Question about Car Audio & Video
Mg rover window and mirrows
I have an mg rover zt my drivers side window and mirrows have stoped working can u tell me where i will find the fuse for this
  • 11,896 Answers
Under dashboard on drivers side. A mirror is very helpful to see the fuses. A needle nose pliers is helpful to remove fuses.
Posted on Nov 17, 2009
Testimonial: "thanks for that m8 i looked under there but could not find them i found the ones under the glove compartmen and under the bonnet"
Fuses for electric side mirrows on ML 320 2006
The fuse box for Mercedes Ml320 is located under the hood on the right hand side. When you unclip the box the top of the box undercover has a chart that tells you which fuse is for what.
Oct 02, 2014 | Mercedes Ml Ml320 Ml350 Ml550 Ml63 Chrome...
How to top up a mg hydragas suspension
are these air shocks? computer controlled? shocks or struts?
Apr 21, 2014 | Koolertron For MG7 & MG ZT 2001 2002 2003...
Mgzs horn not working checked fuses
Own an MG Rover built after August 2003? Is one of the following not working:
Horn? Drivers electric window? Central Locking? Fog lights? Intermittent wipers?
It is very likely going to be one or several of the Pektron relays in the SCU unit that have gone. The relays are readily available for about £5 each on the web. It can all be fixed in under a day with some soldering tools, sockets, patience and perseverance.
Such a shame one small component, not even made by Rover, have just a detrimental effect on electrical reliability.
Here we fix a 2004 MG ZR but the Pektron relay are also used in the MG ZS, Rover 25 45 and MGF, so the general instructions are also applicable to them. Just the location of the SCU unit will vary.
On the MG ZR with a/c most garages will say the a/c has to be degassed etc (more cost) but here we leave the a/c connected. The SCU unit can just about be wiggled out from behind the a/c evaporator(radiator) unit with it still connected if some of the pipes clamps are loosened.
https://youtu.be/sQeFa5v5DXM
Or or search for youtube channel comeinhandynow
Feb 09, 2013 | Cars & Trucks
Zs mg rover fan heater risistor not working just not getting no electric feed to it and the fuse is ok.
A very common fault this one, that is easily fixed. On older cars the heater fan speeds one and two often fail, due to the resistors burning out. This applies to most of the MG Rover cars of the 90's and 2000's so Rover 200, 25, 45, 400, MG ZR, ZS, MGF and MGTF.
Buy three bigger resistors of value 0.68 ohm and wattage 10 watts, from eBay or an electronics store.
Most of the video here is an MG ZR, apart from the MG TF at the start but it is similar for all models. The MG TF took marginally longer due to the slightly more hidden location of the resistor pack. You need to remove a short vent pipe as well as the glovebox cover on that car.
Oct 09, 2011 | Cars & Trucks
Motorvehicle: mg ztt overheating. Added water and
dear friend-it sounds like you have burst a heater hose,i would seggest that you fil the water and then pressure test the system to find the problem.if it did not get to hot then she will be ok.
Nov 09, 2009 | 2002 Land Rover Freelander
Cut wire to drivers side vanity mirrow light. Now
sounds like you blew a fuse, check all fuses, that should be your problem. good luck.
Oct 25, 2009 | 2002 Ford Explorer Sport Trac
Rover 45 - oil capacity and type
Hi, Go to http://www.mg-rover.org, covers all MG Rover models, they will know exactly and type, etc.
Mar 22, 2009 | 2006 Sterling 825
Car Audio & Video Logo
173 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
