Question about Kodak EASYSHARE M340 Digital Camera
Turns itself off right away - Kodak EASYSHARE M340 Digital Camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Nov 18, 2009
Sub-Zero 650 - Keeps turning itself off. The
HI,
Are you having any fault codes along with this issue? Does the fans and light stop working also? This is unusual, is this the G or O model? I need more information to assist you.
Please let me know.
Sep 08, 2013 | Sub-Zero 650 / O Bottom Freezer...
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Samsung monitor makes a crackling sound and turns off
just chk all the capacitors...100% fault of capaiter and chk for any ic overheat tooo..
any prob...just. tell me..
Aug 16, 2017 | Samsung 2443BWT-1 Black 24" 5ms Widescreen...
I was playing a game and the ps3 just randomly shut off then the red light starts flashing and every time I turn it on it shuts off right away
If the system turns on but then turns itself off, beeps at you and flashes it's lights at you then you have over heated the system. The GPU chip has probly pulled itself away from the board. This will require you to diassemble the PS3...
better u download repair guide....
click here to download repair guide
Dec 17, 2010 | Sony Playstation 3 (PS3) Console
Camera turns on, and then turns off again right away
My M1033 had the same problem...I found a blog about someone using air to clean around the lens area...I cleaned my lens very thoroughly and noticed some gunk and once I cleaned this off, the camera seems to work like new!
Apr 05, 2010 | Kodak EasyShare M1033 Digital Camera
RCA L37WD12 LCD TV. it turns on and works perfectly with good picture. sometimes it just turns off by itself. sometimes it flashes rapidly before turning on. sometimes when you turn it on it just turns...
IF YOU CAN SOLDER YOU CAN FIX IT look for Bad capacitor 2200uf 25v if you see any that are puffed up on top they are bad. CK out Encompass Parts online 1-800-638-3328
Dec 08, 2009 | Televison & Video
Tv keeps turning itself off
This Sounds like you need to have the flyback replaced on the main board!
Dec 12, 2008 | Philips Magnavox DVD/VCR Dual Player
My camera turns on but turns off right away, and i know its charged.
When I turn the Camera on - - - - It quickly turns itself off. I have new batteries that have a full charge on them.
Aug 04, 2008 | Canon PowerShot S3 IS Digital Camera
"protection"
I ran across this problem before, the only solution the guy found was resetting the receiver, here''s how to do it:
Jan 30, 2006 | Samsung HT-DB390 System
Kodak EASYSHARE M340 Digital Camera Logo
181 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
