCE: auto defrost not working
Replace the defrost timer
Posted on May 12, 2010
heatman101
  • 43501 Answers
SOURCE: side by side frig/freezer. Freezer auto defrost
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 20, 2010
Jen-Air JSD2989 AE, freezer works but the frig doesn't
Lets make sure that there are no frost build up on the freezer back wall like this=> HERE If there is a problem with frost building on the rear wall of the freezer the most likely reason will be the=> 61005988 Defrost Control Board
The defrost control board can be found behind the control panel inside the fresh food compartment just above the top chef. It is listed as part location 13 in this photo here=> JSD2989AEW Control Components
The next possibility will be the auto damper listed as part location 8 and that part number is=> 61005989 Auto Damper
Instructions on testing and removal of the auto damper and other repairs can be found here=> JSD2989AEW Service Manual
The other two possibilities are the=> 61006199 Defrost Heater and Defrost Thermostat
I will be here should you have questions, Thanks Sea Breeze
Dec 11, 2012 | Refrigerators
Freezer side works fine, Refrigerator side is too warm
Hello.
The leading problem when freezer works yet the refrig. section doesn't get cold is going to a problem with a automatic defrost system defect. Do ya see a bunch of frost inside of the freezer on the back wall?? if yes ya do see that frost build up ist defiently not defrosting and this tip i wrote covers what to check when it doesn't defrost http://www1.fixya.com/support/r10097882-wrong_when_freezer_frosted_refrig_warm
GENE
Oct 04, 2011 | Jenn-Air JCD2389G Side by Side...
My jcd2389des freezer is working fine but the refrigerator isn't cooling properly
Hello Sharleen,
GENE
Oct 03, 2011 | Jenn-Air JCD2389G Side by Side...
Freezer is not defrosting. I have tried changing the control settings, but that doesn't help. There is ice coverering about 1/3 of the freezer rear and is an inch or more thick. I have had the...
Freezer defrost coil is open and in need of replacement.
Go to attached site for part number and replacement/repair. If you get number of part, check with ebay for a cheaper price. Search Over 2 1 Million Appliance Parts
Aug 31, 2017 | Amana ATB2232MR Top Freezer Refrigerator...
The ice maker does not stop making ice when the bin is full
dear sir/madam
please make sure first your freezer,s defrost mode selecter set on auto mode or it,s set on auto defrosting mode. if it.s or freezer making continuously ice in ice bin then defrosting control device or temperature controller is not working for repair it please contact to your maintenance personnel for replace it .i hope after that it will work properly.
hope answer the question
thank you
please vote!
Aug 24, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Side by side frig/freezer. Freezer auto defrost
heatman101
Jul 03, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Freezer not defrosting
Hello pumpguy2
Welcome
You said, you have a Kenmore bottom Freezer Model 596.73503201. It works fine but the freezer has stopped defrosting. Any suggestions?
It is supposed to be auto or self defrosting.
What do you mean you are getting ice forming in the freezer?
Waiting for your response and more detailed explanation.
Huuum
Oct 01, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refigerater warm
You have a malfunction in the auto defrost circuit. Could be a timer, heater(s) or defrost thermostat. Defrosting it manually is only a temporary fix. Under normal conditions the system will auto defrost at least twice every 24 hours.
May 31, 2008 | Refrigerators
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
264 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
