Question about Whirlpool LER7646E Dryer
Lightning hit our house a month ago and the dryer was running. It stopped and now the start button won't stay engaged l We have to push the button to make it run and tape it in the run position,
    President:
  • Whirlpool Master
  • 1,922 Answers
Your missing the voltage from the control panel timer to energize the relay to keep it energized after you push it to make it start,you need to trace this back to the control panel timer possibly thru a resistor that could have burned open due to power outage and probably replace
Posted on Nov 19, 2009
I have a Candy GOU218 when I push the start button it does start the dryer but as soon as I release my finger from the button it stops, It started doing it around a week ago so I had to push and hold
There are push to start circuits used for motors and then there are holding circuits that keep the unit running. This way the dryer stops if the circuit is open due to high temperature or end of the cycle. It seems as if the holding circuit (could be a rotary switch that stays closed while the dryer is running) or a holding circuit relay (stays closed until circuit is broken by the control) has failed.
Jan 09, 2014 | Candy Dryers
Electrical on but dryer does not start
Sounds silly, but because it's an electric dryer, it's run on a 220 line. Double check your breaker box to make sure both breakers are in the correct position. If only one breaker is in the correct position, you'll have electrical power, but the drum won't spin.
Jul 28, 2013 | Maytag Bravos MGDB850WB 7.3 Cu. Ft. Gas...
I have a kenmore he3 dryer that won't stay on. When I push the start button, the motor will turn the drum about a quarter of an inch then stop. I then need to push the pause/cancel button once and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 16, 2011 | Dryers
When I push the "push to start" button (knob) on
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Mar 14, 2011 | Kenmore Dryers
Dryer won't stay on
The motor centrifugal switch is not switching from the start winding to the run winding. The switch should stay in the run winding when the motor picks up speed unless power to the motor is interrupted or cut off. The switch is replaceable on most dryer models but sometimes it is an integral or built-in part of the dryer motor and failure of the switch requires the replacement of the motor. Indicate the exact model number of the dryer for more accurate troubleshooting and repair advice.
May 24, 2010 | Kenmore 63932 Electric Dryer
Dryer will engage with "start" button but will not operate when "start" button is disengaged.
So this sounds like it will start when the start button is pushed but will not stay running after the start button is released.
I.e. press start and drum turns
Leg go of the start button drum stops.
This would be a bad motor switch. Pressing start engages the start winding but once started the motor is not kicking the switch to run.
In some cases the broken belt safety switch can cause this if the drive belt is stretched or has been in use for a long time and worn.
Thanks for using FixYa!
Kelly
Mar 03, 2010 | Dryers
Dryer won't start when button is pushed. The
This is a broken belt symptom. On some models when the belt breaks the idler drops down and hits a micro switch that kills power to the run windings. So that the motor won't run and cause the heater to come on. This is a safety feature. Post your model number for a more precise answer.
Feb 03, 2010 | Dryers
Kenmore Dryer stop running when release the start button
I have whirlpool dryer, when i push the start button it will start but only stay on for part of the drying time. no the start button make noise when push and after keep trying it stop.
Dec 30, 2008 | Whirlpool LEQ9858P Electric Dryer
Maytag drier model MDE5806AYW
hi thanks for the question i would guess the motor but man thats a hard one if the dryer was hit by lightning it could have caused a fef problems myself i would call my insurance company tell them you were hit before you call the insurance check all appliances in your house you may find other problems thanks the appliance doc
Jul 22, 2008 | Maytag PYE2300AY Electric Dryer
Dryers Logo
85 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
